kzr750r1 Posted May 24, 2022 Author Share Posted May 24, 2022 A couple of Company 32 tools showed up. 13mm diff plug socket and 5 point socket for the AVC Pully HW. Will be probably just buying all new pulleys. Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 24, 2022 Author Share Posted May 24, 2022 Well... Unlike last time the shop is ready to deliver. Luckily I have family near them and headed my way this week. So pickup and delivery before the end of the week. SB done. Heads refreshed. Full gasket kit provided. Need to get this other orders finished for the rest of the peripherals. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2022 Share Posted May 24, 2022 That's good progress. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 25, 2022 Author Share Posted May 25, 2022 (edited) Heuberger Subaru - Most all the hoses, OCVS, New ACV pullys, intake ect... FastWRX - OEM quality belt kit. Rally Sport Direct - New Water pump. Cast impeller version. ORDEREDÂ Next on the list is: Oil Pump - Will probably go with one from Outfront motor sports. 11 or 12mm. Shop that built the SB and heads said they prefer the JDM 12mm. Oil Pan - Will be Killer B but what one??? Calling them back as I received not call back today. Windage Tray - Killer B Oil pan HW kit for the pan and pickup. Edited May 25, 2022 by kzr750r1 Link to comment Share on other sites More sharing options...
whitexc Posted May 25, 2022 Share Posted May 25, 2022 Oil cooler? Didn't see it listed unless I skipped by it.... Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 25, 2022 Author Share Posted May 25, 2022 Part of the Heuberger order. Thanks for looking out for me. One item I missed was a new EGT sensor. Is there a more robust after market unit out there? Will need it now that COBB is green. Link to comment Share on other sites More sharing options...
JoeInOregon Posted May 25, 2022 Share Posted May 25, 2022 Part of the Heuberger order. Thanks for looking out for me.   One item I missed was a new EGT sensor. Is there a more robust after market unit out there? Will need it now that COBB is green. A resistor is a lot cheaper Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 25, 2022 Author Share Posted May 25, 2022 Yes but would be nice to have the safety there too. But I've killed one already with a gutted up. If I remember correctly the resistor (have one on an old EGT harness) tells the ECU it's 1350 degrees always. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 25, 2022 Share Posted May 25, 2022 Don't remember if I saw it in your shopping list, cylinder 4 cooling mod? Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 25, 2022 Author Share Posted May 25, 2022 Yes... GetaDom mod has been ordered already. He was happy I let him know they were not in stock on his website. Soon as I found his email suddenly there were 19 available in the store. Again thanks for checking I'm on the right path. Link to comment Share on other sites More sharing options...
JoeInOregon Posted May 25, 2022 Share Posted May 25, 2022 Yes but would be nice to have the safety there too. But I've killed one already with a gutted up. If I remember correctly the resistor (have one on an old EGT harness) tells the ECU it's 1350 degrees always.Probably safer that shooting cooked bits of an egt sensor into your turbo, the general consensus seem to be a egt is a bad idea with an open up pipe Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
JoeInOregon Posted May 25, 2022 Share Posted May 25, 2022 I would block it with a short bolt, I bought a 5 pack of resistors, let me know if you need one Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 25, 2022 Author Share Posted May 25, 2022 Probably safer that shooting cooked bits of an egt sensor into your turbo, the general consensus seem to be a egt is a bad idea with an open up pipe Sent from my Pixel 3a using Tapatalk Agreed. Understood. Need to discuss with Travis (Snail) but I'm not that close yet. Just figured to ask here if anyone has been creative with alternatives. Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 25, 2022 Author Share Posted May 25, 2022 Killer B conversation was a good one. Pan ordered with windage tray. Will be happy to put more oil in the mix. Conversation moved to oil pump size and their findings is what has been out there for a while. No need for a larger pump. After 85psi it's going thru the filter bypass. Word of warning is to take it apart. Clean the internals. Pack with assembly lube and torque the housing to spec. They have seen OEM pumps delivered loose and dirty. Will be ordering a 10mm pump for this build. It's a street car. Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 26, 2022 Author Share Posted May 26, 2022 JMP Custom VF40 incoming! Thankyou Sir! Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 31, 2022 Author Share Posted May 31, 2022 Just ordered a new 10mm oil pump. Parts are starting to arrive. Once this pump arrives I'll get on it. Car covered for now and garage cleaned up. Ran the head stud HW through the ultrasonic cleaner. Need to get my air compressor back in service. Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 2, 2022 Author Share Posted June 2, 2022 (edited) Nice to have the parts rolling in. Shout out to JMP for the spectacular custom VF40! Edited June 2, 2022 by kzr750r1 Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 7, 2022 Author Share Posted June 7, 2022 Parts still rolling in. Found some other items needed. Have plenty to start the rebuild by this weekend. Chipping away at it. Doing some upgrades on the ZRX in the meantime. New SS 4/1 pipe. 2.5 Rejet for Mo Flow filter w/airbox. New clutch frictions and springs. New Battery Tray Mod. Swapping hose clamps to Samco sleeved units since one kept fighting me with coolant spittle. Needed to be sure no other leaking and for sure it's just the one spot. Link to comment Share on other sites More sharing options...
leetdrv Posted June 7, 2022 Share Posted June 7, 2022 Hey Sean, any recommendations for a car cover? I see you have a nice one there! GL with the build! Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 7, 2022 Author Share Posted June 7, 2022 Went to carcovers.com. What you see is the $180 unit. Ships out of Canada, nice unit. Rained here Sunday morning. Noticed water beading up on it while opening up the garage that morning. Link to comment Share on other sites More sharing options...
leetdrv Posted June 7, 2022 Share Posted June 7, 2022 Ordered, Thanks for the tip! Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 10, 2022 Author Share Posted June 10, 2022 Oil pump arrived at my doorstep. Confirmed with oring seal to the case. So no waiting any longer. Time to build this long block! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 10, 2022 Share Posted June 10, 2022 Then hurry up already! I want to see this thing. Must be so shinaay.   :spin: Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 13, 2022 Author Share Posted June 13, 2022 Heads on. Took a couple pics. Stalled at the moment. One exhaust cam is turning with some resistance after torqued. Other three feel smooth. No burrs or other issues found so far. Will swap exhaust cams tonight and see of they feel better. Turned to the oil pickup install and found KillerB didn't provide two in the hardware kit for some reason. Not putting this back together with a vulcanized flat oring in the suction stack. Would work like a cracked straw. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 13, 2022 Share Posted June 13, 2022 I hate when this happens (i.e. beginning working on installing parts only to find out a couple of things are missing in the kit) Link to comment Share on other sites More sharing options...
