Rallitek.com Posted May 1, 2007 Share Posted May 1, 2007 ^what about the clearance with the O2 sensor? I have not heard any issues w/ O2 sensor clearance. Stock manifolds or header? -Sean S. www.RalliTEK.com Link to comment Share on other sites More sharing options...
jim1969 Posted May 1, 2007 Share Posted May 1, 2007 from Mr. T who put in headers. Update; The short answer is that the skid plate will clear the GT Spec Headers but, you need 3 spacers at every mounting point. I purchased some additional nylon spacers the same thickness at my local Ace Hardware. Also had to get longer bolts. I also picked up some stainless steel fender washers to give the bolts more coverage area. I also gave the passenger side "wing" a little tug to give it a bit more clearance. Also have to watch the clearance on the O2 sensor. Overall, pretty good. Certainly better then the cracked, warped piece of plastic I removed. I know, this post is worthless without pics. If anyone wants some, I'll try to get some in the next few days.! Link to comment Share on other sites More sharing options...
Rallitek.com Posted May 1, 2007 Share Posted May 1, 2007 "Also have to watch the clearance on the O2 sensor." Clearance on factory header is no problem. I need more information to comment about the GTSpec header. Sean S. Link to comment Share on other sites More sharing options...
jim1969 Posted May 1, 2007 Share Posted May 1, 2007 maybe someone local has a set on the legacy. they are the same as Mad Dad and Tomei. Link to comment Share on other sites More sharing options...
ama0787 Posted May 11, 2007 Share Posted May 11, 2007 With my stock header I am getting some vibration where they touch under certain circumstances. You guys are sending me some more bushings but I think you should re evaluate the origional bushings you send out. Link to comment Share on other sites More sharing options...
Mr. T Posted May 11, 2007 Share Posted May 11, 2007 "Also have to watch the clearance on the O2 sensor." Clearance on factory header is no problem. I need more information to comment about the GTSpec header. Sean S. With the GT spec headers, the O2 sensor is right above the "wing" on the passenger side. With out spacers, you would have the top of the wing in contact with the wires that come off of the sensor. I finally ended up using 1 1/2 inch steel spacers for the back 3 bolts (plus washers). That and a little tug on the wing and the clearance is (barely) enough... I am not getting any vibration or buzzing now that I went to the 1 1/2 inch steel spacers. Link to comment Share on other sites More sharing options...
jim1969 Posted May 11, 2007 Share Posted May 11, 2007 I have not heard any issues w/ O2 sensor clearance. Stock manifolds or header? -Sean S. www.RalliTEK.com see above post by Mr T. Link to comment Share on other sites More sharing options...
Rallitek.com Posted May 11, 2007 Share Posted May 11, 2007 I have one of these skidplates on my car. I am not having any clearance issues at all (factory manifolds). We are more than happy to provide spacers for anyone that needs them. Sean S. Link to comment Share on other sites More sharing options...
AKLGT Posted May 11, 2007 Share Posted May 11, 2007 woot! can't wait til i get mine end of the month! thanks Chris for a great deal! Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
ih8vtec13 Posted May 11, 2007 Share Posted May 11, 2007 The sound it makes when the car bottms out will make you jump a little Link to comment Share on other sites More sharing options...
caramall2 Posted May 13, 2007 Share Posted May 13, 2007 Just ordered. Will PM you for spacers. Link to comment Share on other sites More sharing options...
Rallitek.com Posted May 14, 2007 Share Posted May 14, 2007 Just ordered. Will PM you for spacers. I forwarded your request to our customer service manager. -Sean S. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted May 14, 2007 Share Posted May 14, 2007 Just ordered. Will PM you for spacers. I got one coming too. I will see if it fits around my headers, if not I know a good welding shop that will tweak it. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
PhilT Posted June 10, 2007 Share Posted June 10, 2007 Tried this up today, and definately won't fit over GT Spec headers. It needs about some 2" spacers on the front two mounting points, and then the front edge folding up to meet the underside of the fender. Plus the passenger side 'flap' folding out some more. I'll take it in to work next week and get it modified. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Mr. T Posted June 10, 2007 Share Posted June 10, 2007 Tried this up today, and definately won't fit over GT Spec headers. It needs about some 2" spacers on the front two mounting points, and then the front edge folding up to meet the underside of the fender. Plus the passenger side 'flap' folding out some more. I'll take it in to work next week and get it modified. Actually, I did get mine to fit with the GT Spec headers. I did use 4 provided spacers at each front point AND, to resolve the issue with the bottom of the bumper cover being higher than the skidplate, I drilled out 2 holes in the skid plate and pulled the 2 bumper tabs down and over the skid plate to bring the bumper cover down to nearly equal with the skidplate. I used a couple of "popits" to secure the tabs to the skidplate and it works just fine. I did have to bend the wing on the passenger side some and use the 1 1/2 inch metal tube spacers in the back but it did fit over the headers. I am happy with the skid plate and Rallitek.. Just my 2 cents. Link to comment Share on other sites More sharing options...
PhilT Posted June 10, 2007 Share Posted June 10, 2007 Don't get me wrong, I am happy with the skidplate, and with Rallitek (although they don't want to answer my emails right now ). I was pretty sure it wouldn't fit when I bought it, now I know It's not a big deal to machine up some aluminum spacers and weld them to the skidplate, that way I'm not farting about trying to hold them in the right place while I fit it up. Also going to make up some bolt on covers for over the filter and drain plug holes. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Billy Dagwood Posted June 10, 2007 Share Posted June 10, 2007 Ok, this is a little off topic, but what does SSI stand for? I just wanted to know since I'm going to be bolting a giant piece of aluminum that says SSI all over it onto the bottom of my car. Link to comment Share on other sites More sharing options...
TSiWRX Posted June 10, 2007 Share Posted June 10, 2007 ^ I believe it's "(S)uby (S)olutions, (I)nternational" - right? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
LittleBlueGT Posted June 10, 2007 Share Posted June 10, 2007 It's not a big deal to machine up some aluminum spacers and weld them to the skidplate, that way I'm not farting about trying to hold them in the right place while I fit it up. Good idea! I just used double sided tape to hold the spacers to the plate. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Billy Dagwood Posted June 11, 2007 Share Posted June 11, 2007 ^ I believe it's "(S)uby (S)olutions, (I)nternational" - right? yeah, I figured Suby Solutions, but I wasn't sure about the I. Inc.? International? Irritation? Ire? Idiosyncracies? Link to comment Share on other sites More sharing options...
Mr. T Posted June 11, 2007 Share Posted June 11, 2007 "Suby Solutions Indeed" Link to comment Share on other sites More sharing options...
Claw Posted June 14, 2007 Share Posted June 14, 2007 I'm thinking about getting this skid plate. For a stock 05 LGT, does it bolt right in, out of the box? Or do I need spacers? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted June 14, 2007 Share Posted June 14, 2007 I'm thinking about getting this skid plate. For a stock 05 LGT, does it bolt right in, out of the box? Or do I need spacers? You need spacers, but they come with the plate. You actually gain ground clearance! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
caramall2 Posted July 3, 2007 Share Posted July 3, 2007 Added wire mesh on the openings for added protection. Just duct tape in place, then secure with metal epoxy (sets in about 5 minutes). Also meshed oil filter and oil plug openings...just bolted on the mesh with a rubber washer. To access, just swing the mesh away, then back in place when you're done. Link to comment Share on other sites More sharing options...
caramall2 Posted July 3, 2007 Share Posted July 3, 2007 Are most with aftermarket headers using two spacers at each location? Are the included bolts long enough? Link to comment Share on other sites More sharing options...
