1max2nv Posted January 10, 2006 Share Posted January 10, 2006 That's a good way to loosen the bolt if you are auto.. I did mine the quick yet dangerous way. Set up a 1" wrench on the ratchet so that it rested on part of the car that doesn't move (and the right direction of course) and cranked the car. As soon as I turned the key I could that the bolt had popped loose...I checked and nothing was damaged, only the bolt was loose and I didn't have to put any"ass" into it ;D Link to comment Share on other sites More sharing options...
wukindada Posted January 11, 2006 Share Posted January 11, 2006 Have had my unothodox pulley set on since August.....Me likie....plus it adds to the under the hood BLING:eek: Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
2Simpletons Posted January 11, 2006 Share Posted January 11, 2006 Do it when the engine's HOT too. Wear gloves and a long shirt 'cause the Coolant hoses will burn the **** outa you. I've installed 4 of these things on Scoobs so far and I've had a different experience every time. The best 2 times I've done it is when the crank shaft was hot hot. The bolt just comes right out. I've almost killed my self and my car trying it on a cold engine twice. Big difference. Link to comment Share on other sites More sharing options...
1freak Posted January 11, 2006 Share Posted January 11, 2006 hey everyone, does anyone know if the pully with cause problems in the long run. I cant remeber where I heard that but I figuerd I would ask check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
PhilT Posted January 13, 2006 Author Share Posted January 13, 2006 Not that I have heard of. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
1freak Posted January 13, 2006 Share Posted January 13, 2006 thanks check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
RaGe Posted February 13, 2006 Share Posted February 13, 2006 well let me ask you this then. giving what type of pulley you uese you say that some require you to buy new belts because of the smaller diameter of the new pulley. does it tell you what size to buy? i know when i had my mustang i purchased underdrive pulleys and i had to custom fit belts. took me forever and a few runs to the parts shop putting on and taking off, putting on and taking off.....it goes on and on. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
wukindada Posted February 13, 2006 Share Posted February 13, 2006 Unorthodox lets you know what you will need:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
RaGe Posted February 13, 2006 Share Posted February 13, 2006 thats what i was wondering. thanks for the promt reply. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
-Smoke_ Posted May 8, 2006 Share Posted May 8, 2006 I did mine the quick yet dangerous way. Set up a 1" wrench on the ratchet so that it rested on part of the car that doesn't move (and the right direction of course) and cranked the car. As soon as I turned the key I could that the bolt had popped loose...I checked and nothing was damaged, only the bolt was loose and I didn't have to put any"ass" into it ;D Thanks BadAndy, it worked great! I set up a breaker bar & 1" wrench, bumped the ignition, and "crack". Kind of worried me at first, but after inspection, bolt was loose and everything was good! I now have a new lightweight pulley with no probs! The car seems to turn up a little faster and maybe a slight bit more performance. Well worth it! "You poke it, You own it" - Man law supporter Link to comment Share on other sites More sharing options...
Shea Posted May 18, 2006 Share Posted May 18, 2006 Bumping for a question. I am suprised that no Lok-tite is needed when installing a pulley, especially if you are using a much lower torque rating. Is this not the case? Link to comment Share on other sites More sharing options...
bugblatterbeast Posted June 8, 2006 Share Posted June 8, 2006 You don't want to use thread locking compound on the crank pully. Given the size of the bolt you would never be able to get it out again. Most manufacturers even recommend oiling the threads so the torque reading is more consistent. I'm sure they've factor in the clamp load needed to hold the pully on, especially if they ask for lube on the threads. Is there a special tool for getting the crank bolt out of Subaru's without a helper? For most Honda's you use a 50mm hex attached to a long handle (ie: plumbing fitting welded to a gas pipe ). The Hex portion locks the pulley while you shove the your socket through the middle. Link to comment Share on other sites More sharing options...
Gt4Me Posted June 8, 2006 Share Posted June 8, 2006 I just tightened the belt alittle and put one ratchet on the power steer pump pulley nut. With long extensions it was no problem. Alot easier than my brake line hoses. Link to comment Share on other sites More sharing options...
