foxrider28 Posted January 12, 2018 Share Posted January 12, 2018 I would be in for a group buy!Possibly in as well. It would be a good idea to do these with my suspension this summer. Link to comment Share on other sites More sharing options...
Hanger Posted January 13, 2018 Share Posted January 13, 2018 In as well, car making all kinds of noises ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
GTEASER Posted January 13, 2018 Share Posted January 13, 2018 I'll play. But no guarantees I get them installed before 2025. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
covertrussian Posted January 13, 2018 Author Share Posted January 13, 2018 Sent an email to Cygnus about doing a group buy! SuperPro also has the +0.5* caster version: SPF4865K If I had a sedan I would get caster adding ones. But since I'm on a tall wagon, I wanted to keep some of the understeer for snow safety. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
cww516 Posted January 14, 2018 Share Posted January 14, 2018 The hardrace rubber ones I bought are still in the box on a shelf, so I might potentially be interested in a group buy as well. Link to comment Share on other sites More sharing options...
Becks1818 Posted January 14, 2018 Share Posted January 14, 2018 I'm in for a group buy too. Question. What the point in buying the castor ones ? Sent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
covertrussian Posted January 15, 2018 Author Share Posted January 15, 2018 I'm in for a group buy too. Question. What the point in buying the castor ones ? Sent from my Pixel 2 XL using Tapatalk Caster increases how much negative camber the wheel will gain as you turn it. Positive caster helps offset the negative effects of lots of Steering axis inclination that all strut cars have (gaining positive camber as you turn the wheel). You can use this worksheet to calculate the difference. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
FLlegacy Posted January 15, 2018 Share Posted January 15, 2018 Caster increases how much negative camber the wheel will gain as you turn it. Positive caster helps offset the negative effects of lots of Steering axis inclination that all strut cars have (gaining positive camber as you turn the wheel). You can use this worksheet to calculate the difference.So since most of our cars are probably neutral or close to it we are actually leaning our front wheels outward as we turn. The caster bushings would correct that slightly and give us more traction into turns. Sound about right? Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
covertrussian Posted January 15, 2018 Author Share Posted January 15, 2018 Correct, more caster = more negative camber on outside wheel = more traction in a turn. Now keep in mind, the inside wheel's top should be point out (positive camber), that's on purpose. When I first got the caster bushings for my LGT, I installed them to remove caster by accident (since I was used to old style control arms). Anyway, the difference form stock bushings to whiteline bushings was night and day, even though I decreased caster. Year or so later I realized my mistake, and rotated them to gain caster, once again the difference was pretty astonishing. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Becks1818 Posted January 15, 2018 Share Posted January 15, 2018 Correct, more caster = more negative camber on outside wheel = more traction in a turn. Now keep in mind, the inside wheel's top should be point out (positive camber), that's on purpose. When I first got the caster bushings for my LGT, I installed them to remove caster by accident (since I was used to old style control arms). Anyway, the difference form stock bushings to whiteline bushings was night and day, even though I decreased caster. Year or so later I realized my mistake, and rotated them to gain caster, once again the difference was pretty astonishing.So if I am running some slight camber right now will they do much of anything ? Sent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
covertrussian Posted January 15, 2018 Author Share Posted January 15, 2018 So if I am running some slight camber right now will they do much of anything ? Sent from my Pixel 2 XL using Tapatalk A picture is worth a 1000 words. http://legacygt.com/forums/attachment.php?attachmentid=260777&stc=1&d=1515987999 Basically more caster, less static negative camber needed. There are limits to how much caster you want to run on a FWD car (~4* due to torque steer issues), but on RWD you see even 10*. AWD is kind of in between, so you should be fine to run 7-8* 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
covertrussian Posted January 16, 2018 Author Share Posted January 16, 2018 Checked my alignment today by hand, was toeing in by 3/16"! When I went from stock to retrofitted Prothanes, car was Toeing out by 1/16", which my notes don't show me zeroing. So expect to need an alignment after installing new bushings. This makes me wonder how off center my Prothanes were, or even how off center the stock ones were before too. If you take your car to an alignment shop this would show up as uneven caster. I would be curious to see people's before and after alignment sheets. P.S. I'm talking to Cygnus about getting the group buy going. Should be able to do a tiered group buy. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
FLlegacy Posted January 17, 2018 Share Posted January 17, 2018 I am definitely in, I have yet to do these bushings on any of our subies, but my baby is popping and creaking lol. Link to comment Share on other sites More sharing options...
