el5y Posted December 23, 2008 Share Posted December 23, 2008 ^ I almost wonder if maybe one of the connectors to the roll connector just popped off? I'm pretty sure the roll connector will break before the connectors popped off.. Link to comment Share on other sites More sharing options...
TSiWRX Posted December 23, 2008 Share Posted December 23, 2008 (edited) ^ True - from your other research (page 16), it looks like there's precedent for just this type of thing....... Good call! Edited December 23, 2008 by TSi+WRX <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
alaskajoel Posted December 24, 2008 Share Posted December 24, 2008 el5y, you are my freaking hero. I knew I had seen something like that, but didn't know where it was. I guess i'll order another roll connector - is there any secret to getting it off? Link to comment Share on other sites More sharing options...
el5y Posted December 24, 2008 Share Posted December 24, 2008 el5y, you are my freaking hero. I knew I had seen something like that, but didn't know where it was. I guess i'll order another roll connector - is there any secret to getting it off? I would PM mvigneau and ask him as I've never done it. I don't think it would be too bad though..just make sure you had your wheel centered and the roll connector centered when you do replace it otherwise you'll have to do it again Link to comment Share on other sites More sharing options...
robertsm99 Posted December 26, 2008 Share Posted December 26, 2008 Anyone by chance know how or has tried to switch the seek controllers from going through all the channels on the radio to being able to change between all my preset channels? I would rather have this option than seeking through every single radio station, just don't know if or how it can be done. Just got a Spec-B a few weeks ago, but not doing this mod anytime soon unless it's REALLY easy, it's too freaking cold in Chi to be working on a car outside. Link to comment Share on other sites More sharing options...
el5y Posted December 26, 2008 Share Posted December 26, 2008 If someone figures out what pressing those preset buttons does exactly (Ohms changes, etc on the head unit) I'm sure someone can figure out how to change the buttons to do that...Or maybe re-program the head unit itself... I just don't know how feasible it is to do that. Link to comment Share on other sites More sharing options...
sabin Posted April 19, 2009 Share Posted April 19, 2009 has anyone tried to use a 08 spec b wheel (the one with the cruise on the right and the si drive controls) in an 05 outback or legacy 5eat Link to comment Share on other sites More sharing options...
SVXdc Posted August 26, 2009 Share Posted August 26, 2009 (edited) I've looked over the 2005 wiring diagrams, and figured out a few things. First, the pins used on the "B68" harness: Harness "B68" (white connector under steering column, near wheel) Viewing contact pins on car's harness plug, wires pointed away from you: 1 --- 2 3 4 5 6 7 8Viewing back of "B68" harness plug -- same orientation as picture below (or viewing pins side of socket that is wired to the clockspring / roll connector): 3 2 --- 1 8 7 6 5 4 (click for larger image)The B68 harness in this picture only has wires for the horn and cruise control buttons. (It's a cropped and rotated version of Trabbic's from his post #7 in this same thread) Common (wheels with shift, audio, or no buttons): 1 White Cruise (Main Switch) 2 3 Red/White Horn 4 Blue/Pink Cruise (Cancel, Set/Coast, Resume/Accel resistor network) 5 Black/Blue Ground 6 7 8AT shift: 1 2 Violet/White Shift Up 3 4 5 6 7 Blue Shift Down 8 Black/Yellow Ground Audio SWCs: 1 2 Violet Illum+ 3 4 5 6 Orange/White SWC– 7 Violet/White SWC+ 8 Black/White Illum– (minus) [Added:] I've attached a PDF with pages showing connections to the various controls in the steering wheel (pages taken from the 2005 Legacy wiring diagrams). Errors/omissions/notes: On the page with the audio SWCs, the diagram omits the STx connectors (ST1 and ST2 or ST4). I included the page after that, which shows a drawing of the 5-pin connector inside the wheel.The "Satellite Switch" drawing erroneously labels the first button "POWER" instead of "MUTE," and is missing one more resistor from the ladder (pressing MUTE results in 22 ohms, not 0 ohms).The Audio System diagram shows only 2 of the 28 wires on bulkhead harness i1/B36.The page with the AT shift up/down buttons omits the label ST1 (B68 plugs into ST1). On cars that have the audio SWC wires in the "i85" harness (8-pin, at the radio): The SWC wires go from i85 to harness "i1" (pins 5 and 6). Bulkhead harness "B36" connects to "i1".B36 pins 5 (SWC+) and 6 (SWC–) go to harness B68 at the steering column.B68 plugs into ST1 (which connects to the stationary side of the roll connector). It's that second leg, from B36 to B68, which lacks the SWC wires on cars that have no audio buttons on the wheel. So if your i85 harness has the SWC wires, another place to connect to them is the empty pin locations on B36. If someone can post some good close-up pictures of i1 and B36, I may be able to find the correct pins to snap into B36. That would allow you to connect to the HU's SWC input by running new wires from B68 (at the steering column) to B36, instead of running all the way to the HU (and then having to tap into the SWC wires there). You would still need to find the two illumination/dimmer wires, but there should be many of those right behind the dash (since they're used by every control that has a backlight).2005 Legacy B68 clockspring SWCs.pdf Edited May 30, 2011 by SVXdc Added wiring diagrams PDF Link to comment Share on other sites More sharing options...
