Darth SpecB Posted December 4, 2016 Share Posted December 4, 2016 Good to see your making really good progress with the build! I've been trying to keep up hehe. I just hope all of your oil clearances for the main bearings are within tolerance. Did you measure with plastigauge? Many rebuilds fail quickly due to inproper bearing sizes. Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
jersdunz Posted December 5, 2016 Author Share Posted December 5, 2016 Good to see your making really good progress with the build! I've been trying to keep up hehe. I just hope all of your oil clearances for the main bearings are within tolerance. Did you measure with plastigauge? Many rebuilds fail quickly due to inproper bearing sizes. Sent from my SAMSUNG-SM-G900A using Tapatalk I paid the machine shop to size the bearings, He only had to adjust the rod bearings 2 of them were tight. I then plastigauged all the mains..as a double check. What I did fail to do is record the process. Link to comment Share on other sites More sharing options...
jersdunz Posted December 13, 2016 Author Share Posted December 13, 2016 Good to see your making really good progress with the build! I've been trying to keep up hehe. I just hope all of your oil clearances for the main bearings are within tolerance. Did you measure with plastigauge? Many rebuilds fail quickly due to inproper bearing sizes. Sent from my SAMSUNG-SM-G900A using Tapatalk So your post has been eating at my soul. And my engine is back apart. I was losing sleep over the Damn thing.. Lol http://uploads.tapatalk-cdn.com/20161213/a570e975410525ed0476d71819aff51a.jpg http://uploads.tapatalk-cdn.com/20161213/7bfdecf7a6e215c3409ee0c6f8e4d227.jpg http://uploads.tapatalk-cdn.com/20161213/dd89885071b61ab8e665b1b535c12cfa.jpg http://uploads.tapatalk-cdn.com/20161213/d8096dcad2b512d6b8953e16c505673b.jpg http://uploads.tapatalk-cdn.com/20161213/5b0902251a06be6c7150c09c463010bb.jpg http://uploads.tapatalk-cdn.com/20161213/01f006185fec53633aa510d37a88b99a.jpg http://uploads.tapatalk-cdn.com/20161213/02086a834094674aee28f402a2dde990.jpg I had to double check. And I'm thinking about taking it to a different machine shop to get some real numbers. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 13, 2016 Share Posted December 13, 2016 It's been many years, but aren't those holes in the bearing supposed to line up with an oil port in the block ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jersdunz Posted December 13, 2016 Author Share Posted December 13, 2016 It's been many years, but aren't those holes in the bearing supposed to line up with an oil port in the block ? I don't know, I will see if they do with some rearranging. I know the groove is all nice and centered. Link to comment Share on other sites More sharing options...
Darth SpecB Posted December 13, 2016 Share Posted December 13, 2016 So your post has been eating at my soul. And my engine is back apart. I was losing sleep over the Damn thing.. Lol http://uploads.tapatalk-cdn.com/20161213/a570e975410525ed0476d71819aff51a.jpg http://uploads.tapatalk-cdn.com/20161213/7bfdecf7a6e215c3409ee0c6f8e4d227.jpg http://uploads.tapatalk-cdn.com/20161213/dd89885071b61ab8e665b1b535c12cfa.jpg http://uploads.tapatalk-cdn.com/20161213/d8096dcad2b512d6b8953e16c505673b.jpg http://uploads.tapatalk-cdn.com/20161213/5b0902251a06be6c7150c09c463010bb.jpg http://uploads.tapatalk-cdn.com/20161213/01f006185fec53633aa510d37a88b99a.jpg http://uploads.tapatalk-cdn.com/20161213/02086a834094674aee28f402a2dde990.jpg I had to double check. And I'm thinking about taking it to a different machine shop to get some real numbers. Haha it was killing me too! Good thing you double checked, but it seems according to plastigauge you should be fine. I would just check your oil pressure and possibly switch to 5w40 if needed. Also if the tangs are in place, the oil holes are fine because I believe oem bearings have only 1 oil hole per half shell. It seems your bearings have 2 oil holes per half shell. Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted December 14, 2016 Share Posted December 14, 2016 Just make sure one of those oils lines up with the oil gallery. Also use 5w-40 year round, don't use a 5w-30. