Deltaking Posted December 13, 2023 Share Posted December 13, 2023 Hi All, Does anyone know where I can get the 3d model of the Subaru Legacy GT B 2007 body? I want to 3D model and 3D print my own body kit... I find models of the newer Subaru but not the older ones Link to comment Share on other sites More sharing options...
KZJonny Posted December 13, 2023 Share Posted December 13, 2023 My gut feeling is: Nobody here is going to have that dude. The folks that may are using those scans to make parts and sell them, which is fair. See Madrig’s crazy 4th gen parts as an example. Link to comment Share on other sites More sharing options...
Infosecdad Posted December 13, 2023 Share Posted December 13, 2023 We had a 3D model thread around here somewhere, if I can find it I'll link it here. 1 Link to comment Share on other sites More sharing options...
Enlight Posted December 14, 2023 Share Posted December 14, 2023 I would check this aero thread: 1 1 muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
Deltaking Posted December 14, 2023 Author Share Posted December 14, 2023 Sweet many thanks they had the model there. I'm going to do some designs over the next few months as well as letters "Spec B" etc. There's a lot of other useful info there. Link to comment Share on other sites More sharing options...
Deltaking Posted December 14, 2023 Author Share Posted December 14, 2023 What I want to do a part from the kit is 3D model insight on the rear and headlights so I can put Led designs in them. So mount for Leds with custom shapes. I have seem the custom headlights and rear lights as well as the price with the stoke could do similar at less than 20% of the price. Luckily I have a big enough machine to cover those. For the kit I will probably just build up my big machine and 3d print them then take the machine apart again for spares lol Link to comment Share on other sites More sharing options...
Deltaking Posted December 18, 2023 Author Share Posted December 18, 2023 I have just drilled down on the free model... Sadly its not to scale.... While I continue to dig for that I'm busy designing other things... Like a replacement airbox drop in that can take a cone filter... The same design in the existing pipe where the MAF gets mount for the air flow and pipe diameter left the same... Thinking about it now as well one may be able to use the stock box and cutout the pipe section and just glue and tidy up the pipe being put into the stock box. But will see how far I get as next up is the front grill 1 Link to comment Share on other sites More sharing options...
Deltaking Posted December 18, 2023 Author Share Posted December 18, 2023 (edited) Spec B Badge and Key Ring https://www.thingiverse.com/thing:6383989 Intercooler to turbo seal (Can't find them locally replaced mine with 3D model below and works perfectly) https://www.thingiverse.com/thing:6381978 MAF mount Cone Filter (Double check your MAF mounting holes) https://www.thingiverse.com/thing:6384465/files Center Grill (Work in progress) https://www.thingiverse.com/thing:6387255 Top Intercooler protector https://www.thingiverse.com/thing:6549267 Turbo Inlet Hose https://www.thingiverse.com/thing:6570200/files Throttle body to intercooler Hose (Straight Hose with angle) https://www.thingiverse.com/thing:6570192 Intake Manifold to TGV O-Ring https://www.thingiverse.com/thing:6580019 Edited April 15 by Deltaking Added additional file Link to comment Share on other sites More sharing options...
Deltaking Posted December 19, 2023 Author Share Posted December 19, 2023 In progress, any chance someone has accurate dimensions for the front grill. Not sure how difficult it is to remove... Link to comment Share on other sites More sharing options...
Deltaking Posted December 19, 2023 Author Share Posted December 19, 2023 Progress update 3 Link to comment Share on other sites More sharing options...
Deltaking Posted December 20, 2023 Author Share Posted December 20, 2023 Progress Update 1 Link to comment Share on other sites More sharing options...
seanyb505 Posted December 22, 2023 Share Posted December 22, 2023 Nice progress! Any chance you would smooth the transition from the very front to the lip that runs the perimeter of the surround? Link to comment Share on other sites More sharing options...
