alyolles Posted January 22, 2015 Share Posted January 22, 2015 Hey guys, was watching a video on YT and found out about the Bee Racing Rev Limiter http://www.nengun.com/bee-r/rev-limiter. Does anybody have this/ know if this works with the 05 5EAT? Kinda interested in this, would like to know if anybody thinks it would cause any harm to any parts or it would it would be fine... Kinda want to spit flames Link to comment Share on other sites More sharing options...
Leviman Posted January 22, 2015 Share Posted January 22, 2015 How would you use it on a 5EAT? The point is that you bring the motor to that rev limit, then drop the clutch and voila, launch control. I believe you can also have it programmed into your ECU. Link to comment Share on other sites More sharing options...
ras06LGT Posted January 22, 2015 Share Posted January 22, 2015 The car already has a rev limiter from the factory (obviously). The "benefits" of ignition vs. fuel cut for a daily driver is highly debatable, and if you are hitting the rev limit enough for it to matter, you're doing it wrong. Racing applications hit the rev limiter much more often, so this could be a benefit. If you just want flames, tee off the fuel line from the pump and dump it in the exhaust (don't actually do this, also should be obvious). Link to comment Share on other sites More sharing options...
MrTris Posted January 22, 2015 Share Posted January 22, 2015 Psssh, you don't want flames, that's well, for flamers. (you know) You need [ame=http://www.amazon.com/Morris-Trick-Exhaust-Whistle/dp/B0006GK1XY]Whistle Tips[/ame]. So. Gangsta. Link to comment Share on other sites More sharing options...
whitetiger Posted January 22, 2015 Share Posted January 22, 2015 :facepalm: Link to comment Share on other sites More sharing options...
MrTris Posted January 22, 2015 Share Posted January 22, 2015 :facepalm: The whistle go WOO WOO! Link to comment Share on other sites More sharing options...
nielsonluther Posted November 2, 2015 Share Posted November 2, 2015 I'm new to the car world and want the same thing. Does anyone know if it will work on a 98 legacy GT? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 2, 2015 Share Posted November 2, 2015 Oh Dear...here we go. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
magnusonsubie Posted November 2, 2015 Share Posted November 2, 2015 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
battelready Posted November 3, 2015 Share Posted November 3, 2015 Honestly wanted to add a turbo whistle because my existing turbo whistle isn't loud enough. Also best way to flames is run no cats and put a spark plug in the exhaust. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
boxkita Posted November 4, 2015 Share Posted November 4, 2015 Honestly wanted to add a turbo whistle because my existing turbo whistle isn't loud enough. Also best way to flames is run no cats and put a spark plug in the exhaust. add a boat horn to the existing one. If that's not enough, add a secondary compressor that fires a truck horn when the turbo whistle starts. If all else fails, a scuba tank will power a train horn. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Phate Posted November 4, 2015 Share Posted November 4, 2015 Delete cats, run straight-through muffler, vent BOV to atmosphere. Car will go pig rich on gear changes, and unburned fuel will end up in the exhaust. Should shoot nice fireballs. None of this will really happen on an automatic though. Link to comment Share on other sites More sharing options...
battelready Posted November 4, 2015 Share Posted November 4, 2015 add a boat horn to the existing one. If that's not enough, add a secondary compressor that fires a truck horn when the turbo whistle starts. If all else fails, a scuba tank will power a train horn. Im guilty of fitting a train horn to my truck before. It shook the ground . I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
boxkita Posted November 4, 2015 Share Posted November 4, 2015 Im guilty of fitting a train horn to my truck before. It shook the ground . Lol. Not saying the scuba tank was a good idea. we tested it inside tye garage. didn't think I d ever hear again Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
quick4dr Posted November 4, 2015 Share Posted November 4, 2015 Delete cats, run straight-through muffler, vent BOV to atmosphere. Car will go pig rich on gear changes, and unburned fuel will end up in the exhaust. Should shoot nice fireballs. None of this will really happen on an automatic though. Not true, i have thrown fire on a few occasions given the right throttle lift off and VTA little over 50:50 Link to comment Share on other sites More sharing options...
MTBwrench Posted November 4, 2015 Share Posted November 4, 2015 OP, it seems for what you want, a neutral drop is the best idea. (Only joking, please never ever ever ever neutral drop your trans.) Sub'd for the lulz. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
battelready Posted November 4, 2015 Share Posted November 4, 2015 OP, it seems for what you want, a neutral drop is the best idea. (Only joking, please never ever ever ever neutral drop your trans.) Sub'd for the lulz. Nahhh, brake and boost it till 3500k rpm and hope the rear diff dosnt grenade . I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
Cesar Posted January 1, 2018 Share Posted January 1, 2018 somebody could help me. I want to install the bee r rev limiter in my subaru legacy gt 2005 but I can not find any diagram to install it to the computer. someone to pass me the diagram? Link to comment Share on other sites More sharing options...
whitetiger Posted January 1, 2018 Share Posted January 1, 2018 dont do it. Link to comment Share on other sites More sharing options...
boxkita Posted January 4, 2018 Share Posted January 4, 2018 somebody could help me. I want to install the bee r rev limiter in my subaru legacy gt 2005 but I can not find any diagram to install it to the computer. someone to pass me the diagram? somebody could help me. I want to install the bee r rev limiter in my subaru legacy gt 2005 but I can not find any diagram to install it to the computer. someone to pass me the diagram? First two posts are to add a rev limiter on top of stock? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
biggreen96 Posted January 18, 2018 Share Posted January 18, 2018 dont do it. Do it. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted January 19, 2018 Share Posted January 19, 2018 went to Costco last night and bought a whole case of popcorn for this one! Link to comment Share on other sites More sharing options...