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StkmltS Posted December 15, 2016 Share Posted December 15, 2016 My clearances are basically the same as yours, except mine is 0.0005" looser on the rear journal. My motor has lasted 2,500 miles (so far) on these clearances so I'm confident you'll be fine with the measurements you got. I used the same King XP bearing as you did, so I'm also sure that you don't need to worry about lining up any of the oil holes. Fortunately for us all of the main bearings (except the thrust bearings) have aligning tangs, which means there's only one way to put them in. From my rebuild: Using plastigage these are my measured clearances for the mains with new std size bearings: Main 1 - 0.0015" Main 2 - 0.0015" Main 3 - > 0.001 but < 0.0015" Main 4 - 0.0015" Main 5 - 0.001" The FSM specifies 0.0004" to 0.0012" clearance. From what I've read, using 5w-40 (vs the factory recommended 5w-30) means that my slightly larger clearances are acceptable. Rod oil clearances (measured using plastigage: R1 - 0.0015" (0.006" side) R2 - 0.0015" (0.006" side) R3 - 0.0015" (0.006" side) R4 - between 0.0015" and 0.002" (0.008" side) The FSM specifies the oil clearance to be 0.0007" to 0.0018", and the side clearance to be 0.0028" to 0.0130". My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
birkhoff Posted December 15, 2016 Share Posted December 15, 2016 This comes up quite a lot. The factory spec on mains oil clearance is tighter than that -- maybe those larger numbers come from the STI specs. The mains are supposed to be 0.0004 to 0.0012. Of course, you can set them more open -- lots of builders do that and it seems to work out fine, up to a point. The machinist who set up the mainline on this case seems to have gone for the top of the spec and did a very nice job of it. With a bore gauge, you can do the measurements and half shell swaps pretty quickly and produce uniform clearances like you have there. There is no need take it back to the shop to verify. Doing a final plastigage test is always a good idea just to be sure the math wasn't wrong. They probably did that at the shop already. Using a bore gauge on he soft bearing faces will inevitably mark them up. That's why you see the polishing marks there as the final step in a professional job. Link to comment Share on other sites More sharing options...
jersdunz Posted December 17, 2016 Author Share Posted December 17, 2016 Thank you guys for the feedback. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
jersdunz Posted December 17, 2016 Author Share Posted December 17, 2016 I got the new cooler in the mail this afternoon. I don't know why but something about the price if this part and the complete lack of aftermarket on it makes me a little bit crazy. It feels like a big fat FU from Subaru. .http://uploads.tapatalk-cdn.com/20161217/751be55ba2e989b65c42764f254ff5b1.jpg On a side note, what is the consensus on spending 40$ on a new oil pick up from Subaru vs the aftermarket for 175? Are new oem pickups dependable? Link to comment Share on other sites More sharing options...
Darth SpecB Posted December 17, 2016 Share Posted December 17, 2016 Yeah 200$ is what I paid for my oil cooler! I went with a Moroso oil pickup tube. The design looks great compared to oem. I'll post a link. For $92 I'd say the extra 50$ for peace of mind is more than worth it. https://www.amazon.com/gp/aw/d/B005PX0SAO/ref=mp_s_a_1_fkmr1_2?ie=UTF8&qid=1481951500&sr=8-2-fkmr1&pi=AC_SX236_SY340_FMwebp_QL65&keywords=subaru+oil+pickup Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted December 17, 2016 Share Posted December 17, 2016 I got the new cooler in the mail this afternoon. I don't know why but something about the price if this part and the complete lack of aftermarket on it makes me a little bit crazy. It feels like a big fat FU from Subaru. .http://uploads.tapatalk-cdn.com/20161217/751be55ba2e989b65c42764f254ff5b1.jpg On a side note, what is the consensus on spending 40$ on a new oil pick up from Subaru vs the aftermarket for 175? Are new oem pickups dependable? PM Sgt.Gator about the oil cooler. He knows the Perrin folks who might have an alternate solution. I bought a Mishimoto Oil cooler with thermostatic plate. With regards the oil pickup. have you read of anyone cracking one other than after a big off-road hit? That said, I bought a KB pickup along with the pan & windage tray, so YMMV. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
RustyRuu Posted December 18, 2016 Share Posted December 18, 2016 Using a bore gauge on he soft bearing faces will inevitably mark them up. That's why you see the polishing marks there as the final step in a professional job. he said he used king bearings and i was wondering why they were not that blacker color. Link to comment Share on other sites More sharing options...
