rawfish Posted June 16, 2007 Share Posted June 16, 2007 Looks good! I wasn't sure if I'm gonna put my emblem back on, so for now it's off. Link to comment Share on other sites More sharing options...
diamondgraymetallic21 Posted June 24, 2007 Share Posted June 24, 2007 Well two comments from me after just doing mine. First off, I attached the mesh by using clear liquid nails. That way I wouldn't have to drill or find spots to attach it, I did this on a previous car and it held for years. Just another option since I hadn't seen it mentioned. Second, for those of you that painted the chrome section, did you have any problems with the chrome beginning to "bubble" after you sanded it so the primer and paint would adhere better? Mine began to bubble and it seems to almost be impossible to get rid of/smoothed out. Link to comment Share on other sites More sharing options...
FJuan Posted June 24, 2007 Share Posted June 24, 2007 Second, for those of you that painted the chrome section, did you have any problems with the chrome beginning to "bubble" after you sanded it so the primer and paint would adhere better? Mine began to bubble and it seems to almost be impossible to get rid of/smoothed out. As long as you sanded all the chrome off (Start with 180 or 220 grit, end with 320 or 360 grit) and washed it really good, because it's easy to leave finger prints on the edges. Let dry out several hours before priming, if there is any oil or water lingering on the plastic this will give you bubble or "Fish Eyes" effect. When priming, shoot a light spray across the surface to make good contact, wait about 5-10 mins before coating. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Guest Gitster Posted June 25, 2007 Share Posted June 25, 2007 As long as you sanded all the chrome off (Start with 180 or 220 grit, end with 320 or 360 grit) and washed it really good, because it's easy to leave finger prints on the edges. Let dry out several hours before priming, if there is any oil or water lingering on the plastic this will give you bubble or "Fish Eyes" effect. When priming, shoot a light spray across the surface to make good contact, wait about 5-10 mins before coating. Im still working on mine. Ive almost gotten all the chrome off. Its insane trying to peel it off. Im using a dremel, it starts to strip it when the heat from the dremel contact peels it off. I dont recomment it. Just get a good sanding base down. I had to continue to get all the chrome off because I started to do it, so I need it all off to have a clean surface. But when im all done I shouldnt have any problems with bubbling because its just paint over the base plastic instead of the chrome. Link to comment Share on other sites More sharing options...
FJuan Posted June 25, 2007 Share Posted June 25, 2007 I agree, I wouldn't recommend using any power tools since it's easy to leave large groves in the paint or plastic. Hand sanding is the best route. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
sleeper8406 Posted August 27, 2008 Share Posted August 27, 2008 good guide Link to comment Share on other sites More sharing options...
Legdude Posted April 25, 2009 Share Posted April 25, 2009 Ill be doing this tomorrow, ill throw my pics up soon Link to comment Share on other sites More sharing options...
RedDawg Posted April 27, 2009 Share Posted April 27, 2009 i cant decide whether to leave the chrome ring or fully paint it BSM. Link to comment Share on other sites More sharing options...
06gtleg Posted May 6, 2009 Share Posted May 6, 2009 take it out Link to comment Share on other sites More sharing options...
nka Posted May 17, 2009 Share Posted May 17, 2009 well, I did this today. Things I notice... I suck in body shop, really ! Maybe I did this too fast or without propre lightning, but it's only cute from far. From near, you see all the hole and wave well, it was craked anyway, so it's not a big lost and I can always try to "redo" it ! I remember I did some "patch-up" on my civic and it was OK. Link to comment Share on other sites More sharing options...
cryo Posted June 6, 2009 Share Posted June 6, 2009 I did this a few weeks ago, I originally tried regular black paint and it came out horrible. redid it and used crinkle finish black and it came out great. it was broken before so I had nothing to loose but need to buy a emblem to put on it. http://i67.photobucket.com/albums/h314/WhiteRushin02/000_0231.jpg http://i67.photobucket.com/albums/h314/WhiteRushin02/000_0240.jpg http://i67.photobucket.com/albums/h314/WhiteRushin02/000_0264.jpg [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
REDlgt05 Posted August 13, 2009 Share Posted August 13, 2009 Any body got any pictures of how they attached the Mesh to the grille? Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted August 13, 2009 Share Posted August 13, 2009 I used zip ties. Link to comment Share on other sites More sharing options...
