cBax Posted January 31, 2016 Author Share Posted January 31, 2016 Made some progress, I suppose. Today we matched up each piston to the best fitting bore. Then moved onto filing rings. I'll say that this is a fairly tedious process. And I humbly admit that I went over my target gap on the 1st try, even thought it took 8-10 tries, then just like that...over..not sure wtf happened. And Im not sure what I'm going to about it. It's a 2nd ring and it's at .026. My target was .0235. Manley has 2 different piston ring sheets on their site. Assuming the same 3.92 http://www.manleyperformance.com/dl/tech/piston-rings.pdf 3.92*0.007=0.02744 http://www.manleyperformance.com/dl/tech/Subaru-Piston-and-Ring-Installation-04-30-14.pdf 3.92*0.006=0.02352 I was following the Subaru specific instructions. Further searching on nasioc shows others suggesting that the 2nd ring should be opened up a little further anyways. Anyone see any issue running the top rings at .0235 and the 2nd ones all at .026? '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
fahr_side Posted February 1, 2016 Share Posted February 1, 2016 The top ring should have the larger gap. See now why I advised against power tools? Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
cBax Posted February 1, 2016 Author Share Posted February 1, 2016 Ha-ha. I think my "help" was more of a distraction. It's very hard to tell how much you are removing with the grinder. And Ive learned that it's better to start with a smaller feeler gauge, that way you know when you're close as opposed to knowing you went over. All a learning experience... No biggie. Would you suggest a new set of rings? 1st glance said they were $100, but I wonder if that was for a set of 4. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cBax Posted February 1, 2016 Author Share Posted February 1, 2016 2 new sets of rings ordered. $50 chalked up to a learning experience. It seems like the Top vs Bottom ring being larger is different per piston/ring manufacturer. The old Manley instructions said the top was bigger. Now they are the same. CP says the bottom is bigger. I'm just going to target .0235-.024 on them all. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
fahr_side Posted February 1, 2016 Share Posted February 1, 2016 Manley changed the specs for the Subaru pistons a while back. Go with the new instructions. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
cBax Posted February 1, 2016 Author Share Posted February 1, 2016 That was my plan. Hoping to be able to get out there for a few minutes each evening this week and get it done in solitary confinement. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cBax Posted February 4, 2016 Author Share Posted February 4, 2016 Pistons installed. Yes. I know thread is over due for pics. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
FJuan Posted February 5, 2016 Share Posted February 5, 2016 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
cBax Posted February 5, 2016 Author Share Posted February 5, 2016 Potato pics for FJuans enjoyment. DSLR upload soon for the rest of you. Work area http://i641.photobucket.com/albums/uu139/sti__this/OBXT/IMG_20160130_134328302.jpg A couch full of goodies http://i641.photobucket.com/albums/uu139/sti__this/OBXT/IMG_20160130_134348054.jpg Progress http://i641.photobucket.com/albums/uu139/sti__this/OBXT/IMG_20160204_175333215.jpg '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
FJuan Posted February 5, 2016 Share Posted February 5, 2016 Them some nice potatoes. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
cBax Posted February 7, 2016 Author Share Posted February 7, 2016 More pictures. Nothing too informative, just me playing with the camera. I was really concerned about the rod ends riding on the cylinder walls at 1st. Once I got a couple pistons out, the towels became much harder to keep from getting sucked into the crank, so I took them out. Seemed fine.. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0004.jpg This is what I used to pull the wrist pins. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0006.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0010.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0013.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0020-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0023-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0025-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0034-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0054-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0062-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0069-2.jpg Should have it on the stand and get everything aside from one head installed today. Still waiting on a dowel pin. I don't think there is anything stopping me from assembling the bottom end too. I've got a few more things to clean up anyways. AVCS gears, OCVs, a couple hard lines and valve covers. If we break 40 deg, I've got stuff to paint too. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cBax Posted February 7, 2016 Author Share Posted February 7, 2016 Here's a few pictures from today. Sorry about the dark pics. I just realized that my exposure was set to -2 for some reason and I wasn't looking at the previews as I went. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0127-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0132-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0142-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0163_2.jpg Spent a bunch of time cleaning hardware. But I made some progress. Basically just buttoned the bottom end up and started on the front/top. Hopefully be able finish it up next weekend. I figure another 4-6 hours of assembly. And 4-6 hours of installation, along with installing all the gauges. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
seanyb505 Posted February 7, 2016 Share Posted February 7, 2016 The exposure gives a feeling of mystique about the whole thing lol Link to comment Share on other sites More sharing options...
