wukindada Posted May 3, 2006 Share Posted May 3, 2006 I see that this item is now avail.....any vendors on the site have them or are getting them? EJ25 fittment Part # KK3774 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
rao Posted May 3, 2006 Share Posted May 3, 2006 Why would you want one? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
wukindada Posted May 3, 2006 Author Share Posted May 3, 2006 I have a track close by.......Sebring:) Several very high speed corners.....the last one on the track has eaten up several STI's. High speed corner...high revs.....Need more oil......not there..... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
edmundu Posted May 3, 2006 Share Posted May 3, 2006 So what's the pump going to do about it? Seems like it is a sump/baffling issue, so a better pump still won't do any better without a steady oil supply. Link to comment Share on other sites More sharing options...
mccorry Posted May 3, 2006 Share Posted May 3, 2006 I agree... a high flow pump isn't going to net you anything. Your pressure relief valve on your pump outlet is set to 85psi... so that is all the oil pressure you're going to get.... Link to comment Share on other sites More sharing options...
wukindada Posted May 3, 2006 Author Share Posted May 3, 2006 Very true......any ideas to help the situation? Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
edmundu Posted May 3, 2006 Share Posted May 3, 2006 Very true......any ideas to help the situation? Short of a custom redesigned oil pan, or at least baffles, only a dry sump setup would truly eliminate the issue. But of course it is quite expensive & likely overkill for occassional track use. Perhaps using a little overfill on the oil? Like .5qt or so, might be enough to keep some more near the pump's intake? Link to comment Share on other sites More sharing options...
rao Posted May 3, 2006 Share Posted May 3, 2006 The Legacy's oil pan is pretty decent, but an area around the sump with a flapper piece would probably help and not be too expensive or difficult. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Th3Franz Posted May 3, 2006 Share Posted May 3, 2006 Is our oil pan the same as the STi? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
jim malach Posted May 3, 2006 Share Posted May 3, 2006 try Z10motorsport I think there in new york some where for dry custom dry sump they make them for honda's and they said that they could make one for my 300z I knew the web site but it slips my mind Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted May 3, 2006 Share Posted May 3, 2006 Dry-sump twin turbo H6 FTW... It is only money! Better yet siamese two EJ25x motors, weld the cranks and cams together, slice up and re-weld a few short blocks, heads together... re-sleeve, and make yourself a 5-liter flat eight, dry sump it, put on an high-flow electric water pump, and put on a pair of twin-scroll turbos, and a huge intercooler... THAT would be a sight. and probably a hell of a sound, too. can we say an easy 800hp or more? Cosworth just came out with new ej25-fitment heads, too, didn't they? I would think that a company as renowned as cosworth would be worth their salt, and offer products that do have real benefit... but I am not sure. But the point is correct that a high-flow oil pump just sucks the pan dry faster, if the oil isn't kept in place with a windage tray and/or pan baffles. Link to comment Share on other sites More sharing options...
BOXRPWR Posted May 4, 2006 Share Posted May 4, 2006 might be a dumb question.....but sense there's consensus that a baffled oil pan is the right solution....is there an aftermarket oil pan that fits the EJ25 engine? seems like a decent market since that includes all the STIs. Heck, might even fit on the 2.0L engine but I don't know. any vendors for such a thing? Link to comment Share on other sites More sharing options...
