PeterJMC Posted February 14, 2006 Share Posted February 14, 2006 I bake them before to open them up, then bake them after to seal them back up. Point was that he exceeded the 187*F that you indicated to bake the headlights closed. Link to comment Share on other sites More sharing options...
GeorgeB Posted February 14, 2006 Author Share Posted February 14, 2006 yes i did ... for 10 minutes . hmmm yummy legacy headlight ... he he he Link to comment Share on other sites More sharing options...
Boostjunkie Posted February 14, 2006 Share Posted February 14, 2006 My friend, I have had angel eyes on my car for around a year, which I installed myself. I have had my headlights apart twice now. I am quite familiar with how to disassenble and reassemble my headlights. I too baked my headlights after installing my angel eyes. However, you only need to do so for about 5-7 minutes. Even if you went longer only the outer skins and housing get very hot. The inner parts holding the angel eyes and such don't really get hot in that short period of time. My point is that on a hot summer day, when your car is left out in the sun for many hours the superglue might start to breakdown. If you are fine with it, that's ok with me. Just warning you of a potential problem. Link to comment Share on other sites More sharing options...
GeorgeB Posted February 14, 2006 Author Share Posted February 14, 2006 thank you ... potential problem noted the silicon i had didn't set fast enough , that's why i dind't used it . Link to comment Share on other sites More sharing options...
TSiWRX Posted February 14, 2006 Share Posted February 14, 2006 I'd recommend against superglue as well. Not only for Boostjunkie's cited concerns, but also as they can form vapor deposits during curing and permanently "haze" plastics. Additionally, due to their highly "liquid" nature, they can easily cause mated parts to "slip" during critical setting, creating a mess... Try to find super-fast-setting epoxy - you'll want something that starts to really "gel" within 30 seconds, and will set at well under two minutes, max. This should allow you more than enough time to properly build any "bridges" extending from your light housing to the halo ring, and will allow you some movement in finalizing placement. Black or white would be preferable, if I had to do mine over again, as the "clear" type tends to yellow with heat exposure. And let all of our lessons translate to your next install - be sure to give enough "freedom of movement" to your rings so that they don't crack! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
GeorgeB Posted February 14, 2006 Author Share Posted February 14, 2006 have you seen the rings i installed? they cannot be cracked ... unless u use a hammer or something like that Link to comment Share on other sites More sharing options...
jj808 Posted February 14, 2006 Share Posted February 14, 2006 Tide, Add me in if the price is close to the quoted. Im not too happy with the gap on the other Halo's. Link to comment Share on other sites More sharing options...
GeorgeB Posted February 14, 2006 Author Share Posted February 14, 2006 closeup ... Link to comment Share on other sites More sharing options...
johnAWD Posted February 14, 2006 Share Posted February 14, 2006 What type of adhesive did you use to hold them in place, George? Link to comment Share on other sites More sharing options...
GeorgeB Posted February 14, 2006 Author Share Posted February 14, 2006 ahhh not again it was super glue , which at the moment seemed the best choice . it was sundey afternoon and there was no hardware shop opened. so , if thay will fall off, i hope the won't , i'll reopen the case and use some poxypol or something like that . Link to comment Share on other sites More sharing options...
BOXRPWR Posted February 14, 2006 Share Posted February 14, 2006 Tide didn't answer my PM. Is this Group Buy for real? I'm asking because I've already contacted Paul at AVO and he can get these very same halo rings from Gialla in Japan. His cost is $150 bucks per set. Don't have a final price with shipping yet. I'm not trying to be pushy. Just pointing out that it's obvious there is enough interest to support a GB. Using Paul & AVO is a perfectly good alternative to having Tide purchase a bunch himself. Unless the price is much more attractive. Has anybody seen any pricing info yet?????? Link to comment Share on other sites More sharing options...
johnAWD Posted February 14, 2006 Share Posted February 14, 2006 Heh heh. Sorry - I'm a newb to this place. http://jsalmi.com/images/headbanger.gif ahhh not again it was super glue , which at the moment seemed the best choice . it was sundey afternoon and there was no hardware shop opened. so , if thay will fall off, i hope the won't , i'll reopen the case and use some poxypol or something like that . Link to comment Share on other sites More sharing options...
GeorgeB Posted February 14, 2006 Author Share Posted February 14, 2006 no problem you are driving the competition ... he he he Link to comment Share on other sites More sharing options...
johnAWD Posted February 14, 2006 Share Posted February 14, 2006 Only until my home equity loan paperwork is done & I can hand a check to the guy I'm buying the LGT from. Link to comment Share on other sites More sharing options...
