cww516 Posted December 3, 2018 Share Posted December 3, 2018 Assuming you have one of those little USB C to micro USB adapters, USB OTG adapters are probably easier to come by than USB C male to USB A female cables. They're pretty cheap on Amazon, I picked up a pair for about $7, IIRC. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 4, 2018 Author Share Posted December 4, 2018 OK I checked for vacuum leaks and I could not hear any...next step bottle of brake clean and I am going to spray the intake manifold around where it mates to each head...I am guessing leak when cold that seals as engine warms up Link to comment Share on other sites More sharing options...
nads Posted December 4, 2018 Share Posted December 4, 2018 OK I checked for vacuum leaks and I could not hear any...next step bottle of brake clean and I am going to spray the intake manifold around where it mates to each head...I am guessing leak when cold that seals as engine warms up You likely won't hear a vacuum leak unless there is a whistle on it. A vacuum gauge is handy post throttle body. I've used starting fluid to find them but typically I remove and plug lines to isolate issues, but that's on older cars with fewer vacuum lines. Vacuum will be highest at warm idle and you should be pulling a solid 21". If the needle is fluctuating something is out of balance. If its solid but low like 19" or less, there is a leak somewhere. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 5, 2018 Author Share Posted December 5, 2018 well I sent OBDlinx a support e-mail on Monday at 6am CST They replied back same day stating someone would be with me.... here we are 2 days later, nada... gonna add OBDLinx to the suck column here in a minute. Well here it is Friday and still no response. I am done with this crap, their stuff does not work and their support sucks. obd solutions is the parent company that makes that product Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 7, 2018 Author Share Posted December 7, 2018 Here is the e-mail chain to back up my claims YEUEMMAIMAI -----Original Message----- From: YEUEMMAIMAI Sent: Friday, December 07, 2018 5:50 AM To: 'hello' <ch94228-dafcgpmm@xsell.co> Subject: RE: issue with OBDLinx LX Hi, Is anyone going to help me with my issue? YEUEMMAIMAI -----Original Message----- From: hello <ch94228-dafcgpmm@xsell.co> Sent: Wednesday, December 05, 2018 1:04 PM To: YEUEMMAIMAI Subject: Re: issue with OBDLinx LX Hi , Thank you for your message! Someone from our Customer Service team will get back to you shortly. Best Regards, Micah S. P.S. Our operating hours are Monday through Friday, 8:30 am - 4:30 pm MST. On Wednesday, December 5, 2018 at 6:21 PM, wrote: > Hi, > > Just wondering if someone was going to get back to me regarding this issue... > INFO REMOVED > > -----Original Message----- > From: hello > Sent: Monday, December 03, 2018 6:53 AM > To: Yeuemmaimai > Subject: Re: issue with OBDLinx LX > > Hi , > > Thank you for your message! Someone from our Customer Service team will get back to you shortly. > > Best Regards, > > Micah S. > > P.S. Our operating hours are Monday through Friday, 8:30 am - 4:30 pm MST. > On Monday, December 3, 2018 at 12:16 PM, wrote: > > > HI, > > > > I purchased your tool through Amazon on July 15th 2018 (order XXX-########-####### ) and I am unable to get this tool to reliably work with my setup > > > > OBDLinx information: > > > > OBDlinx LX firmware 4.3.3 > > > > Model 10R-05 8941 > > > > Revision 1.2/R4 > > > > Manufactured 12-07-17 > > > > S/N XXXXXXXXXXXX > > > > Phone paired to: > > Samsung Galaxy S8 > > Model SM-G950U > > Andoid 8.0.0 > > > > Car attached to: > > 2014 Subaru Legacy 2.5i > > > > Anytime I get near my car (on or off) the OBDLinx will want to pair with my phone stating OK or cancel with a new key each time. I can factory reset the device and it will function normally for a few days and then it will go right back to spamming my phone for connection requests. As soon as I tell the phone to forget this device, I stop being spammed with BT connection requests. > > > > Another issue is I cannot get this device to work with BTSSM. It will go as far as querying ECU and hang... Your software works but is very limited in what It can do in terms of data from my car... > > > > Sincerely. > > > > > > -- > > [XSELL_JFZT81K4P7L6X] > -- [XSELL_JFZT81K4P7L6X] Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 8, 2018 Author Share Posted December 8, 2018 I got a reply from obd solutions and they stated that since their tech support never got back to me after 5 working days (still no reply as of today) they offered to send me a OBDLinx MX+ Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 8, 2018 Share Posted December 8, 2018 Get a vag-com cable and usb otg adapter if you can. Ut works and it's cheap. Just as insurance incase the new Bluetooth adapter doesn't work out Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 8, 2018 Author Share Posted December 8, 2018 I have a cable it is in a box somewhere, I have been looking for it... Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 11, 2018 Author Share Posted December 11, 2018 here is a data log. I can only grab 4 items at a time so tell me what you wantCar Scanner live data session 20181210151531.csv Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 11, 2018 Share Posted December 11, 2018 Manifold pressure : ensuring good vacuum Knock Coolant temp Afr maybe Btssm only allows you to log 4 fields at a time? Could have sworn I logged more than that. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 11, 2018 Author Share Posted December 11, 2018 naw until I get this issue sorted out with the OBDLinx I am limited to a regular ELM module and Car Doctor Pro in Windows. Finally after 7 days and a message of them saying to use scantool.net, they think the modem is tango uniform and stated they will be in touch with a replacement RMA Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 11, 2018 Author Share Posted December 11, 2018 this morning's logCar Scanner live data session 201812115404.csv Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 12, 2018 Share Posted December 12, 2018 I'm having all kinds of trouble opening the log. I've tried like 3 different excel viewers and they all have issues. Granted it's on my phone. You notice any issue with coolant temp or knock events? Link to comment Share on other sites More sharing options...
FLlegacy Posted December 12, 2018 Share Posted December 12, 2018 I have used my galaxy s9+ with the Hancomb office suite to open some CSV logs before and it worked alright. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 12, 2018 Author Share Posted December 12, 2018 this morning's log including manifold absolute pressure edit: Site wants to save as a .php file, just change the ext back to .csvCar Scanner live data session 201812125557.csv Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 12, 2018 Author Share Posted December 12, 2018 question, Where is the Manifold Absolute Pressure sensor on this car? Looks like this could be an issue. EDIT: nevermind it is right in front of my face on the top of the intake manifold.... when I first start the car MAP is 6.24PSI at the end of my trip idling in the parking lot warmed up it is 4.64PSI it takes the car 22minutes to go from a coolant temp of 116 (car was running for about 3 minutes when the data logger finally connected) to 192.2F 10 miles later Link to comment Share on other sites More sharing options...
dgoodhue Posted December 12, 2018 Share Posted December 12, 2018 I can't read the attach files on my laptop either, by using CSV or not. It is not uncommon for the idle vacuum to be higher when cold vs warmed up. At 1st glance the pressure seems low to me, but I guess it depends on that the signal is using as a reference. I would have to look at it further. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 12, 2018 Author Share Posted December 12, 2018 the idle vacuum is actually opposite of what I would expect Atmosphere is 30.54 12.70 HG when cold 9.45 HG when warm Link to comment Share on other sites More sharing options...
dgoodhue Posted December 12, 2018 Share Posted December 12, 2018 I am trying to wrap my head around the reference. Is that suppose to be 30.54-12.7 = 17.84" HG and 30.54-9.45 = 21.09" HG? Does the vacuum (or PSI) go down when you driving and step on the gas? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 12, 2018 Author Share Posted December 12, 2018 no those are the values reported at idle cold and idle warm. respectively there is something wrong when the car is cold Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 13, 2018 Author Share Posted December 13, 2018 OK got new OBDlinx MX+ will pair with car tomorrow. what is best protocol to use with BTSSM Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 13, 2018 Share Posted December 13, 2018 Those numbers are way off what you should have. Vaccum is usually 18-20in hg at warm idle. Looking for a vaccum leak would be my first order of business. Btssm says k-line unless you have a patched tune that supports can bus with that adapter. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 13, 2018 Author Share Posted December 13, 2018 ok, will do Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 13, 2018 Share Posted December 13, 2018 Thinking about your values, get the values from btssm first. The other values may have been uncorrected like dgooghue alluded. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 13, 2018 Author Share Posted December 13, 2018 BTSSM is a big fat bust. loaded up and paired to new OBDLinkMX+ and wouldn't you know it, hangs at querying ECU. Sent them an e-mail but I do not expect much given my experience with recent customer service from [insert some company here] Link to comment Share on other sites More sharing options...