SATSFYD Posted August 28, 2009 Share Posted August 28, 2009 This is good stuff. I might have to do this to my 5EAT. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
phildog33 Posted September 11, 2009 Share Posted September 11, 2009 Im trying to put some SWC pods in my 2005 AT wagon and having some trouble with the wiring. http://www.legacygt.com/forums/showthread.php?t=118964 Can someone take a look at my pictures Thanks p Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 6, 2009 Share Posted October 6, 2009 Is there an option to have the AT shifters AND the radio controls, or is it one or the other? Any pics? Link to comment Share on other sites More sharing options...
natoli4 Posted March 15, 2010 Share Posted March 15, 2010 So I tried this weekend on my 07 outback and they don't work. I do have illumination but the buttons do nothing. Really bumbed out. Can anyone provide a clean wiring diagram? Seems like alit if patch work with this thread. I have an 5eat!!!! Link to comment Share on other sites More sharing options...
SVXdc Posted March 15, 2010 Share Posted March 15, 2010 Which radio do you have (model number printed on the front)? Search for "vacation pix". Link to comment Share on other sites More sharing options...
natoli4 Posted March 15, 2010 Share Posted March 15, 2010 I have a p-204UH Link to comment Share on other sites More sharing options...
natoli4 Posted March 15, 2010 Share Posted March 15, 2010 did a search for vacation pix...al long list of posts came up...what am I missing? Link to comment Share on other sites More sharing options...
Leonardo Posted March 16, 2010 Share Posted March 16, 2010 Is there an option to have the AT shifters AND the radio controls, or is it one or the other? Any pics? One or the other unless my idea of adding 08-09 paddle shifters somehow works. Might require a new clockspring (where the paddle assembly mounts) but not sure. Link to comment Share on other sites More sharing options...
SVXdc Posted March 16, 2010 Share Posted March 16, 2010 I have a p-204UH That model should work with SWCs (if connected properly). did a search for vacation pix...al long list of posts came up...what am I missing? You asked for a clean wiring diagram. Look for 2007 vacation pix (perhaps search in thread titles only). Check your wiring -- unplug the 8-pin i85 plug from your HU and use an ohm meter to measure across the two SWC pins there. You should see the various resistor values when you push the SWC buttons. No power required (ignition key can be completely off). Link to comment Share on other sites More sharing options...
natoli4 Posted March 16, 2010 Share Posted March 16, 2010 rodger that. I will rip it apart again this weekend. I just wanted to try and make sure that I tapped into the proper wires on BOTH ends as the wires. The one that comes down the steering column is a bit different on the 5eat. Anyone in the Los Angeles area do this to your 5eat P-204uh? Link to comment Share on other sites More sharing options...
natoli4 Posted March 23, 2010 Share Posted March 23, 2010 got it done. the wire ties were the problem. sucked. they didn't tap far enough into the wire. boooo! diagnosed it for a few hours last weekend. everything works great now! Thanks SVXdc Link to comment Share on other sites More sharing options...
winnipegsubaru Posted May 11, 2010 Share Posted May 11, 2010 Hey everyone, Where can I buy the radio controls and have them shipped to canada? Thanks Link to comment Share on other sites More sharing options...
winnipegsubaru Posted May 11, 2010 Share Posted May 11, 2010 Hey guys, I just ordered the parts from Subaru Online Parts . com.... So hopfully they will arrive quickly and I can see if I can get them to work with my after market radio. Thanks Link to comment Share on other sites More sharing options...
Leonardo Posted May 11, 2010 Share Posted May 11, 2010 Depends if you have the adapter that ties in the factory controls to the aftermarket radio. Saw it on Crutchfield.com Link to comment Share on other sites More sharing options...
natoli4 Posted May 11, 2010 Share Posted May 11, 2010 Local subaru dealership should be able to order them for you. P/N: 83153AG000 ($113 - $82 EST.) Link to comment Share on other sites More sharing options...
winnipegsubaru Posted May 12, 2010 Share Posted May 12, 2010 hey guys, I ended up ordering a set from 1stsubaruparts.com (hopfully they are a good site) Anyways, I also ordered from sonic electronix a PAC SWI-PS adapter to go into my Avic X710bt stereo So my question is, is there a way to hook all this up without splicing or cutting the stock wiring? Any help would be great. Thanks Link to comment Share on other sites More sharing options...
mcsquish Posted May 13, 2010 Share Posted May 13, 2010 So I have been MIA for some time, so sorry if I missed this question while I was reading the old posts. So I finally looked at the 2010 models (I got married 11 months ago........) and saw that they have radio and cruse buttons on the steering wheel now. Does anyone know if those, more importantly the radio button set, work and fit the '05 steering wheel? The shape and size looks right, but wondered if anyone has tried it yet. I have already done this mod and love it, just thinking this might be better to have all of the buttons in one area. Link to comment Share on other sites More sharing options...
