Help me! Hub bearing rusted to knuckle.
So I made the now infamous decision to change out my front drivers side wheel bearing. I’ve already snapped the lower caliper bracket bolt (repair still in progress) and now have a hub that is completely rusted to the dust screen/knuckle. It is completely free from the spindles. I’ve been constantly PBing it, hammered it, screwed in a couple bolts on the back to hammer, and slide hammered. The slide hammer completely split the hub, so now I know longer have bolts to work with.
I’m desperate here, does anyone have any ideas? I can’t even take the easy route out since I’m not sure how I’d tow in it’s current state. I really appreciate any help.
Can you provide details on when you screwed in the bolts on the back to hammer? How far did you screw them in, what did you use to hammer them?
Bottom line is, that's the correct approach, and it WILL come out that way if you apply the correct technique. It may help to post a pic of what you have left to work with.
I’ll work on getting pictures if I can. I basically have the two lower 14mm screwed in less than half way. I’ve tried hammering them from the back, but nothing is budging. I’m debating the technique of using an extension bar and turning the wheel, but a little nervous and only think I have a leverage point for the one closer to the front of the car.
Sounds like it might be easier at this point to replace the knuckle.
BTW what front hub assemble did you buy ?
https://www.google.com/search?q=front+steering+knuckle+2006+subaru+legacy&oq=front+steering+knuckle+2006+subaru+legacy&aqs=chrome..69i57.23207j0j8&sourceid=chrome&ie=UTF-8
That pinch bolt can be a PITA.
Have you tried hitting the hub from the side to spin it ?
Looks like you the axle pushed back a little.
Engine Build - Click Here
It's just rust holding it in at this point. My left rear was a PITA at the same point your at, let the PB do its thing, go have lunch and come back.
Max, I bought a Timken HA590315 assembly. Really trying to avoid the knuckle replacement since I’m sure I’ll have difficulty getting that stuff apart and I’ve had past difficulties reattaching my strut.
As for as chiseling, I’ve been going at it where I can. Should I just slaughter the dust plate and go at it all over?
I had this problem and ended up taking my knuckle/hub assembly as a unit to a guy with a hydraulic press who then pressed the hub assembly out of the knuckle and pressed the new hub assembly in.
Torch, hammer, slide hammer, hub puller, brute force... it won't work.
Perfect pics, thanks. First, you need to screw the bolts much farther in, for two reasons. 1 - when they're that shallow, any serious hammering will destroy the threads, which of course only matters if you want to keep the bolts. 2 - firmer seating in the threads makes for more effective force transfer. So thread them in to 3-5 mm from the back of the knuckle.
Second, put the bolts in catty corner so you can keep the bearing straight when walking it out. Third, you didn't say what you hit them with. The proper tool for this job is an air hammer, $10 from Harbor Freight. It's possible but much more difficult and dangerous to use an engineer's hammer with a super-long punch.
A few seconds with the air hammer will break the rust. Then alternate hammer taps with backing the bolts out.
Yeah, followed one of your other posts suggesting that brand. I’ve been soaking it in PB for the last 3 days in between my holiday/frustration drinking. Looks like I’m about to throw in the towel for a tow, then I can add sad drinking to the list.
If you have a Dremel or angle grinder you could try to cut the rust around the the bearing housing and allow the PB and chisel to get in deeper. You could also make a groove to get a chisel/pry bar in there for more leverage.
if you have air, not only would i suggest the air hammer, but also take a burr to some of the rust. it's a bit time consuming, but prevents throwing more money at the problem when you can salvage your parts.
edit: dont forget to wear some eye pro
Do you have any air tools if so you can try an air hammer on the sides or a sledge hammer or using an old brake rotor. If you have new bolts you can try using old bolts and hit them from the other side. If you have a grinder or wire wheel try to clean up any rust you can. If using a hammer make sure you are using jack stands and watching that car is not going to fall off and hurt/kill/etc you
I had a similar problem with the front wheel bearing on my 99 Dodge Ram. I ended up using the loosened bolts with a socket and extension to push the bearing out of the knuckle. Long socket extension wedged onto the axle bracket and starting & turning the wheel popped it loose quickly. Air hammer on the loosened bolt heads would probably work pretty well too.
Definitely try an air hammer. I think they’re like $15 at Walmart. Also, ditch the PB blaster and go for a 50/50 transmission fluid and acetone mix. Put in a bottle shake it up and spray the hell out of it. I’ve never seen anything it couldn’t break. It’s broken loose alignment bolts that shops couldn’t.
