Jolbaru_LGT Posted August 11, 2021 Share Posted August 11, 2021 (edited) So, when taking off the transmission, I noticed a crusty ol coolant hose under the turbo. Since I don't know when I'll ever get to this again, it's gotta be changed. Anyone have any experience with this? Do I need to drain the coolant and take off the turbo to get at it? It really looks like it's going to fail and I've got the parts ready, I just need some advice. Thanks! Edited August 11, 2021 by Jolbaru_LGT Link to comment Share on other sites More sharing options...
amm203 Posted August 11, 2021 Share Posted August 11, 2021 If I'm seeing the photo correctly, I believe that is your oil return hose and not related to the coolant. Coolant hose is that "U"-shaped hose near the top-left of your parts diagram. It's usually covered in a foil-like material. Link for replacement oil return hose and spring clamps: https://www.fastwrx.com/products/turbo-oil-return-line-hose-to-head Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 11, 2021 Author Share Posted August 11, 2021 Ok, for some reason I thought it was coolant. Any good advice on getting at it? Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 11, 2021 Author Share Posted August 11, 2021 If I'm seeing the photo correctly, I believe that is your oil return hose and not related to the coolant. Coolant hose is that "U"-shaped hose near the top-left of your parts diagram. It's usually covered in a foil-like material. Link for replacement oil return hose and spring clamps: https://www.fastwrx.com/products/turbo-oil-return-line-hose-to-head Funny, the spring clips in that link are what Subaru recommends for only the bottom of it, for the top there's a thicker hose clamp they recommend. And I got all that from the dealership, the hose, hose clamp and spring clip. Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 11, 2021 Share Posted August 11, 2021 Pull the turbo, no other way you're getting at it that would be anywhere near as easy. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 11, 2021 Share Posted August 11, 2021 Has the filter from the banjo bolt been removed ? if not, now would be a good time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JoeInOregon Posted August 12, 2021 Share Posted August 12, 2021 From what I have ready replacement of that hose is one of the trickiest bits of a turbo swap also, I have seen long pliers , finness and patience recommend highly...good luck Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 12, 2021 Author Share Posted August 12, 2021 Has the filter from the banjo bolt been removed ? if not, now would be a good time. I replaced that one 30,000 miles ago. I plan on changing both every time I do the timing belt. I just don't feel comfortable deleting it. I might change my mind about deleting the one behind the timing belt cover, but I've got some time to decide. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 12, 2021 Author Share Posted August 12, 2021 Pull the turbo, no other way you're getting at it that would be anywhere near as easy. Yeah, you're telling me! I struggled and swore, used too much silicone spray, but I got it. Hopefully there won't be a next time, but I suppose if I ever replace/upgrade the turbo, I'll replace that then as well.. Definitely would have been easier removing the turbo. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 12, 2021 Author Share Posted August 12, 2021 From what I have ready replacement of that hose is one of the trickiest bits of a turbo swap also, I have seen long pliers , finness and patience recommend highly...good luck Sent from my Pixel 3a using Tapatalk The rubber tube went on fairly decent, I got the top in first and then bent and twisted the lower part on, with the clips in the middle. Then, putting the clips in place.. The bottom clip wasn't that horrible, I zip tied it together and it slid down and over the metal return tube, then I obviously cut the zip tie. The upper part(hose clamp) was the REAL bugger. That one, I swore way too much and almost freaked out trying to get it where it needed to be. In the end, it took super long extended reach needle nose pliers and a beefy metal hanger I typically use for holding up brake calipers. I had to actually shape a tool of sorts with that to pull the clip in and sneak it close enough to grab both tabs with the pliers. Once I had the two spring clip tabs secure with the pliers up as far as I could, only then could I blast a little more silicone spray and weasel it over the metal tube. Once it was finally on, and I was sure about it, could I then use a flat head screwdriver to twist it up into place. But there's no room to work in there, and you can only see it from below, with the transmission out. I couldn't get at it from the side, above or anything. Never really thought that was going to be one of the hardest part of the whole clutch job. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 12, 2021 Author Share Posted August 12, 2021 (edited) Honestly tho, I've got a lot to learn about these cars if I really thought that hose was coolant. Guess I was so used to replacing so many random coolant hoses around the engine, that that's what I thought it was. I didn't give much thought to why there'd be coolant going into the turbo. Thank you amm203 for correcting me, that actually gave me more courage to tackle it. But honestly, I would gladly wait another 257,000 miles before doing that job again. Edited August 12, 2021 by Jolbaru_LGT Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 12, 2021 Share Posted August 12, 2021 Coolant does go into the turbo as well, just not from that hose. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 12, 2021 Author Share Posted August 12, 2021 (edited) Coolant does go into the turbo as well, just not from that hose. right. I do remember replacing those now that I think about it. One of the first hoses I replaced, just a bloated, leaking hose, connecting coolant to the turbo. I also remember that metal tube being very white and crusty. I really try to do the best I can replacing everything I see that's nasty. Only to find out what it is later on.. Here's the new one. Edited August 12, 2021 by Jolbaru_LGT Link to comment Share on other sites More sharing options...
amm203 Posted August 12, 2021 Share Posted August 12, 2021 Glad everything went well! Thank you for updating us on the results/method! I may have to tackle this soon myself Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted August 12, 2021 Author Share Posted August 12, 2021 Yeah, long reach needle nose pliers worked great. Maybe long reach bent nose would work well too? Hard to say because I didn’t have one on hand. I wished I could have had that clip pre tensioned that you release like some are from Subaru. But being a return hose, maybe you would only need two of the thin wire spring clips? I’m not sure, I usually tend to do what the factory originally intended. Link to comment Share on other sites More sharing options...
