08SpecB_DE Posted January 21, 2019 Share Posted January 21, 2019 If they haven't figured it out by now, take it somewhere else. It's hard to diagnose on the internet but with live data and freeze frame data to look at, they should have nailed the problem down by now. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 21, 2019 Author Share Posted January 21, 2019 the problem is, this issue happens when the CAR is extremely cold. So we have to let them have it when the temps are in the 0 range.. that is this week and part of last week. I will be up on them today... the car is under extended warranty so let them deal with it while I drive their car. BTW if you do mostly around town driving, the 2019 Impreza is not a very fuel efficient option. I am averaging around 22mpg in that thing... yikes...it has 3.2K miles on it.. that 2.0L really struggles to get that car moving unless you get pretty deep into the throttle Link to comment Share on other sites More sharing options...
nads Posted January 21, 2019 Share Posted January 21, 2019 Good, let them figure it out. It's what you paid for. Link to comment Share on other sites More sharing options...
Wanna build gt Posted January 21, 2019 Share Posted January 21, 2019 New to the forum I am hoping some one will explain how to get power slowly not very knowledgeable on terms and under standing couldn't figure out how to make new post Hoping for advice and guidance from someone with wizdom Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 21, 2019 Author Share Posted January 21, 2019 idiots said no problem found....so I am going to get my car, already called SOA and expressed my dissatisfaction and we are done here. in the meantime I will diag it myself and fix it. freaking Subaru techs cannot fix squat Link to comment Share on other sites More sharing options...
nads Posted January 22, 2019 Share Posted January 22, 2019 idiots said no problem found....so I am going to get my car, already called SOA and expressed my dissatisfaction and we are done here. in the meantime I will diag it myself and fix it. freaking Subaru techs cannot fix squat Sorry to hear this, but almost every technician I've dealt with only knows what a computer tells them. Did they outline what they have done? Link to comment Share on other sites More sharing options...
ehsnils Posted January 22, 2019 Share Posted January 22, 2019 You need a dude with experience to get things correctly analyzed and found out. It could be a simple thing like a valve that sticks when it's cold, like OCV or purge valve. The problem is to figure out which valve. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 22, 2019 Author Share Posted January 22, 2019 yeah talk to service advisor and they said "we think the intake gaskets are shrinking when cold causing the issue" OK, if that is the case, take the intake off and verify the condition of the gaskets. pulled into parking lot car fully warmed up heat very good and STFT is pegged at 35%.....mother plucker Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 23, 2019 Share Posted January 23, 2019 Spray around the intake with 2+2 carb cleaner and watch your fuel trims. If they think it's the intake gaskets, a smoke test would have shown the leak. Your ect sensor was reading in the 180's when you had erratic fuel trims so that debunks their thought of it only leaking when cold. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 25, 2019 Author Share Posted January 25, 2019 today's ride in01-25-19car.csv Link to comment Share on other sites More sharing options...
cww516 Posted January 25, 2019 Share Posted January 25, 2019 Well, if you were to eyeball in a trend line on that graph, it does look like STFT and LTFT follow the ambient temperature sensor reading pretty closely, at least for the most part. I don't know that I know what that means, but I'd guess that it's somehow electrical rather than mechanical in nature. Would you be able to log intake air temp in addition to what you have there, to see if there's any correlation? I'd guess no, which doesn't make much sense to me, since I would have guessed the ECU would use IAT to do temperature-based corrections rather than ambient. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 28, 2019 Author Share Posted January 28, 2019 well imagine that, CEL is back on for network error and pending p0171.... Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 29, 2019 Author Share Posted January 29, 2019 two more codes u0100 and u0073 Link to comment Share on other sites More sharing options...
nads Posted January 30, 2019 Share Posted January 30, 2019 ECU failing? I think it's temper tantrum time at the dealer. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 31, 2019 Author Share Posted January 31, 2019 Sweet.... Edit: got P0012 pending this morning. I did check oil level and it is at the full mark. Oil is always changed within 6K miles. Ironically I had no heat this morning as well....(coolant temp never made it past 130F despite letting the car sit and warm up for 4 minutes. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 3, 2019 Author Share Posted February 3, 2019 Back at Subaru Link to comment Share on other sites More sharing options...
nads Posted February 4, 2019 Share Posted February 4, 2019 Well it looks like you have more ammunition to get the point across to them. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 4, 2019 Author Share Posted February 4, 2019 lol the service advisor didn't even look a the u codes Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 4, 2019 Author Share Posted February 4, 2019 OK got a text message and it has been confirmed that the intake gaskets were leaking. as a bonus, oil sending unit replaced due to leak Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 5, 2019 Share Posted February 5, 2019 I'd steer clear of that dealer in the future if possible. I'm glad to hear they finally found the problem. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 5, 2019 Author Share Posted February 5, 2019 Yeah definate last visit with tbem... Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 6, 2019 Author Share Posted February 6, 2019 they texted stating car is ready... has every single finger and toe crossed hoping that this is the LAST ISSUE that needs to be addressed. to recap 3 years to get T-stat replaced as it was sticking closed in extreme temps 2+ years to get P0171 resolved. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 7, 2019 Author Share Posted February 7, 2019 Drove car home and 1 no more hesitation 2 no more rough idle 3 no more excessive fuel smell 4 32mpg Link to comment Share on other sites More sharing options...
Infosecdad Posted February 7, 2019 Share Posted February 7, 2019 Promising start Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 7, 2019 Author Share Posted February 7, 2019 Went out and started car this morning and yessir, the issue is good... did not smell excessive fuel, matter of fact it barely smelled at all.. car runs fantastic, gives good head and fuel economy is back up in the lower 30s. Lets just say that up until this point SOA has left a bad taste in my mouth 2 out of the 3 times I dealt with them. If you were to ask me if they stand behind their cars, I would have to say, No, not really. I bought my car when it was 2.5 years old and still within the original 3/36 warranty 5/60K power train warranty and I also purchase extended warranty for 4 years 60K November 2016 is when I first brought the car in for no heat in winter time. Car had 23,2XX miles on it. this issue was finally resolved in Jan 2019 and the car had 57,6XX miles on it. Had to pay extended warranty deductible, yes I am submitting that to Subaru for reimbursement as that issue was clearly present under original powertrain warranty November 2017 is when I first brought the car in for P0171, replaced front o2, did not resolve, I replaced MAF in April 2018 as it was flaky, it partially resolved as I was no longer smelling raw fuel at the time. Winter 2018-19 shows up and literally p0171 begins to toggle like mad, setting and clearing in each drive cycle. Finally February 2019, they replace both intake manifold gaskets and voilà, issue 100% resolved. Link to comment Share on other sites More sharing options...
