JazzAvi8r Posted May 26, 2018 Author Share Posted May 26, 2018 #4 is really hosed. #1&3 look fine. So i need an A and a B piston, and a set of rings. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted May 26, 2018 Author Share Posted May 26, 2018 1 and 3 look fine. gonna replace the rings on those anyway. i'll replace 2 and 4. cylinders check out perfectly fine and dont need to be honed at all. i'm dreading getting the rods and pistons lined back up to put the wrist pins back in. that's gonna suck. Link to comment Share on other sites More sharing options...
relative4 Posted May 26, 2018 Share Posted May 26, 2018 So... this thread started after a head gasket job. What were the symptoms before that job? Link to comment Share on other sites More sharing options...
JazzAvi8r Posted May 26, 2018 Author Share Posted May 26, 2018 Misfire on cyl2&4. Link to comment Share on other sites More sharing options...
ehsnils Posted May 26, 2018 Share Posted May 26, 2018 #4 is really hosed. #1&3 look fine. So i need an A and a B piston, and a set of rings. Check the pistons of 1&3 thoroughly, or you may blow them soon too if 2&4 has gone. I'd prefer to take all pistons at once even if it's more expensive. It would suck to find out that in a few months 1&3 are gone. Realize that unless you X-ray you don't know if a piston is good or not at this stage. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted May 26, 2018 Author Share Posted May 26, 2018 Yeah, we are throwing around the idea of,dropping in forged stock sized pistols and rings. Still debating how much money we want to dump in it since we are just selling the car anyway. Link to comment Share on other sites More sharing options...
ehsnils Posted May 26, 2018 Share Posted May 26, 2018 Not good for karma if it's a time bomb going out. Just run with all pistons stock, but check the diameter of the bores before you get pistons to make sure the diameters are still A or B classed or if you need overdimension. Link to comment Share on other sites More sharing options...
rhino6303 Posted May 26, 2018 Share Posted May 26, 2018 Isn't there a vendor that sells brand new drop in pistons that they take out of new oem blocks for forged builds? Somone like outfront or something? I thought I read somewhere there was and that they sell them at a fairly reasonable cost. Link to comment Share on other sites More sharing options...
aj_mariner Posted May 27, 2018 Share Posted May 27, 2018 Do you still have pistons from the STI build? Keep thinking about how clean everything is. Making me wonder if they did a Seafoam treatment or something. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted May 30, 2018 Author Share Posted May 30, 2018 Yeah, i still habe the STi pistols, but irrelevant. I just bought 4 new pistons, set of rings, and the little plastic piece i. Rome off the power steering pump. Another $460 to my build. That puts me right at $5k in to this car and hoping to sell it for $8500 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 30, 2018 Share Posted May 30, 2018 So it was the pistons huh... Moral of the story (at least for me): --good cylinder wall conditions do not automatically exclude cracked ringlands --having two cylinders misfiring on the same bank can indeed be due to cracked ringlands (first time I see this though) What brought the build cost to 4.5K$ again? Link to comment Share on other sites More sharing options...
sshole Posted May 30, 2018 Share Posted May 30, 2018 Isn't there a vendor that sells brand new drop in pistons that they take out of new oem blocks for forged builds? Somone like outfront or something? I thought I read somewhere there was and that they sell them at a fairly reasonable cost. Crawford sells them for $25/piston (B) and $75/piston (A)... https://crawfordperformance.com/products/take-out-pistons-sti-ej257?variant=18735087303 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 30, 2018 Share Posted May 30, 2018 Crawford sells them for $25/piston (B) and $75/piston (A)... https://crawfordperformance.com/products/take-out-pistons-sti-ej257?variant=18735087303 Great, now you tell him... Where were you the other day...what, did life get in the way. LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 30, 2018 Share Posted May 30, 2018 Crawford sells them for $25/piston (B) and $75/piston (A)... https://crawfordperformance.com/products/take-out-pistons-sti-ej257?variant=18735087303 I just browsed their site. Looks like you still have to add the price of rings which is like 160$. Not sure if it is for all 4 pistons or just one. Not clear. Link to comment Share on other sites More sharing options...
sshole Posted May 30, 2018 Share Posted May 30, 2018 Pick up a set of rings from another vendor if their price is too high. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 2, 2018 Author Share Posted June 2, 2018 What brought the build cost to 4.5K$ again? $3300 for the car $100 for the trailer rental $470 for the gasket kit, head bolts, thermostat, and new reservoir tank $200 for new buckets $120 in fluids $350 for the head work Another $460 for pistons and rings, and the little power steering plastic piece. Gonna need fluids again as well Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 2, 2018 Share Posted June 2, 2018 ah ok. You are including the price of the car. So I see why the build is at 4.5k now. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 3, 2018 Author Share Posted June 3, 2018 Pistons and rings are in. What a nightmare. I kept dropping the stupid wrist pin retainer clip into the oil pan. So i had to remove the oil pan 3 times last night to dig it out. I know, I should be just left the oil pan off to begin with, but I have to learn all my lessons the hard way. After my wife gets home to watch my son, I'll put the heads back on and get this car running. Thinking of replacing the clutch and flywheel while I'm in there since this one is about shot. Exedy stage 1 is what's on it right now with the TSK3. Pics to follow Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 3, 2018 Author Share Posted June 3, 2018 baby steps. gonna go put the heads on now. Link to comment Share on other sites More sharing options...
ehsnils Posted June 3, 2018 Share Posted June 3, 2018 Pistons and rings are in. What a nightmare. I kept dropping the stupid wrist pin retainer clip into the oil pan. So i had to remove the oil pan 3 times last night to dig it out. I know, I should be just left the oil pan off to begin with, but I have to learn all my lessons the hard way. After my wife gets home to watch my son, I'll put the heads back on and get this car running. Thinking of replacing the clutch and flywheel while I'm in there since this one is about shot. Exedy stage 1 is what's on it right now with the TSK3. Pics to follow It's getting there - and with the oil pan off Murphy's law would have had it that the clip would have been found in the most remote corner in the garage under something taking a forklift to move. We all just hope that you got it good now! Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 3, 2018 Author Share Posted June 3, 2018 Yeah, it was pretty easy to find after removing the pan. Its just a royal PITA to get those wrist pins back in while lining up the rods. Took entirely too much time Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2018 Share Posted June 3, 2018 ain't it fun working on these cars... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
aj_mariner Posted June 4, 2018 Share Posted June 4, 2018 What did you end up deciding about the honing? Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 4, 2018 Author Share Posted June 4, 2018 I took the glaze off. I used my honer, but wrapped it with a scotch brite pad to take the glaze off. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 4, 2018 Author Share Posted June 4, 2018 Heads are back on. Waiting on a new Exedy stage1 clutch and flywheel to come in. Link to comment Share on other sites More sharing options...
