Oldskoolbiker's '08 Outback XT Cosworth, EFR 7153 Build
Posted
I finally got the car back after it spending the last 6 months at Moore Automotive.
After the last engine rebuild I had done at IAG barely lasted a year and was beyond rebuild. I decided to just go all out and have the engine built up to withstand the Track Day's I like to go to. And in true sleeper fashion, I instructed Moore to keep everything stock looking as possible.
I ended up buying this engine that was for sale on NASIOC.
http://forums.nasioc.com/forums/showthread.php?t=2632081
The initial tune it did 411 WHP @21 PSI on 93 pump gas. But the "real tune" will come later after the engine is fully broken in.
I'll be taking it to VIR this weekend so I'll see how it does on track.
Below is my current mod list, and a few pictures.
Engine (Cosworth Longblock)/Drivetrain:
Competition Stage 3 Clutch & Flywheel
Cosworth 79mm Billet Crankshaft
Cosworth EJ25 100mm Forged Pistons
Cosworth High Performance Tri Metal bearings
Cosworth Multilayer Steel Head Gaskets
Cosworth Xtra Heavy Duty Forged Connecting Rods
Cosworth CNC Ported Big Valve - Max Flow Street/Race Cylinder Heads
Cosworth 11mm Heavy Duty Head Studs
Cosworth 1mm over stock Intake and Exhaust Valves
Cosworth Valve Spring & Ti Retainer Set
Crawford Air Oil Separator
Darton Sleeves
Gates Racing Timing Belt & Water Pump
JUN Cam Sprocket Set
Kelford 264/264 Camshaft
NGK Laser Iridium Spark Plugs One Step Colder
SPT Oil Filler Cap
SPT Battery Tie Down
STI Engine Mounts
STI JDM 12mm Oil Pump
STI JDM Top Feed TVG Deletes
Turbocharger & Induction:
Borg Warner EFR 7163 EWG V-Band
DEI T3 Turbo Blanket
ETS FMIC with Moore Automotive Black Piping
GrimmSpeed 3-Port Boost Controller
K&N Air Filter
Moore Automotive Custom CAI
OMNI-Power 3 Bar MAP Sensor
TiAL 44MM MVS External Wastegate
TiAL QR 50MM Blow Off Valve
Fuel & Tuning:
Agency Power Fuel Rail Kit
Cobb Accessport V3
Injector Dynamics Top Feed 1300cc Injectors with Plug and Play adapters
Tuned by Chris Hoover at Moore Automotive
Walbro 255lph Fuel Pump
Cooling:
GMS 160 Degree Thermostat
Mishimoto Performance Aluminum Radiator
Mishimoto Sandwich Plate Adapter
Mishimoto Silicone Radiator Hoses
Moore Automotive Coolant Expansion Tank
Moore Automotive Coolant Overflow Tank
Mocal SS Oil Cooler Kit with Thermostat
Exhaust:
AVO 3” Center Pipe with Resonator
AVO Twin Mufflers
GT Spec GEN II Style Unequal Length Header
Kartboy 12mm Exhaust Hangers
Moore Automotive SS Uppipe
Moore Automotive SS Catless Downpipe
Swaintech White Lightning Coatings
Electrical:
Optima Redtop Battery
Hella Supertone Horn Kit
Morimoto Retro-Quik HID Kit
Morimoto XB LED Turn Signal Bulbs
TapTurn Flasher Relay
Handling:
BBS 2004 STI 17x7.5 +53 Wheels (Street)
Falken Azenis 225/50R17 Tires (Street)
Fortune 510 Coilovers with Swift Spring Upgrade
GT Spec Front Strut Bar
Mach V Awesome 17x9 +42 Wheels (Track)
MOOG Front and Rear End Links
MOOG Wheel Hub Assemblies
Nitto NT-01 255/40ZR17 Tires (Track)
RalliTek Front and Rear Sway Bars
Subaru Legacy GT rear bump stops
Whiteline Adjustable Rear Control Arms
Whiteline LCA and RCA Bushings
Whiteline Roll Center Adjustment Kit
Brakes:
Amsoil Series 600 DOT 4 Racing Brake Fluid
DBA T2 Street Series Slotted Rear Rotors
GrimmSpeed Master Cylinder Brace
Hawk DTC-60 Racing Brake Pads (Hawk HPS for Street)
Rooducts Brake Cooling Ducts
Goodridge Stainless Steel Braided Brake Lines
Racing Brake 332x32mm Slotted Front Rotors
StopTech ST-40 4 Piston Front Calipers
Subaru Legacy GT Rear Calipers
Interior:
AEM Digital AFR Wideband Gauge
Billet Aluminum Pedals
GT Spec Steering Wheel
HP f310 Dash Cam
Kartboy Short Throw Shifter
Kenwood DPX500BT Double DIN In-Dash Car Stereo Receiver
RalliTek Shifter Bushings
Redline Leather Shift/E-Brake Boots
STI Gauge Kit
STI Titanium Shifter Knob
Subaru JDM Twin HVAC Double Din adapter
Tinted Windows 30% Front, 50% Rear
WeatherTech All-Weather Floor Mats
http://dalenet.com/moore/1.jpg
http://dalenet.com/moore/2.jpg
http://dalenet.com/moore/3.jpg
http://dalenet.com/moore/4.jpg
http://dalenet.com/moore/5.jpg
http://dalenet.com/moore/6.jpg
http://dalenet.com/moore/7.jpg
  • Replies 70
  • Created
  • Last Reply
Posted
So, I REALLY wanted to hate on this! LOL! Mainly because your car is over 400whp and mine is not done yet, but there is NO way I could hate on something this flipping sweet!!!! AWESOME setup, Dude!!! Mine should be there soon!
