ex-Treadhead Posted February 20, 2020 Share Posted February 20, 2020 I have been looking at various manufacturers bars, and they all pretty much state GT only, mine is an I Limited. Is there a physical difference in the bar, is it the chassis mount clamps that are the problem or end links? Link to comment Share on other sites More sharing options...
Osei Posted February 20, 2020 Share Posted February 20, 2020 The GT bars will fit the I, but not the other way around. GT bars are cut to miss the turbo crossmember. O. Link to comment Share on other sites More sharing options...
Nonamedude Posted February 20, 2020 Share Posted February 20, 2020 The GT bars will fit the I, but not the other way around. GT bars are cut to miss the turbo crossmember. O. That's only the front bar though correct? Rear bars are the same? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
NORULZleggy Posted February 20, 2020 Share Posted February 20, 2020 Rears are the same Link to comment Share on other sites More sharing options...
Febreze Mee Posted February 21, 2020 Share Posted February 21, 2020 Next question would be, are the 3.0Rs different from the GT/XTs, BL/BPs? MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Nonamedude Posted February 21, 2020 Share Posted February 21, 2020 Yea I think they are. There was a 3.0 sway bar for sale for a while and it was stated that it only worked for the 3.0. I think it was a rear? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Osei Posted February 21, 2020 Share Posted February 21, 2020 The only caveat is that a sedan rear will not fit a wagon rear. IIRC the Tribeca rears would fit also, but they are 27mm, so unless you upped the front you would have massive oversteer. O. Link to comment Share on other sites More sharing options...
Febreze Mee Posted February 22, 2020 Share Posted February 22, 2020 Yea I think they are. There was a 3.0 sway bar for sale for a while and it was stated that it only worked for the 3.0. I think it was a rear? I think I remember seeing that which is what prompted the question. Thanks! Sent from my iPhone using Tapatalk The only caveat is that a sedan rear will not fit a wagon rear. IIRC the Tribeca rears would fit also, but they are 27mm, so unless you upped the front you would have massive oversteer. O. Facts! 27 is HUGE:spin: And to clarify, you are stating all sedan RSBs are not compatible with wagons RSBs, correct? MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Osei Posted February 22, 2020 Share Posted February 22, 2020 Correct. The wagon sways are bent to clear the spare tire area. O. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 24, 2020 Share Posted February 24, 2020 I don't know about that info. Wagon and sedan sway bars are the same I thought, f&r. Different btw NA and FI though. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Chocoholic005 Posted February 24, 2020 Share Posted February 24, 2020 I don't know about that info. Wagon and sedan sway bars are the same I thought, f&r. Different btw NA and FI though. I believe you are correct. Link to comment Share on other sites More sharing options...
Osei Posted February 24, 2020 Share Posted February 24, 2020 Thanks for the correction. O. Link to comment Share on other sites More sharing options...