covertrussian Posted January 17, 2018 Author Share Posted January 17, 2018 Alright those that are interested, send an email to Geoff at geoff@cygnusperformance.com or give him a call at (321) 600-0889 and mention this post. I'm not sure what the pricing will be, but he said he'll give a discount and free shipping. Please note this is technically not a group buy, more like a group discount from an external site/vendor. Since he mainly deals with non-Legacies he doesn't have these bushings on his website yet. Also please note that I'm not getting paid for this, I also have no investment in this, I'm just a happy customer spreading the joy . 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Becks1818 Posted January 18, 2018 Share Posted January 18, 2018 Alright those that are interested, send an email to Geoff at geoff@cygnusperformance.com or give him a call at (321) 600-0889 and mention this post. I'm not sure what the pricing will be, but he said he'll give a discount and free shipping. Please note this is technically not a group buy, more like a group discount from an external site/vendor. Since he mainly deals with non-Legacies he doesn't have these bushings on his website yet. Also please note that I'm not getting paid for this, I also have no investment in this, I'm just a happy customer spreading the joy .Emailed earlier today ! No response yet though Sent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
covertrussian Posted January 18, 2018 Author Share Posted January 18, 2018 He takes about a day to reply to me too, calling him is the fastest way to get a hold of him. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
FLlegacy Posted January 18, 2018 Share Posted January 18, 2018 Emailed as well. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
TDWPgtp Posted January 18, 2018 Share Posted January 18, 2018 Any idea on the price range? Are we talking $50, $100, $200, or more? I'm interested if it will solve my clunk, but only if it isn't too much. My wife isn't happy with the money I've spent on the car this year:wub: Link to comment Share on other sites More sharing options...
covertrussian Posted January 18, 2018 Author Share Posted January 18, 2018 Any idea on the price range? Are we talking $50, $100, $200, or more? I'm interested if it will solve my clunk, but only if it isn't too much. My wife isn't happy with the money I've spent on the car this year:wub: Should be around $130, since that's how much the 05-09 kit costs, but might be more since it's new to market. Since I got mine on sale during BlackFriday mine was less then that. I'm hoping the prices should be less then $130 with 5+ people buying at once. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 18, 2018 Share Posted January 18, 2018 Checked my alignment today by hand, w How did you do it? You used the string method? I did my own alignment for the second time this past weekend . Shooting for zero toe, -0.3 deg camber front and -0.9 deg rear. Link to comment Share on other sites More sharing options...
covertrussian Posted January 18, 2018 Author Share Posted January 18, 2018 I use toe plates, my driveway is not level enough for strings to work accurately, and they take way too long to setup. With toe plates I was able to check, and reset my alignment to 1/32" toe in on my lunch break. The key with toe plates is, making sure both outer tie rods are equal distance compared to the inner ones. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
covertrussian Posted January 24, 2018 Author Share Posted January 24, 2018 I found some on a Russian website. Seems like there are a lot of options http://www.polyurethan.ru/es/category/subaru-legacy-1295-1295/all/ I'm not seeing any 2010+ bushings, just the 05-09 ones. Mind direct linking? 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
FLlegacy Posted January 24, 2018 Share Posted January 24, 2018 Got mine in today, gonna be a while before I have time to install. But they are ready! I will have time to maybe gather a fee more parts. Front swaybar, mounts, and links. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted January 25, 2018 Share Posted January 25, 2018 ^ Which caster option did you go with? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FLlegacy Posted January 25, 2018 Share Posted January 25, 2018 ^ Which caster option did you go with?Thus set adds .75 degrees positive caster. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