Posted
I'm at VIR this weekend. It's hot here 95 degrees at the track. I spent the first 3 sessions working out bugs, but the last session I did a lap of 2:20 and hit 143 MPH. My cornering was very bad though and car was understeering a lot, so hopefully I'll shave a little off time off tomorrow. The high heat really doesn't help.
I should have some pics and video's pretty soon.
Oh and a rock cracked my windshield. Annoying....
Posted
Video of my fastest lap at VIR this weekend. 2:17 lap with top speed of 140 MPH. It was hot and sunny with temps over 90 degrees. That didn't help with car power or grip.
Posted
I'm fine with the 5 Speed for now until it breaks then I'll upgrade to a 6 speed.
As far as heel toe, no I haven't gotten it down yet on the track. I've been practicing on the street, but it's not second nature yet.
Posted
Any issues with getting the power down through the corners? I remember reading that Boxkita mentioned at 340ish whp coming out of turns he couldn't get the full power down and needed a LSD.
  • 1 month later...
Posted
Watching the video, it looks like boost comes in at too high rpm so the lack of LSD never becomes an issue.
If you shift down one more gear, the turbo will still be on boost and you'll be able to accelerate sooner/faster coming out of the corners.
If you want the 5 speed to last with that much power, don't rush the shifts.
I looked at this motor setup before deciding to spend less on my build. I'm sure my 5mt would have failed a lot sooner on this build.
What's the rattling noise when you get on the gas? Is that the turbo spooling up?
Posted
@Nightmaresmk: The car made 434 WHP and 430 WTQ when I got the final tune done. This was on just 93 pump gas. I'm sure I could make more on e85, but I'd need a bigger fuel pump and bigger fuel lines for that. I'm satisfied with the power level. My only complaint is it's bit slow to spool up. It really doesn't kick in until 3700 RPM or so.
@boxkita: Not sure what the rattling sound is you're talking about unless it's the sound of the EWG you're referring to. I am getting some suspension rattling, seems ball joints got a little play. Putting in a new Whiteline kit in a couple of weeks. As far as the shifts at VIR, I was short shifting a bit to keep the RPM's a little lower as it was about 95 degrees that day and that helped keep the engine cooler. Couple of spots like the oak tree turn 2nd gear would be ideal but it's difficult to smoothly get it down to second so I usually just stay in third (although that's like a 35-40 MPH turn). So I just need more practice. I recently made my brake pedal a little higher to help with heel toe downshifting.
The car currently has a few minor issues which still need some attention:
Suspension Rattle (need new ball joints)
Front Camber: Driving one day the camber on my drivers front went from negative to positive. Took it in and turns out the Fortune Coilovers aren't drilled to accept the eccentric camber bolt. Moore had just put in a straight through bolt and expected just the friction of the bolt being tight to hold the camber. Obviously that didn't work. So when I'm getting the new ball joints they are going to drill out the mounting holes on the coilovers to accept the camber bolt. No idea why the Fortune's didn't make the hole big enough on the one side to accept the camber bolt.
Coolant Overflow Tank is too small and overflowed at the track. Need to get a larger tank made. OEM tank won't fit anymore because of FMIC piping.
Headlight fogging up: I had a HID conversion done on my headlight and had the orange reflectors removed. Now one of the headlights is getting water in it when it rains. I already took it off and put silicone around the seal, but that didn't work, so need to take it off again and do it really good next time.
Right now I'm planning to take the car to VIR in Sept and Summit Point in November.
Posted
the noise I heard sounded like the turbo. My hta68 makes noise when spooling.
Having to get to 3700rpm to be on boost with the larger turbo (side effect), you'll want to be 1 gear lower to keep the turbo on boost going thru a corner. The long delay in acceleration coming out of the corners is turbo lag. If you went to a smaller turbo, you'd spool sooner. Or you can change your tuning to make a flatter torque curve (more or a plateau) or move the peak earlier in the rpm band.
If VIR is your favorite track, then adjust your tuning to match the track.
Drilling out the fortune's - get Vorschlag / similar camber plates. You'll get far more adjustability without hacks. The eccentric camber bolt is a hack :-)
If you soften the rear sway bar and stiffen front one, you should push less coming out of the corners.
KillerB makes a nice overflow tank as well as an upper tank. Spendy but nice work
  • 2 weeks later...
  • Moderators
Posted
Nice video, Delmar. I'm not much of a suspension junkie, but do the Fortune's really match up with the rest of your build and the track time that your car sees?
Edit: So many people whining about the sound of your car. Turbos make that noise even with IWGs (mine does with a 16g) and it's completely normal. So many youtube trolls who have zero clue what they are hearing / talking about.
Not currently in stock :(
