Solgt's "Sleeper Status" Build Thread
Invidia turbo back
Suspension and exhaust install by Andrewtech Automotive
K&N drop in panel filter
Intake resonator removed
Cobb Ap
Tuned to 247whp@6200\330lb-ft tq@4300 @19-20psi by Jermaine@turboxs
While there a Perrin 3port bcs and turboxs recirc bov was added
Everything else stock.
Worked great till stock tmic end tanks let go then a call was placed to Brian at racerx and his tmic was sent out. His charge pipe wasn't available at the time. Still in development phases.
Then head gaskets started leaking and build began.
FMIC FTW will be next.
I'll organise op to better show my progression soon. Hope this helps.
Edited by solgt
  • Replies 240
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
After about 3yrs of and modding figured I'll share.
I drove it stock for a couple months. Flashed the Cobb ots 93 before going further for S&G to see if it really made a difference and suprise! It was. A very welcome one at that.
Part 1.
Suspension:
Tein 2" springs
WhitelineL 22mm front 2way lower sway
WhitelineL 22mm rear 3way lower sway
WhitelineL f/r endlinks
Engine:
Invidia turbo back
Cobb Ap
K&N panel filter
Resonator delete
Perrin 3 port bcs
Grimm ebcs
TurboXS recirc bov
Made 247whp@6200\330lb-ft tq@4300 @19-20psi by Jermaine@turboxs
Intermission
Worked great till stock tmic end tanks let go. Thus call was placed to Brian at racerx and his tmic was sent out. His charge pipe wasn't available at the time. Still in development phases.
Part 2.
Sam and Riyaad, Jacob and of course the guru himself Andrew, deserve HUGE Thanks for making this possible!
With the engine out, heads off, inspection was scrutinized for warping of heads or any other possible major worries. None found so progress insued!
Racing water pump
Timing belt
1000cc ID inj
300lph fuel pump
08 sti oil pump
ARP headstuds
Weisco Pistons
Engine gasket kit
BNR custom 20G
RacerX charge pipe
Crawford air\oil seperator
Perrin tmic coupler
Perrin shifter bushing
Clutch delete both locations
TurboXS rfl bov
Custom Cobb SF intake
Tuned again by Jermaine
350hp\350tq@ 23psi.
So other than the exhaust led marker lights and license plate brackets from AndrewTech nothing cosmetic has yet been done the car.
The BIGGEST THANKS go to the wife for not killing me for building it while she was pregnant!
Thanks guys for reading. I'll post pics and dyno video later
Just curious on the resonator delete?
Sent from my SAMSUNG-SM-G925A using Tapatalk
It's part of the factory intake system. #14.http://uploads.tapatalk-cdn.com/20160905/ad89af9481d24031126f20b11993544d.jpg
Easy removal.
Was it something you wanted to try out?
What is the purpose of the resonator?
Did it increases your airintake?
Back a few years ago, HKS made an intake funnel that would take the resonator's place that did offer a very modest bump in horsepower and slightly cooler intake air temperature. However, as I recently found out, that part has all but vanished from the face of the earth, and any store still listing it as purchasable will not be able to deliver.
This is my factory airairbox looking at it from the bottom. Front facing away. The resonator blocks this opening and reduces that diameter at the bottom of said resonator to a 1-2mm opening. To me that's free horsepower. Definitely not enough to tune for but does allow more airflow to filter. Literally the 1st mod I did.
http://uploads.tapatalk-cdn.com/20160906/b5c4c6a60ea7e474255cce6b1c79b571.jpg
Not to jack your thread but I did the same thing early on and just to be extra careful I cut up an extra filter I had to fit to part of the jug and popped it back in
http://uploads.tapatalk-cdn.com/20160906/215b9a1d4e1b88d09d3af499d6365b60.jpg
You don't need to, this hole is pre-filter.
Very interesting. I thought it would be a torque box or something in that regards.
Water will find its way into just about anything. Even though the chances are small Im not risking getting my dry filter wet. When I removed my jug it was plenty dirty so Im not going to risk getting additional junk in there for the sake of a little sound and air.
I'm pretty sure water can come in through the snorkus while driving normally.
You mentioned the clutch damper delete in both places, Where is the second damper I know about the one by the clutch pedal but where is the other one?
There is a restrictor device of some sort inside the slave cylinder.
