Febreze Mee Posted April 30, 2023 Share Posted April 30, 2023 Thise are beautiful! Dimensions? MILKRUN - Click Here Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted April 30, 2023 Author Share Posted April 30, 2023 Just now, Febreze Mee said: Thise are beautiful! Dimensions? 18x9.5 +38 in 5x100 Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted May 5, 2023 Author Share Posted May 5, 2023 I did a little test fit yesterday to see the clearance for the strut. Looks like I need to be at about -2.5 degrees of front camber. The rears should be chilling with a roll. They are currently at about -2 degrees. I am planning on running a 255/35/ 1 Link to comment Share on other sites More sharing options...
Febreze Mee Posted May 5, 2023 Share Posted May 5, 2023 (edited) Mmm meaty. That's a lot of wheel/tire to work into our wells, but it will look great! Edited May 5, 2023 by Febreze Mee MILKRUN - Click Here Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted June 1, 2023 Author Share Posted June 1, 2023 Finally got the wheels on. I will be rolling the rear fenders tomorrow. Current tire size is a 245/35/18. 3 Link to comment Share on other sites More sharing options...
Febreze Mee Posted June 1, 2023 Share Posted June 1, 2023 Gorgeous!! MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Code Posted June 1, 2023 Share Posted June 1, 2023 Wheels look great but you’ve got A LOT of work to do in the rear. I ran a really wide tire on a higher offset and the rear always rubbed under full compression. Roll, pull, camber arms, etc. car looks great. How many miles? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted June 1, 2023 Author Share Posted June 1, 2023 I have about 118000 miles on the car. I'm still on the fence about buying rear camber arms. I was looking at some SPC ones. Link to comment Share on other sites More sharing options...
Code Posted June 1, 2023 Share Posted June 1, 2023 It’s unlikely that you’ll be able to tuck the rears without camber arms. Whiteline makes a good product. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted June 1, 2023 Author Share Posted June 1, 2023 20 minutes ago, Code said: It’s unlikely that you’ll be able to tuck the rears without camber arms. Whiteline makes a good product. Do you think I could get away with just camber arms and still have enough toe adjustment? Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted June 2, 2023 Author Share Posted June 2, 2023 Rolled and pulled the rears today. This is the first time I rolled fenders and I’d like to say it went smoothly because I got a quality fender roller. Aside from that, I want to match the front height but I might go ahead and get Whiteline arms and lock bolt. 3 Link to comment Share on other sites More sharing options...
cheeseenlo Posted June 2, 2023 Share Posted June 2, 2023 Wow, nice work with the fender rolling. 9.5" +35 looks tough. What size spacers did you use with the stock wheels? Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted June 2, 2023 Author Share Posted June 2, 2023 2 hours ago, cheeseenlo said: Wow, nice work with the fender rolling. 9.5" +35 looks tough. What size spacers did you use with the stock wheels? It’s a little higher offset actually. It’s a +38. For the stock wheels I was using a 1 inch spacer so about 25mm. 1 Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted June 14, 2023 Author Share Posted June 14, 2023 Whiteline arms and alignment were installed today! Had to raise the car slightly to have it not rub but overall I am satisfied with the height. One of the eccentric bolts was rusted into the bushing sleeve but I had the lockout kit (KCA307) to replace them anyways. This car isn't even rusty! It's from California and it still had a seized rear eccentric bolt. Anyways, the car does not rub. The ride quality has substantially improved. 5 Link to comment Share on other sites More sharing options...
Code Posted June 14, 2023 Share Posted June 14, 2023 Hell yea. Enjoy it! "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
legacybt Posted July 17, 2023 Share Posted July 17, 2023 Huge fan of that wheel/tire setup, looks great! Is there any rubbing on bumps during hard cornering? Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted July 17, 2023 Author Share Posted July 17, 2023 1 hour ago, legacybt said: Huge fan of that wheel/tire setup, looks great! Is there any rubbing on bumps during hard cornering? Just a tad. However on mostly normal flat roads it does not rub. I just finished my 2nd round of autocross. I had to borrow my friends tire waterer to keep heat down and not chunk the brand new tires. 3 Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted July 20, 2023 Author Share Posted July 20, 2023 Here are some more photos I had laying around! 4 Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted August 12, 2023 Author Share Posted August 12, 2023 Just put on a Cusco rear sway bar. I was wondering what endlinks people are running with a Cusco bar or anything similarly sized. I’m leaning more towards getting some solid kartboy endlinks. Link to comment Share on other sites More sharing options...
legacybt Posted August 12, 2023 Share Posted August 12, 2023 I’ve run Kartboy on my Whiteline setup for 10ish years without issue 1 2 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted August 15, 2023 Share Posted August 15, 2023 (edited) On 4/24/2023 at 10:49 AM, reallyfunnymoment said: Installed some Project Mu B-Spec brakes pads and some OEM rotors. Then I just did my first autocross event. Car performed perfectly with no issues. Had a fantastic time driving! Sorry I’m a little late to the party on this one how do those feel? Bought a set but stupid “Sub model” drop down didn’t have a “gt” option so ended up with 2.5i pads and my stupid self didn’t bother confirming the p/n… PS car looks fantastic! Edited August 15, 2023 by SoobyDoobyDoo Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted August 15, 2023 Author Share Posted August 15, 2023 3 hours ago, SoobyDoobyDoo said: Sorry I’m a little late to the party on this one how do those feel? Bought a set but stupid “Sub model” drop down didn’t have a “gt” option so ended up with 2.5i pads and my stupid self didn’t bother confirming the p/n… PS car looks fantastic! The pads feel great. The car stops infinitely better than the stock pads. I also haven't noticed a lot of brake dust either. I tried to get new brake pad shims but was only able to find one side of the front brake shims from Subaru. The right part numbers for the pads from Project Mu is F916 for the fronts and R912 for the rears. 2 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted August 16, 2023 Share Posted August 16, 2023 (edited) If you want, I might have some shims laying around…need to check. I bought some but need to make sure they’re correct. Pads I ended up putting on the car queasy came with them.. Edited August 16, 2023 by SoobyDoobyDoo Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted August 18, 2023 Author Share Posted August 18, 2023 17 hours ago, SoobyDoobyDoo said: If you want, I might have some shims laying around…need to check. I bought some but need to make sure they’re correct. Pads I ended up putting on the car queasy came with them.. It's fine. I'll just grab the rock auto ones next time I need to change the pads. Link to comment Share on other sites More sharing options...
reallyfunnymoment Posted August 23, 2023 Author Share Posted August 23, 2023 Final product of installing the new Cusco RSB and Whiteline endlinks. Car handles phenomenally now. I just need it to rain to really test the grip of the car. 4 Link to comment Share on other sites More sharing options...