cBax Posted February 8, 2016 Author Share Posted February 8, 2016 I kindof like them too. But I'm not happy about the other 20+ pictures that are useless and now hiding behind the oil pan. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cBax Posted February 8, 2016 Author Share Posted February 8, 2016 can anyone confirm that this is the correct seal for the input shaft on the 5EAT? I think it is....I cant find the specific seal on Heurberger's site and the opposedforces site seems to be down. Is 23070A the Subaru part #? If so, I'll just get it locally. I'd just like to cross reference to whatever the parts guy finds. http://www.makcotransmissionparts.com/23070A.html '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cBax Posted February 12, 2016 Author Share Posted February 12, 2016 High of 9 deg this weekend! Yup, no progress planned. lol I can do mid 20s. But 9 is just too cold. My heaters wont make a bit of difference. Tools hurt to hold at that temp. I really need to put insulation and real heat on the priority list. Of course its supposed to be 45 next Tuesday. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
SCASEYS Posted February 12, 2016 Share Posted February 12, 2016 very nice work Charlie, how far upstate are you? I'm originally from the Sanford area I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
cBax Posted February 12, 2016 Author Share Posted February 12, 2016 Thanks! I'm midcoast area. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cbkenison Posted February 17, 2016 Share Posted February 17, 2016 Subbed. Link to comment Share on other sites More sharing options...
StkmltS Posted February 17, 2016 Share Posted February 17, 2016 Subbed. Welcome to the LGT game My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
cBax Posted February 17, 2016 Author Share Posted February 17, 2016 Subbed. welcome to the party! You know you're in Maine when the shorts come out and the windows go down at the 1st sight of 40 degrees! Loving the forecast and the extra daylight in the evening these days. Hoping to get this project moving along soon so I can get it out of the way and on to the race car before the season starts! I'd hate to postpone this until mid summer. A guy has to have priorities, right? I think I'm a solid weekend away from starting installation. There is quite a bit still to do to the car, but hopefully not much more than another weekend's worth. So very much do-able. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
cBax Posted February 21, 2016 Author Share Posted February 21, 2016 Made some progress today! A blistering 40 deg this morning meant nothing was stopping me from the garage. I didn't get as much done as I had hoped. Amazing how tedious all the cleaning and thread chasing and cleaning and cleaning and cleaning is. I should probably be doubling my time estimates from here on out. haha. I'm having fun. I'm basically just following the vaca pics, chasing the rabbit holes. Got to one point where I remembered you guys talking about a water pipe needing to be done before the heads. Came inside and sorted through tear down pics, saw I removed the small black pipe last and saved myself some frustration by installing it then. thanks! Started out the day with this. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0176-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0205-2.jpg Oil Pump installed http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0215-2.jpg Comparison to old water pump. I wonder if this was stock? http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0222-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0227-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0230-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0234-2.jpg Water Pipe and oil cooler. I still need to mount the cooler. ha! Need to find a 24mm or 1"? deep socket. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0254-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0267-2.jpg RH ARP head studs and OEM head gasket (dry ) going in. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0300-2.jpg RH head w/ Supertech Inconel Exhaust valves and re-used OEM intake valves http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0281-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0285-2.jpg RH cams installed and lubed up http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0310-2.jpg LH side getting ready. I moved the crank off TDC to keep from messing up any valves. I plan to put it back at the last minute when putting the belt on. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0317-2.jpg LH head http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0333-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0337-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0338-2.jpg '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
rebourne Posted February 22, 2016 Share Posted February 22, 2016 Thanks for all these juicy pics! Keep 'em coming! pic thread build thread Link to comment Share on other sites More sharing options...
seanyb505 Posted February 23, 2016 Share Posted February 23, 2016 Looking good. I'm only slightly behind you, but still so far away. Link to comment Share on other sites More sharing options...
cBax Posted February 26, 2016 Author Share Posted February 26, 2016 50 degrees and rain, along with the lack of fires to put out at work yesterday was good enough excuse to take a 1/2 day off and make some more progress. Par for the course, everything is taking forever. Started with this. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0007-2.jpg TIC FU bolts. No clue why Subie didn't do this to begin with. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0016-2.jpg Cleaned the AVCS gears. They don't look like they've been too active. Lots of sludge and definitely some glitter present. I read Underdog's post and took note of the seals and springs, but still managed to toss them across the bench the 1st time I got the rotor to pop out. Funny how the second one always goes smoother. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0020-2_1.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0032-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0045-2.jpg All cleaned up. Oiled everything really good, made sure to put the seal pin holes up and the springs inward. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0056-2.jpg Sometimes you need a helping hand and all you have is a jack stand. I'm pretty sure my chin was involved at one point, but I got it. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0058-2.jpg Company23 timing belt guide http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0064-2.jpg This is where it sits. http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0084-2.jpg http://i641.photobucket.com/albums/uu139/sti__this/OBXT/DSC_0068-2.jpg I'll have some time Saturday morning to put a couple hours in. Hoping to get the fuel system installed and maybe start on the mani. Rest of my weekend is booked. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