Deltaking Posted December 22, 2023 Author Share Posted December 22, 2023 Are you talking about the front of the model? In the middle of the yellow highlighted area? I revised the grill which I'm going to double check measurements with the original. I was thinking that I may be able to print the grill in TPU 95A which would make it very easy to mount to the existing grill with epoxy. Link to comment Share on other sites More sharing options...
seanyb505 Posted December 23, 2023 Share Posted December 23, 2023 Yeah that's the area I was thinking. When you print are you printing the whole grill or just the honeycomb? If just a honeycomb insert then that lip won't matter. Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted December 23, 2023 Share Posted December 23, 2023 How big is your printer? The front grill is a big piece. I bough honeycomb material from customcargrills.com, they’ll also send you a sample. Most who have done this use weather strip to hide the line between the grill and the outer edge. Link to comment Share on other sites More sharing options...
Deltaking Posted December 23, 2023 Author Share Posted December 23, 2023 (edited) 5 hours ago, seanyb505 said: Yeah that's the area I was thinking. When you print are you printing the whole grill or just the honeycomb? If just a honeycomb insert then that lip won't matter. For testing only honeycombs. Want to check dimensions and positioning. Want to get this done so I can get to the side mirrors. Edited December 23, 2023 by Deltaking Link to comment Share on other sites More sharing options...
Deltaking Posted December 23, 2023 Author Share Posted December 23, 2023 4 hours ago, SoobyDoobyDoo said: How big is your printer? The front grill is a big piece. I bough honeycomb material from customcargrills.com, they’ll also send you a sample. Most who have done this use weather strip to hide the line between the grill and the outer edge. Big one that I switch on once in a while is 400x400x800mm. Normal day to day ones are 200 x 200 x 200 and the other 400 x 400 x 400 excluding the resin one Link to comment Share on other sites More sharing options...
Deltaking Posted January 2 Author Share Posted January 2 So created the Spec B badge as close to the original as possible from an image https://www.thingiverse.com/thing:6413396 2 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted January 3 Share Posted January 3 Looks good for modeling it from an image! Link to comment Share on other sites More sharing options...
Deltaking Posted March 23 Author Share Posted March 23 Anyone have the TGV 3D model by any chance... I was thinking that may end up deleting it and it could potentially just be 3D printed instead of bought or all the cutting... Link to comment Share on other sites More sharing options...
KZJonny Posted March 23 Share Posted March 23 5 hours ago, Deltaking said: Anyone have the TGV 3D model by any chance... I was thinking that may end up deleting it and it could potentially just be 3D printed instead of bought or all the cutting... Not from personal experience, but that of others here: There is a reason why you used to be able to find plastic/resin/composite TGVs on the market as a replacement for the aluminium ones, but no longer do. They weren't any good, and didn't stand up to the heat in the bay under hard use. Apparently even the thick phenolic spacers were not enough to keep them from warping and causing leaks. So, YMMV, but the general consensus is to either chop up and plug the holes in your OE TGVs, or get a set or tailor mades from your speed parts producer of choice. 1 1 Link to comment Share on other sites More sharing options...
Deltaking Posted March 24 Author Share Posted March 24 (edited) Does anyone know the dimensions or hole positions for the secondary air pump deletes (LGT 07) on the back of the engine for both plates by any chance? I want to 3D model them then cut them out in aluminum since I am going to do the TGV delete and remove IM. Edited March 24 by Deltaking Link to comment Share on other sites More sharing options...
Bobsyouruncl Posted March 25 Share Posted March 25 On 1/2/2024 at 10:35 AM, Deltaking said: So created the Spec B badge as close to the original as possible from an image https://www.thingiverse.com/thing:6413396 I have next to zero experience 3d printing. I'm wondering if this could be used to 3d print a new matte black badge for the rear of my car. Been looking for a while for black badging and found nothing Link to comment Share on other sites More sharing options...
Deltaking Posted March 25 Author Share Posted March 25 @Bobsyouruncl yup you can give the file to anyone with a 3d printer just tell them the colour you want it in. Petg would probably be a good material to 3D print in (PLA wouldn't last) Link to comment Share on other sites More sharing options...
Deltaking Posted March 25 Author Share Posted March 25 What you guys think about this? Its a Top intercooler protector? Link to comment Share on other sites More sharing options...
