MPacMan15 Posted June 12, 2016 Share Posted June 12, 2016 I recently put a 20mm whiteline rear bar on my 09 3.0r with moog end links and really wanted to finish it all off with the avo bracket reinforcements but being 19 and working minimum wage I just couldn't do it. So I decided to try my hand at making myself a set. From looking at pictures of the AVO ones I got an idea of what I needed to do and cut out all the pieces out of some 1/8in sheet metal and some 1 1/4 pipe with a thick washer welded on one end for the subrame mounting bolt. I bolted the pipe into the subframe mount and the flat piece to the bushing mount and tacked them together on the car, took them off and weleded them up. Heres the finished product, all in all this cost me materials and a few hours of work. Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 12, 2016 Share Posted June 12, 2016 Excellent work. Make sure they are good and strong and see my PM. Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted June 12, 2016 Share Posted June 12, 2016 Way to take some initiative. It's always more satisfying to fabricate something yourself. Nice work. Even if they have a weak spot, it should be pretty cheap and easy for you to make a better version. Link to comment Share on other sites More sharing options...
MPacMan15 Posted June 12, 2016 Author Share Posted June 12, 2016 Thanks guys! Just got them put on the car and they bolted right up! Link to comment Share on other sites More sharing options...
coldsoda Posted June 12, 2016 Share Posted June 12, 2016 you considering making a few extra sets ???? Â good work, thanks for the pics. Link to comment Share on other sites More sharing options...
MPacMan15 Posted June 13, 2016 Author Share Posted June 13, 2016 you considering making a few extra sets ????  good work, thanks for the pics.  Yes I actually may make up a jig and make a couple sets up and see what happens, I'm thinking about making a chassis brace next time I can get the car up on a lift for a few hours. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted June 13, 2016 Share Posted June 13, 2016 Good job! Your welds look very good too! I might get in line for a set if you plan to make more. Link to comment Share on other sites More sharing options...
Impulse Posted June 13, 2016 Share Posted June 13, 2016 ^+1, i'd be in line for a cheap pair too! (Yay capitalism?) Link to comment Share on other sites More sharing options...
98legwag Posted June 13, 2016 Share Posted June 13, 2016 Well done. I looked at the pictures first and thought these were the AVO brakets with the finish stripped off. Link to comment Share on other sites More sharing options...
whitrzac Posted June 13, 2016 Share Posted June 13, 2016 Now paint them so they don't rust. Link to comment Share on other sites More sharing options...
MPacMan15 Posted June 13, 2016 Author Share Posted June 13, 2016 Now paint them so they don't rust. They are, there silver. My iPhone camera doesn't show it the best lol Link to comment Share on other sites More sharing options...
theflystyle Posted June 14, 2016 Share Posted June 14, 2016 Also interested  PS - I wish I could have had a car like the 3.0R when I was 19 Link to comment Share on other sites More sharing options...
MPacMan15 Posted June 14, 2016 Author Share Posted June 14, 2016 Since there seems to be some interest I might make 5-10 sets if I can come up with a jig that will keep everything in place where it needs to be, the only thing that you would need to do to install these differently than the AVO ones is the subframe bolt that attaches the bracket is just slightly larger than the tubing that I could find. so instead of having there be a massive space around the bolt head I chose to take a little bit of material off of the flared part of the bolt to have a nice snug fitting bracket. The amount you have to take off the flare of the bolt is very small, probably around 1mm off the diameter. Just wanted to let you guys know that ahead of time. Link to comment Share on other sites More sharing options...
FJuan Posted June 14, 2016 Share Posted June 14, 2016 Count me in. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Akasa Posted June 14, 2016 Share Posted June 14, 2016 Hey, count me in too! This is legit. Just bent my oem bracket Link to comment Share on other sites More sharing options...
henhead Posted June 14, 2016 Share Posted June 14, 2016 Id be in as well. This plus some new MOOG endlinks all around would be nice! Link to comment Share on other sites More sharing options...
pzzamakr1980 Posted June 20, 2016 Share Posted June 20, 2016 I'd be in as well. You don't even have to paint them! Link to comment Share on other sites More sharing options...
ttnio Posted June 20, 2016 Share Posted June 20, 2016 Me three.! Link to comment Share on other sites More sharing options...
oODanKNesSOo Posted June 20, 2016 Share Posted June 20, 2016 Looks clean.. not sure I follow you non the part about the bolt trimming tho? Link to comment Share on other sites More sharing options...
scoobydo2.0 Posted June 20, 2016 Share Posted June 20, 2016 Count me in for a set of these if you decided to make a few, nice work! Link to comment Share on other sites More sharing options...
FJuan Posted June 20, 2016 Share Posted June 20, 2016 He's just saying the tube where you bolt up the bracket is a little tight (the tube that is) and that bolt that goes into the tube would need a little trimming on the edges to make it fit right. Ideally, if he could find a 1 - 2mm larger tube, then there shouldn't be an issue of the bolt. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
JJr Posted June 21, 2016 Share Posted June 21, 2016 Several years ago when it took forever for me to receive my AVO mounts I though about having some made and selling them. Great job OP. make a couple dozen you should be to sell them no problem. Link to comment Share on other sites More sharing options...
MPacMan15 Posted June 22, 2016 Author Share Posted June 22, 2016 Awesome to see there are people interested, hopefully I can start making some sets this weekend Link to comment Share on other sites More sharing options...
Jimblaz Posted June 23, 2016 Share Posted June 23, 2016 id be in for a pair Link to comment Share on other sites More sharing options...
legacyshawn Posted June 28, 2016 Share Posted June 28, 2016 I'm in for a set! Link to comment Share on other sites More sharing options...