Legacy05 Posted February 14, 2006 Share Posted February 14, 2006 Although those look nice, I am sorta biased towards my halos .. I like the thinner look. Link to comment Share on other sites More sharing options...
PeterJMC Posted February 14, 2006 Share Posted February 14, 2006 Although those look nice, I am sorta biased towards my halos .. I like the thinner look. +1 http://legacygt.com/forums/vbpicgallery.php?do=big&p=1058 Link to comment Share on other sites More sharing options...
Nighthawk CL9 Posted February 14, 2006 Share Posted February 14, 2006 well at leastt nea' mitica, vasile, gheorghe and ion will wonder how complicated the subaru is as opposed to their 1970 dacia 1300 hahahhahaha......maybe they upgraded to the 1310. but you can aleast count of having a dacia parts store everywhere.....especially in bucharest Ex '05 Legacy GT Link to comment Share on other sites More sharing options...
Tide Posted February 14, 2006 Share Posted February 14, 2006 You sent a PM yes, but you didn't ask me a question, so not sure what I'm to respond to. When I get ahold of a distributor and get a firm order, I'll update everyone with details. Tide didn't answer my PM. Is this Group Buy for real? I'm asking because I've already contacted Paul at AVO and he can get these very same halo rings from Gialla in Japan. His cost is $150 bucks per set. Don't have a final price with shipping yet. I'm not trying to be pushy. Just pointing out that it's obvious there is enough interest to support a GB. Using Paul & AVO is a perfectly good alternative to having Tide purchase a bunch himself. Unless the price is much more attractive. Has anybody seen any pricing info yet?????? Link to comment Share on other sites More sharing options...
Tide Posted February 14, 2006 Share Posted February 14, 2006 Ok, got a distributor, but they need a part # or other information before calling and placing the order. They say that Gialla makes the parts on demand usually (I dont know if that's true in this case) and it would be 2-4 weeks + shipping. I need to make a group buy forum sometime. Anyways, if someone could figure out the Gialla part # or official name it would really help me out -- need to get out of the office here and pick up dinner for tonight. Link to comment Share on other sites More sharing options...
f1anatic Posted February 14, 2006 Share Posted February 14, 2006 well at leastt nea' mitica, vasile, gheorghe and ion will wonder how complicated the subaru is as opposed to their 1970 dacia 1300 Damn these Romanians are sprouting up EVERYWHERE. I just learnt NightHawk - from Chicago and fellow GT owner is Romanian. Anyways George...pune o poza dincolo sa moara IMPULS de ciuda ! Link to comment Share on other sites More sharing options...
4boxparts Posted February 14, 2006 Share Posted February 14, 2006 Not sure if this is any help. But on the gialla website it is referred to as: CCFL headlight ring- ring kit Link to comment Share on other sites More sharing options...
blacky Posted February 15, 2006 Share Posted February 15, 2006 Subscribe +I want to be in group of buy:icon_bigg Link to comment Share on other sites More sharing options...
Tide Posted February 15, 2006 Share Posted February 15, 2006 Yes, I passed that along after I finally found it in the catalog. It looks like they are listed for $133 after currency conversion. They are supposed to call tonight and get pricing for me, we'll see. Link to comment Share on other sites More sharing options...
PeterJMC Posted February 15, 2006 Share Posted February 15, 2006 Group buy going on here.... in the new group buy forum. http://www.legacygt.com/forums/showthread.php?t=28043 Link to comment Share on other sites More sharing options...
GeorgeB Posted February 15, 2006 Author Share Posted February 15, 2006 Damn these Romanians are sprouting up EVERYWHERE. I just learnt NightHawk - from Chicago and fellow GT owner is Romanian. Anyways George...pune o poza dincolo sa moara IMPULS de ciuda ! am pus ... am pus pana si pe forumul bmw ... si sa citez de acolo : " GeorgeB, nu vreau sa te superi, dar e la fel cu o Dacie cu sigla BMW sau cu un 520i cu sigla de M5... In aceeasi categorie. Desigur, gusturile fiecaruia difera. Angel eyes e o semnatura a BMW, nu? Daca da, atunci nu inteleg de ce ti-ai dori pe subaru o semnatura BMW. Nu iti doresti si o sigla BMW, nu? De ce atunci angel eyes? Sper sa nu mi-o iei in nume de rau, daca iti spun ce cred." asta zicea admin ul daca ma intelegi ce mama ciorilor , ma lupt cu ei pana la moarte Link to comment Share on other sites More sharing options...
