DaveWaters Posted August 10, 2019 Share Posted August 10, 2019 (edited) AEM 50-1215 is completely drop in.. no mods necessary. No crimping wires. Plugs right in. Use the existing plastic spacer at the top of the oem pump and 2 orings. No matter which pump you use, while you’re in there you may want to replace the fuel filter. It does cost about $70 but being that it’s half the bucket, now’s the time to do it. I used a sock bought from rock auto that fits just like the oem. I’ll see if I can dig up the part# for you. The one that comes with the AEM is kinda large and will fold up on the sides. You may also want to reinforce the voltage to the pump. There is a thread about that on here somewhere. Read the whole thread though because there is an alternate wiring toward the end to keep from draining the battery over time. I didn’t wire mine to avoid draining of the battery but it takes about a week or more of sitting to drain to the point of a dead battery. Edited August 10, 2019 by DaveWaters Link to comment Share on other sites More sharing options...
DaveWaters Posted August 11, 2019 Share Posted August 11, 2019 Here’s the pump wiring thread https://legacygt.com/forums/showthread.php/upgrading-your-fuel-pump-wiring-4th-gen-213570.html Here’s the sock thread https://legacygt.com/forums/showthread.php/replacement-fuel-pump-strainer-part-number-found-260452.html Link to comment Share on other sites More sharing options...
Tehnation Posted August 11, 2019 Share Posted August 11, 2019 why did I have to read about this pump wiring nonsens..... another thing to add to the list of crap to do..... this looks annoying lol Link to comment Share on other sites More sharing options...
Tehnation Posted August 13, 2019 Share Posted August 13, 2019 Ebay is your friend here. So i bought this, part number 14047AA700, or thats what they are saying it is... what part did you cut? I don't see how it lines up? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 13, 2019 Share Posted August 13, 2019 So i bought this, part number 14047AA700, or thats what they are saying it is... what part did you cut? I don't see how it lines up? [ATTACH]278300[/ATTACH]The bottom two holes align with the two bottom fuel rail bolts on the tgv. The rear hole aligns to the rear fuel rail bolt on the tgv. I cut about an inch past the coolant tank bolt hole. Link to comment Share on other sites More sharing options...
Tehnation Posted August 13, 2019 Share Posted August 13, 2019 my coolant tank bolt doesn't seem to be the right angle. Am I missing a piece? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 14, 2019 Share Posted August 14, 2019 my coolant tank bolt doesn't seem to be the right angle. Am I missing a piece?Do you have top feed fuel rails and top feed tgvs? Link to comment Share on other sites More sharing options...
SageAbkatsor Posted August 14, 2019 Author Share Posted August 14, 2019 (edited) The bottom two holes align with the two bottom fuel rail bolts on the tgv. The rear hole aligns to the rear fuel rail bolt on the tgv. I cut about an inch past the coolant tank bolt hole. my coolant tank bolt doesn't seem to be the right angle. Am I missing a piece? Mine looks very different from yours... Idk, I think he got the wrong part... Or I got the wrong part. Look at mine vs his: Clearly very different parts. Ultimately I still dont think either piece would do me any good. I have aftermarket side feed TGV deletes with top feed conversion rails. I have no provisions in the new TGVs for any of the brackets to use those bottom holes. Which is why I still don't understand fully the need for this other bracket if those holes are used. Those holes are in the exact same location as the smaller bracket that my car came with. Aren't they? Tehnation, you did your top feed conversion with the later model top feed TGVs, right? What does the normal expansion tank bracket do for you? Why does that one not work? Would love to see more pictures of what you are working with. Ill take some pictures of my dilemma tomorrow. Edited August 14, 2019 by SageAbkatsor Link to comment Share on other sites More sharing options...
Tehnation Posted August 14, 2019 Share Posted August 14, 2019 Do you have top feed fuel rails and top feed tgvs? yep, I have tgv deletes, top feed, with top feed injectors. Link to comment Share on other sites More sharing options...