StkmltS Posted December 21, 2016 Share Posted December 21, 2016 I'll second Darth's vote for a Moroso pickup. It's twice the price of OEM, but only half the price of a Killer B. I've never understood why people spend so much extra $ on name brand items that aren't necessarily proven to be better than a cheaper alternative (Killer B vs Moroso). I'm not knocking every Killer B customer, I just don't understand what makes the KB pickup so much better My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Sgt.Gator Posted December 21, 2016 Share Posted December 21, 2016 I've used the both the Moroso and KillerB pickups. The only advantage I can see is the Killer B is a tripod design for potentially greater stability in extremely violent situations like RallyX or a Baja 1000 run. I use the Moroso now in my street builds. Dry Sump for racing which removes the oil pickup. Moroso has been making competition oil pickups and pans since 1968, started by a racer. They know how to make oil pickups and have a ton of experience at it. They are the best deal for a pickup in our engines IMHO. On the oil cooler, you can delete it entirely (it's primarily an oil warmer for cold weather operation to get the engine warm for emissions, but it does have a cooling effect too) or replace it with a sandwich plate >AN lines> cooler options. The problem is not all sandwich plates will fit in the limited area against the block without the cooler extending the plate down away from the block. To delete the oem cooler you need the short oil filter pipe. There's writeups about deleting it. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
birkhoff Posted December 22, 2016 Share Posted December 22, 2016 he said he used king bearings and i was wondering why they were not that blacker color. King makes a number of different lines of shells for our cars. They may not have been black to begin with. The polish step is normally very light -- sometimes just a piece of newspaper is enough to clean up the scratches, but it will leave those swirls you see in the pics. The swirls may not be as obvious to the eye as they are in the pictures. Camera angle and light can accentuate this sort of thing. Link to comment Share on other sites More sharing options...
jersdunz Posted February 2, 2017 Author Share Posted February 2, 2017 I went with the compromise and ordered the moroso oil pick up. On a side note I dug my bow out for one reason or another. And it's been over a month since I've accomplished something productive.. Damn Link to comment Share on other sites More sharing options...
Max Capacity Posted February 2, 2017 Share Posted February 2, 2017 Nice bow. Now get back to the engine... we want to see progress 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
maxspeed3 Posted February 13, 2017 Share Posted February 13, 2017 Subscribed! You've made awesome progress on your build! I may have missed it, but what turbo are you planning on running? Link to comment Share on other sites More sharing options...
jersdunz Posted February 13, 2017 Author Share Posted February 13, 2017 Subscribed! You've made awesome progress on your build! I may have missed it, but what turbo are you planning on running? That is one if those decisions I have not been able to lock down. I've been considering forced performance although which one I'm not sure about. steam speed http://steamturbochargers.com/index.php/stock-location-turbos-456/steam-turbos/steam-stx-71lgt-for-subaru-wrx-legacygt-8cm.html bnr billet 20g Something that'll flow 51lb/min at a minimum. I'm also torn on rotated or stock. I think I could fabricate the pieces to do rotated pretty cheaply. My friend's, several of them have tig welders and I have some access to laser cutting as you probably seen previously on here. In fact I already have the flanges drawn up at least to reproduce the stock connections. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 13, 2017 Share Posted February 13, 2017 rotate it. That STX 71 looks like a nice piece... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jersdunz Posted February 14, 2017 Author Share Posted February 14, 2017 You just have to love... The oil shield bolt that won't tighten.. :-( Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
jersdunz Posted March 7, 2017 Author Share Posted March 7, 2017 I have been back to work on the Legacy.. I just noticed today that I had closed up the engine with out snapping any photos. I did Go with the Moroso oil pickup. I Just bought a used Grimspeed EBCS and a new DW200 fuel pump. I just barely mailed the cam gears to outfront this weekend so not a ton of progress on the engine. I did get some work done mounting the FMIC i'll Post some pics from my phone. Also over the weekend I finally pulled the trigger on my turbo and it felt really good to get over that hurdle. I went with a BorgWarner EFR 7670. I'm still not even crystal clear on all of the plumbing to put the intake back together but I'm all kinds of excited to be getting to the part where I get to start building a header. I plan on building a clone of a KillerB holy header going to use my friends bender & 2" dies to make the runners and i'll get some 2.5" mandrel bends to run out from the collector. I'll tell you the hardest part of this project for me too accept is the pornographic prices on some of these simple fabricated exhaust parts. Link to comment Share on other sites More sharing options...
jersdunz Posted March 7, 2017 Author Share Posted March 7, 2017 Link to comment Share on other sites More sharing options...