Guest subiecity Posted November 1, 2006 Share Posted November 1, 2006 i have a 4eat....i couldnt get my nut off so i took it to a friend of mines shop....he said he almost couldnt get it off....when we finally took off the oem pulley....HOLY ****........the thing feels like it weights like 10 lbs, it really feels like a solid piece of steel..i kno the oem pulley is suppsed to be like 6 lbs or so...but goddam its heavy compared to my agency power pulley...they claim their pulley weight exactly 1.0lb i think its the lightest crank pulley outta all of them....but definitely a hug diffence i feel as i can launch the car a lot faster now insead of having the car feel like its 3000lbs(lol jk 3200 to be exact)...and when dropping down a gear and wanting to pass someone...oohh baby it feels soo much better....but for a N/A car its def a good investment for your money..i highly reccomend a lightweight crankshaft pulley Link to comment Share on other sites More sharing options...
iroczu Posted November 22, 2006 Share Posted November 22, 2006 No change in driveability, just seems to rev quicker. No reason to stall it at all, it doesn't feel any different setting off, just when you floor it the needle climbs faster. No way she will notice, mine hasn't noticed any change from stock even though I'm at AP stg.1. I just drive accordingly when she is in the car. the worlds most funniest words "will my wife notice" "no" but the rest is just funny... maybe i'm just lacking sleep... Link to comment Share on other sites More sharing options...
derffred Posted November 23, 2006 Share Posted November 23, 2006 But, again you can look at the other side of the story and hear/see the stories of the stock pulley seperating; causing serious damage. yep... same thing with Mercedes-Benz... they have a recall for almost all harmonic balancers on the 112 an 113 engines... you have to replace them based on certain part numbers.. failure to do so will result in breaking and damaging the main front cover an main upper oil pan... Link to comment Share on other sites More sharing options...
Jagger82 Posted January 17, 2007 Share Posted January 17, 2007 I purchased the perrin lwp, wife threw the installation instructions away... I've tried to get them off perrin website but can't find them. could someone email the instructions, I have a 5eat, is it safe to crank the car like mentioned above to loosen the bolt? thanks, Yager Link to comment Share on other sites More sharing options...
unstablementaly Posted January 19, 2007 Share Posted January 19, 2007 dude, check the beginning of the thread! my vBGarage Link to comment Share on other sites More sharing options...
sashadg1 Posted January 23, 2007 Share Posted January 23, 2007 What about the Power steering Pulley, do I need a Pulley Puller to get it off, they are usually torqued on. Link to comment Share on other sites More sharing options...
Guest subiecity Posted January 23, 2007 Share Posted January 23, 2007 no just a oem sized lightweight crankshaft pulley Link to comment Share on other sites More sharing options...
sashadg1 Posted January 23, 2007 Share Posted January 23, 2007 no just a oem sized lightweight crankshaft pulley No trying to find out how to get the Power Steering pulley off. I have the UN Crank and Steering pulley set. What about all this talk of making sure it's top dead center? (Do I need to mark anything before I remove it?Crank) Link to comment Share on other sites More sharing options...
Guest subiecity Posted January 24, 2007 Share Posted January 24, 2007 oh so u got an underdriven pulley i guess, idk i just took my shit to the gas station cahrged me 50 bucks and had everthing installed in like 25 min Link to comment Share on other sites More sharing options...
sashadg1 Posted January 24, 2007 Share Posted January 24, 2007 Yes have the UN slight Underdrive pulley set, the Steering pulley has compression grooves which telles me the stock has them too, this means PIA to get off. Has anybody done this (Power Steeering pulley)? Do I need a Puller to get it off. Scott Link to comment Share on other sites More sharing options...
Guest subiecity Posted January 27, 2007 Share Posted January 27, 2007 i couldnt help ya there, im not exactly a fan of underdriven pulleys, not to safe for charging your car, i dont wanna get stuck with a dead/weak battery Link to comment Share on other sites More sharing options...
one69chev Posted January 27, 2007 Share Posted January 27, 2007 ^^but if you go with the same diameter, but a lighter weight, it won't be underdriven, just have lighter rotational mass..... or sumthin' like that.... Link to comment Share on other sites More sharing options...
