dgoodhue Posted July 19, 2021 Share Posted July 19, 2021 While you have the starter out, pull it apart and regrease it. My OB made noise when I bought it with 113k miles, my '12 GT started making noise at that mileage and my '11 GT made noise at 126k. It is an easy fix. I don't know if my 2010GT makes noise but I will proactively regrease it before I install as well. Link to comment Share on other sites More sharing options...
Falcor Posted July 20, 2021 Author Share Posted July 20, 2021 While you have the starter out, pull it apart and regrease it. My OB made noise when I bought it with 113k miles, my '12 GT started making noise at that mileage and my '11 GT made noise at 126k. It is an easy fix. I don't know if my 2010GT makes noise but I will proactively regrease it before I install as well. I greased both the 2010 Outback and the GT. The Outback had an extended warranty so had it replaced. Pulled the GT starter twice to grease I believe. Those things need a grease fitting. [emoji1] Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted July 23, 2021 Share Posted July 23, 2021 Headgaskets seem to be hit or miss as are exhaust valve issues. I am at 99k miles with stage 2 tune the last 39k/4 years I am planning out my timing belt for this fall and plan to do the clutch/cylinder heads/ARP studs/headgaskets all at the same time. At this point I may hold out for a built short block, Link to comment Share on other sites More sharing options...
DrD123 Posted July 23, 2021 Share Posted July 23, 2021 Headgaskets seem to be hit or miss as are exhaust valve issues. I am at 99k miles with stage 2 tune the last 39k/4 years I am planning out my timing belt for this fall and plan to do the clutch/cylinder heads/ARP studs/headgaskets all at the same time. At this point I may hold out for a built short block, Just going to say that's taking "well, while I'm in there I might as well replace..." to a whole new level! Link to comment Share on other sites More sharing options...
Falcor Posted July 23, 2021 Author Share Posted July 23, 2021 Just going to say that's taking "well, while I'm in there I might as well replace..." to a whole new level! Link to comment Share on other sites More sharing options...
Falcor Posted July 23, 2021 Author Share Posted July 23, 2021 It will be a few months before I'll be able to do the work. Moving to a new town and not having much furniture will do that. Link to comment Share on other sites More sharing options...
creep_nu Posted July 23, 2021 Share Posted July 23, 2021 or is that the perfect time to do it? kitchen engine rebuild! Link to comment Share on other sites More sharing options...
FLlegacy Posted July 23, 2021 Share Posted July 23, 2021 Just going to say that's taking "well, while I'm in there I might as well replace..." to a whole new level! It was really to mitigate time constraints, head rebuild/resurface would have taken a week or better in my area so it seemed prudent to just have a set ready to go back on. The short block would definitely be an overshoot at this point, or not....lol Link to comment Share on other sites More sharing options...
Blizzard Posted August 4, 2021 Share Posted August 4, 2021 $1350 sounds like fairly standard dealer pricing. I had mine done a month back or so by a trusted independent. With labor, parts and tax I think it was around $1,050. Link to comment Share on other sites More sharing options...
SpaceKiwi Posted August 15, 2021 Share Posted August 15, 2021 Mine is going to get the clutch done in a couple of weeks. The cost at an official Subaru dealer is about 145,000yen to get it all replaced. Link to comment Share on other sites More sharing options...
Falcor Posted August 15, 2021 Author Share Posted August 15, 2021 That’s around $1,323 usd at the moment. So I was about right in figuring it would be around $2,500 to have an independent shop do all the work. Of course, that does not include the larger FSB, and heavy duty shift fork and pivot ball. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Falcor Posted September 1, 2021 Author Share Posted September 1, 2021 No change yet on when the work will be done, but I called a local import shop (only one in this small town) and he kinda confirmed what I thought about the $2,500 price range. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
Falcor Posted June 13, 2023 Author Share Posted June 13, 2023 Boy does time fly. I'm finally ordering all the parts tonight and having the local import (euro) shop do the work. The guy is not afraid to try something new. Right now he has an old 80's 911 he is doing an engine swap on and a 20 or so year old Jag coupe that he is swapping a LS 350 into. He has done a few Subaru's before so feel pretty good about him working on mine. Link to comment Share on other sites More sharing options...
Falcor Posted June 15, 2023 Author Share Posted June 15, 2023 Parts started trickling in today. Link to comment Share on other sites More sharing options...
Scubaboo Posted June 15, 2023 Share Posted June 15, 2023 Who/where did you end up getting parts from? Link to comment Share on other sites More sharing options...
Falcor Posted June 16, 2023 Author Share Posted June 16, 2023 3 hours ago, Scubaboo said: Who/where did you end up getting parts from? Rockauto - Exedy OEM clutch and flywheel Import Image Racing - PDM TSK3 Snout kit, Verus billet clutch fork pivot, Verus Forged clutch fork Six Star Bernie - OEM timing belt kit Heuberger - OEM water pump, all new flywheel and pressure plate bolts, all new clutch fork springs, clutch fork boot, rear main seal (just in case), and MY13/14 26mm front sway bar w/bushings I know the HD clutch fork was a bit overkill on a stock clutch, but I never want to hear that squeaky barn door sound again Link to comment Share on other sites More sharing options...
