PGT Posted April 2, 2006 Share Posted April 2, 2006 so, too soon to panic?? Damn, I was already for it too Link to comment Share on other sites More sharing options...
TRS Posted April 12, 2006 Share Posted April 12, 2006 Only glue the spacers after you figure out where they go... Each bolt goes into a slot, not a hole, so the plate can slide a little to adjust for manufacturing tolerances on the cars. I do not think the spacer thing is a big deal, and so far I think I am the only one who has installed the plate. Ted I finally got around to installing mine tonight. Followed your write-up and it was a pretty easy install. The hardest part was doing it solo and having to hold the plate to get the front bolts threaded. You just have to use an elbow here and a knee there to hold the plate up to the frame while you find the bolt holes and get them started. As you said, you'd can't glue the spacers on beforehand because you don't know exactly where they'll end up. Once installed, the next time you remove it you could then reference the spacers' positions to the marks left by the bolts on the otherside of the plate. Link to comment Share on other sites More sharing options...
praedet Posted April 12, 2006 Author Share Posted April 12, 2006 Yeah, the one person thing is fun I felt like I had done a good set of crunches because I had the plate on my elbows, knees, and feet... Did you install two spacers on all the back bolts TRS? Ted Link to comment Share on other sites More sharing options...
TRS Posted April 12, 2006 Share Posted April 12, 2006 Did you install two spacers on all the back bolts TRS? Ted I couldn't find any with a diameter that large. I got some with a smaller O.D. but decided not to use them. Link to comment Share on other sites More sharing options...
B2.5GT Posted April 30, 2006 Share Posted April 30, 2006 Will this skit plate fit 1998 LGT. Link to comment Share on other sites More sharing options...
praedet Posted April 30, 2006 Author Share Posted April 30, 2006 No, but I think rallitek has one that will fit older Legacys, just give them a call... Ted Link to comment Share on other sites More sharing options...
dtmenace Posted May 4, 2006 Share Posted May 4, 2006 can you see this thing if you are looking at the front of the car from 10-20 ft away? Link to comment Share on other sites More sharing options...
praedet Posted May 4, 2006 Author Share Posted May 4, 2006 nope Link to comment Share on other sites More sharing options...
legacy2005 Posted May 18, 2006 Share Posted May 18, 2006 praedet how you liking the skip plate so far. im thinking of picking one up now that im doing autox. allrdy busted a piece of the plastic undersheild on a cone..lol Work hard. Play even harder. My Garage Link to comment Share on other sites More sharing options...
praedet Posted May 18, 2006 Author Share Posted May 18, 2006 I like it a lot, no problems so far! I will be putting the car on a ift this weekend, so I will check up on it Link to comment Share on other sites More sharing options...
PGT Posted May 18, 2006 Share Posted May 18, 2006 ^ just did that and all looks good!! My only issue is how the front overlaps the bumper skin. Need to fool with it a bit, but I'm the only one who knows that it's weird. Link to comment Share on other sites More sharing options...
Terrain.org Posted May 18, 2006 Share Posted May 18, 2006 Do you have a plate covereing the rear differential, as well? Link to comment Share on other sites More sharing options...
blkwag Posted May 18, 2006 Share Posted May 18, 2006 Does one fit the LGT? The dealer told me it Subys will not. Link to comment Share on other sites More sharing options...
praedet Posted May 18, 2006 Author Share Posted May 18, 2006 Nope, there isn't one out there yet As soon as there is, I will get it... Ted Link to comment Share on other sites More sharing options...
Rallitek.com Posted May 19, 2006 Share Posted May 19, 2006 Do you have a plate covereing the rear differential, as well? We with SSI are working on that. There are some for older cars but not for the new LGT. Garner Thomas Link to comment Share on other sites More sharing options...
bugblatterbeast Posted June 12, 2006 Share Posted June 12, 2006 How much space is there between the plate and the front jack point? Link to comment Share on other sites More sharing options...
caramall2 Posted July 16, 2006 Share Posted July 16, 2006 Bump...can you still jack up the front? Also, rallitek site says "70 lbs shipping". Not sure if that's the real weight, but are you sure about the skid plate weighing only 20ish lbs? Thanks. How much space is there between the plate and the front jack point? Link to comment Share on other sites More sharing options...
phoenix96 Posted July 17, 2006 Share Posted July 17, 2006 Bump...can you still jack up the front? Also, rallitek site says "70 lbs shipping". Not sure if that's the real weight, but are you sure about the skid plate weighing only 20ish lbs? Thanks. The UPS label on the box it came in says "20 LBS". I'll put it on a scale when I get a chance, but 20 lbs feels about right. phoenix96 2006 Legacy GT Ltd · 2011 Outback 3.6R Ltd · 1992 SVX 2006 Outback 3.0R VDC · 2009 Forester 2.5X 2002 Outback VDC · 1996 Outback 2.5L · 1986 GL-10 Link to comment Share on other sites More sharing options...
PGT Posted July 17, 2006 Share Posted July 17, 2006 shipping weight os more because it's oversized...it gets billed at the higher rate. Link to comment Share on other sites More sharing options...
Rallitek.com Posted July 17, 2006 Share Posted July 17, 2006 Bump...can you still jack up the front? Also, rallitek site says "70 lbs shipping". Not sure if that's the real weight, but are you sure about the skid plate weighing only 20ish lbs? Thanks. Yes, you can still jack up the front. (jack at original point using the plate itself) Bulk rate, not actual weight. The plate itself is about 10lbs. Pics: Aluminum Skidplate - LegacyGT (click on the pics for full size image) Sean S. RalliTEK - Subaru Performance Parts Link to comment Share on other sites More sharing options...
Triskite Posted July 20, 2006 Share Posted July 20, 2006 I just got mine in and was about to install.... guess i'll wait for the spacers~~ tore my stock rubber POS to pieces off-road. hopefully this 1/8" will hold up... otherwise i'll have to custom order Primitive's 3/16" metal... Link to comment Share on other sites More sharing options...
Rallitek.com Posted July 20, 2006 Share Posted July 20, 2006 I just got mine in and was about to install.... guess i'll wait for the spacers~~ tore my stock rubber POS to pieces off-road. hopefully this 1/8" will hold up... otherwise i'll have to custom order Primitive's 3/16" metal... You did not recieve the hardware kit with the plate??? Link to comment Share on other sites More sharing options...
PhilT Posted November 20, 2006 Share Posted November 20, 2006 This looks like just what I need, I am wondering though why the access for the filter and drain plug has been left open ? I would like to keep it flush underneath and would fit removeable covers over those openings if I can get some aluminium plate cut to size. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Rallitek.com Posted November 20, 2006 Share Posted November 20, 2006 The main purpose is for protection of components aginst road hazards / debris, and ease of service. The plate is not meant for dirt or rally racing. Sean S. Link to comment Share on other sites More sharing options...
caramall2 Posted November 25, 2006 Share Posted November 25, 2006 Any way to insert some spacers to fit aftermarket headers? Link to comment Share on other sites More sharing options...