REDlgt05 Posted August 13, 2009 Share Posted August 13, 2009 Me too, but i was scanning the rest of the post and i saw that others ziptied it to the clips that actualy hang onto the bumper...i wouldent have thought of that...i just drilled small holes in the face of it and put the ziptie threw the mesh as you can see just bairly in the 2nd pic...it dont look too bad, but when i get some time ill fill thoes holes and change the anchor point.....when i mounted my badge...i left it on the plastic part that originaly ran down the center of the grill...i just sanded it so it was even and at the correct angle to mount back up to the grill with out looking TOO slanted... i used epoxy to put the badge back on but it ate away the blue paint so now it looks like its ' frosted' on the inside...any idea on how to remoze epoxy? ...i dont think using heat will work for this Link to comment Share on other sites More sharing options...
triple_B Posted January 27, 2010 Share Posted January 27, 2010 here is my original local post but thought i could get some thoughts here as well, thanks. check out post #14, its my big unknown. http://www.legacygt.com/forums/showthread.php?p=2802531#post2802531 Link to comment Share on other sites More sharing options...
teK-- Posted January 28, 2010 Share Posted January 28, 2010 For those who have used the bondo technique and had their grills on for a while, have you experienced cracking? I am advised that due to the plastic and bondo having very different expansion/contraction characteristics, that cracks will develop in those areas. Link to comment Share on other sites More sharing options...
TravisS Posted January 28, 2010 Share Posted January 28, 2010 Looks pretty much the same as when I did it, more then 2 years ago now. No noticeable cracks. Link to comment Share on other sites More sharing options...
greatredbear Posted February 17, 2012 Share Posted February 17, 2012 i get all the mesh part. but im scared to cut the middle out cause im not sure how to bondo the holes. and i dont have any experience working with body stuff. any tips? Link to comment Share on other sites More sharing options...
FJuan Posted February 17, 2012 Share Posted February 17, 2012 i get all the mesh part. but im scared to cut the middle out cause im not sure how to bondo the holes. and i dont have any experience working with body stuff. any tips? It's fairly easy to do, just mix the bondo with the hardner together as directed. Sand over the area with 320 grit paper and then use a plastic scraper and smoothly apply bondo over the holes. If you need to apply a 2nd coat, wait about an hour an repeat. Let it dry completely, usually overnight. Then sand over it with 320 grit paper again and smooth it out to blend it in with the plastic. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted February 18, 2012 Share Posted February 18, 2012 Your going to need to use some mesh to cover the spaces. Bondo the mesh onto the backside and that will give you a platform for bondo on the top. Link to comment Share on other sites More sharing options...
TravisS Posted February 19, 2012 Share Posted February 19, 2012 Having never worked with Bondo before doing this, honestly the hardest part is making the mesh look good I need to redo my mesh, but I'm lazy. It might be worth spending a little more then just gutter guard. It's too flimsy and looks kinda bad after a couple years. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted February 19, 2012 Share Posted February 19, 2012 Grilleguy.com sweet stainless steel mesh in silver or black powdercoat, looks awesome. Link to comment Share on other sites More sharing options...
triple_B Posted February 22, 2012 Share Posted February 22, 2012 i just used the cheap metal mesh that came with my bondo. who cares what color it is. bondo is pink and i painted the grill afterwards. put a few dabs on the back sides to hold the mesh, dry. put a small layer on mess, dry. fill in the divet to match surface of grill, dry. sand smooth. clean with mineral spirits, dry. paint. done. Link to comment Share on other sites More sharing options...
greatredbear Posted February 23, 2012 Share Posted February 23, 2012 how can you connect two pieces of mesh? i got the gutter guard stuff for free and its not tall enough for my grill. any ideas/suggestions? Link to comment Share on other sites More sharing options...
FJuan Posted February 23, 2012 Share Posted February 23, 2012 You'll need to get a taller screen/mesh in order for it to look right. Connecting the mesh may not give you the look you want, IMO. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