Scubaboo Posted June 16, 2023 Share Posted June 16, 2023 9 hours ago, Falcor said: Rockauto - Exedy OEM clutch and flywheel Import Image Racing - PDM TSK3 Snout kit, Verus billet clutch fork pivot, Verus Forged clutch fork Six Star Bernie - OEM timing belt kit Heuberger - OEM water pump, all new flywheel and pressure plate bolts, all new clutch fork springs, clutch fork boot, rear main seal (just in case), and MY13/14 26mm front sway bar w/bushings I know the HD clutch fork was a bit overkill on a stock clutch, but I never want to hear that squeaky barn door sound again I couldnt relate...we only ever had auto GT's here lol! I'm in the same boat as you, got a bunch of parts from Six Star Bernie, and a whole lot from the local dealer too. Now to find time to get it installed! Link to comment Share on other sites More sharing options...
Falcor Posted June 16, 2023 Author Share Posted June 16, 2023 1 hour ago, Scubaboo said: I couldnt relate...we only ever had auto GT's here lol! I'm in the same boat as you, got a bunch of parts from Six Star Bernie, and a whole lot from the local dealer too. Now to find time to get it installed! But you guys got the wagon, so that kinda makes us even. 1 Link to comment Share on other sites More sharing options...
DrD123 Posted June 16, 2023 Share Posted June 16, 2023 11 hours ago, Falcor said: Import Image Racing - PDM TSK3 Snout kit, Verus billet clutch fork pivot, Verus Forged clutch fork Is the snout damaged on the case, or is the repair kit a just in case sort of thing? I went with the 6 star bernie kit when I did my timing belt a little while back - opted not to do the water pump at the time (only 75k miles and I didn't feel like pulling the exhaust manifold) - few things I would add to the parts - the o-rings for the drivers side cams (the covers have to come off to access the bolts) and a thermostat. If the folks doing the work haven't done this before, I'd recommend a cam lock tool for the drivers side cams (makes getting the belt on/aligned a whole lot easier) Opting to do the swaybar is a great idea! I did that when the engine was out for a spun bearing (25k miles ago) - it makes a nice improvement in body roll. Link to comment Share on other sites More sharing options...
Falcor Posted June 16, 2023 Author Share Posted June 16, 2023 Didn't think about the thermostat or o-rings. Looks like another order is going to be made. As far as the snout kit, it is really only if there is any damage to the snout. If it all looks good, I will probably send it back. The guy has done Subaru's before and he did have some Company23 tools hanging on the wall. Link to comment Share on other sites More sharing options...
Falcor Posted June 16, 2023 Author Share Posted June 16, 2023 Can anyone confirm these PN's?: Thermostat - 21210AA160 O-Rings - (top) 806939040 - (bottom) 806969020 https://parts.bestbuysubaru.com/a/Subaru_2011_Legacy-25L-TURBO-6MT-4WD-GT-Limited-Sedan/49287751__6022766/CAMSHAFT--TIMING-BELT-CAMSHAFT-10MY-12MY/B14-013-03.html Link to comment Share on other sites More sharing options...
DrD123 Posted June 16, 2023 Share Posted June 16, 2023 (edited) Those look correct on the diagram (looking at parts.subaru.com which I am sure looks identical to what is on the Heuberger site (I buy from them all the time - they are right up in the colorado springs area) I remember it was a bear to find someone with the thermostat in stock when I was getting mine Edited June 16, 2023 by DrD123 Link to comment Share on other sites More sharing options...
Scubaboo Posted June 16, 2023 Share Posted June 16, 2023 6 hours ago, Falcor said: Can anyone confirm these PN's?: Thermostat - 21210AA160 O-Rings - (top) 806939040 - (bottom) 806969020 https://parts.bestbuysubaru.com/a/Subaru_2011_Legacy-25L-TURBO-6MT-4WD-GT-Limited-Sedan/49287751__6022766/CAMSHAFT--TIMING-BELT-CAMSHAFT-10MY-12MY/B14-013-03.html Cant help you with the OE 'stat part number, but if you happen to be so inclined I know the lower temp STI thermostat fits, I put that in mine. You will also want a thermostat gasket with your new 'stat whether you go OE or STI. Link to comment Share on other sites More sharing options...
Falcor Posted June 16, 2023 Author Share Posted June 16, 2023 1 hour ago, Scubaboo said: Cant help you with the OE 'stat part number, but if you happen to be so inclined I know the lower temp STI thermostat fits, I put that in mine. You will also want a thermostat gasket with your new 'stat whether you go OE or STI. Did you see a benefit of using the STI thermostat? Link to comment Share on other sites More sharing options...
DrD123 Posted June 16, 2023 Share Posted June 16, 2023 21210AA160 is with the gasket and 21200AA230 is without the gasket (I have always wondered why Subaru does that) - the gasket itself (if you were to buy it separately) is 21236AA010 Does the STi thermostat flow better or something? At least for USDM MY12, both the STi and Legacy GT thermostats are fully open at 91C (F) but the STi one does start opening at a lower temperature (76-80C vs. 82-86C) but they have the same lift and bore. The one for the 2.5i is different, though - it is fully open at 95C and starts to open at 86-90C 1 1 Link to comment Share on other sites More sharing options...