Tehnation Posted August 14, 2019 Share Posted August 14, 2019 (edited) what was your part number? I have the right piece for part number 14047AA700. I googled it and found pictures of exactly what I have. Edited August 14, 2019 by Tehnation Link to comment Share on other sites More sharing options...
SageAbkatsor Posted August 14, 2019 Author Share Posted August 14, 2019 The bottom two holes align with the two bottom fuel rail bolts on the tgv. The rear hole aligns to the rear fuel rail bolt on the tgv. I cut about an inch past the coolant tank bolt hole. what was your part number? I have the right piece for part number 14047AA700. I googled it and found pictures of exactly what I have. Yeah I think you got the correct part for that part number. Honestly that's what I searched in ebay so that is what I thought I had but clearly found something else. My original listing does not show a part number, but it says it is for an 02-05 WRX... I think I am probably just an idiot. But hey maybe this is what you actually need. From what I can tell, the part number is 14047AA264. I would see if you can double check what Rhino is telling you before you go buy this thing though. I just confirmed the AA700 is what is on the later top feed LGTs. I am just special... Link to comment Share on other sites More sharing options...
rhino6303 Posted August 14, 2019 Share Posted August 14, 2019 The bracket tehnation has is exactly the same as the one I used. Link to comment Share on other sites More sharing options...
Tehnation Posted August 14, 2019 Share Posted August 14, 2019 I must be missing a piece... cause the bottom hole for the reservoir is horizontal and the hole on the bracket is vertical. I need a right angle bracket somewhere.. Link to comment Share on other sites More sharing options...
Tehnation Posted August 14, 2019 Share Posted August 14, 2019 I ordered both so we will see lol! Link to comment Share on other sites More sharing options...
rhino6303 Posted August 14, 2019 Share Posted August 14, 2019 I must be missing a piece... cause the bottom hole for the reservoir is horizontal and the hole on the bracket is vertical. I need a right angle bracket somewhere..Please post a picture of your setup. Thanks. Link to comment Share on other sites More sharing options...
Tehnation Posted August 15, 2019 Share Posted August 15, 2019 Link to comment Share on other sites More sharing options...
rhino6303 Posted August 15, 2019 Share Posted August 15, 2019 [attach]278354[/attach] [attach]278355[/attach] [attach]278356[/attach] [attach]278357[/attach] [attach]278358[/attach]That is exactly like mine. How are you trying to install the bracket? As noted, you need to cut the bracket just past where the tank bolts on. You need to remove the coolant tank and unbolt the fuel rail to install the bracket. Link to comment Share on other sites More sharing options...
SageAbkatsor Posted September 4, 2019 Author Share Posted September 4, 2019 (edited) AEM 50-1215 is completely drop in.. no mods necessary. No crimping wires. Plugs right in. Use the existing plastic spacer at the top of the oem pump and 2 orings. No matter which pump you use, while you’re in there you may want to replace the fuel filter. It does cost about $70 but being that it’s half the bucket, now’s the time to do it. I used a sock bought from rock auto that fits just like the oem. I’ll see if I can dig up the part# for you. The one that comes with the AEM is kinda large and will fold up on the sides. You may also want to reinforce the voltage to the pump. There is a thread about that on here somewhere. Read the whole thread though because there is an alternate wiring toward the end to keep from draining the battery over time. I didn’t wire mine to avoid draining of the battery but it takes about a week or more of sitting to drain to the point of a dead battery. Installing fuel pump today. Wish I had gone the AEM route, but also kinda glad I went Aeromotive. This is not plug and play lol. I called Aeromotive and they said that this is the correct way to make an E85 pump though as the submerged connector creates electrolysis in E85. In regular gas that is fine to have that connector submerged but not in E85. This is why Aeromotive uses bonded wires... Now the question is commit and hard wire my pump, or bail and sell this and get the AEM. I know the recommendation from everyone here is to go AEM, and AEM says E85 compatible, but I do believe what Aeromotive is saying about electrolysis. The only thing is... I am not running E85... while I plan to in the future, that may be a ways out yet. EDIT: ordered the AEM pump last night... Edited September 6, 2019 by SageAbkatsor Link to comment Share on other sites More sharing options...
