gordata Posted October 9, 2014 Share Posted October 9, 2014 I thought the air temp sensor was in the maf (pre-turbo, pre-intercooler)? Or did you relocate yours or something? heiche - If he is running proper speed density setup, his IAT sensor should be right before the throttle body after intercooler. Sent from my A0001 using Tapatalk Link to comment Share on other sites More sharing options...
Doogie29th Posted October 9, 2014 Author Share Posted October 9, 2014 no maf here....speed density tune. sensor is tapped into fmic piping before throttle body Link to comment Share on other sites More sharing options...
Doogie29th Posted October 9, 2014 Author Share Posted October 9, 2014 might be able to see in this pic... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 9, 2014 Share Posted October 9, 2014 might be able to see in this pic... Man this intake manifold looks gorgeous Link to comment Share on other sites More sharing options...
heiche Posted October 9, 2014 Share Posted October 9, 2014 Ah, I see! thanks guys. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
gordata Posted October 9, 2014 Share Posted October 9, 2014 Anyone working on upgraded axles. Sent from my A0001 using Tapatalk Link to comment Share on other sites More sharing options...
Doogie29th Posted October 9, 2014 Author Share Posted October 9, 2014 http://legacygt.com/forums/showthread.php/specb-rear-axle-bar-upgrade-227659.html Strizzy is working on the upgrade Link to comment Share on other sites More sharing options...
jslayz Posted October 10, 2014 Share Posted October 10, 2014 Very excited to see the 'chopsticks' that are used as axles on liberty's be replaced. Would Water to air be an option as that is a high IAT..? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 10, 2014 Share Posted October 10, 2014 Very excited to see the 'chopsticks' that are used as axles on liberty's be replaced. Link to comment Share on other sites More sharing options...
s2baru Posted October 13, 2014 Share Posted October 13, 2014 LOVING EVERY BIT OF THIS!!! Good gracious!!!! Just going through breakin on my outfront block with similar internals. Haven't selected a turbo yet but EFRs are high on the list. Not going quite this high of HP for a goal but at least I know what the block is capable of. Keep after it! 10s are in your future (waves magic wand) Link to comment Share on other sites More sharing options...
loogie Posted October 14, 2014 Share Posted October 14, 2014 i use this word rarely, epic. love the car color too Link to comment Share on other sites More sharing options...
jmorris6689 Posted October 16, 2014 Share Posted October 16, 2014 I have the same issue with the rear axles in my legacy. I ran that 11.668 then on my third pass snapped the rear axle. I have some empi front axles but didn't feel like paying dss for them to fabricate some rear axles. Link to comment Share on other sites More sharing options...
Doogie29th Posted October 16, 2014 Author Share Posted October 16, 2014 I already have gone to dds and they can't make spec b rears. Strizzy is working on the upgraded rears as we speak. Link to comment Share on other sites More sharing options...
jmorris6689 Posted October 16, 2014 Share Posted October 16, 2014 Yeah I read the thread, I'm probably going to order a set soon, I was surprised at how cheap they are! What are you doing for a drive shaft? Link to comment Share on other sites More sharing options...
Doogie29th Posted October 17, 2014 Author Share Posted October 17, 2014 Strizzy has the aluminum 1 piece drive shaft covered too. I have an oem spec b drive shaft now. Link to comment Share on other sites More sharing options...
jmorris6689 Posted October 17, 2014 Share Posted October 17, 2014 Sweet thanks for the info! Link to comment Share on other sites More sharing options...
LatentWagen Posted October 20, 2014 Share Posted October 20, 2014 Is the DriveShaft Shop still around? That was the go-to shop back when... might be able to hook you up while other options are sorted. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Doogie29th Posted October 20, 2014 Author Share Posted October 20, 2014 I already have gone to dds and they can't make spec b rears. Strizzy is working on the upgraded rears as we speak. Link to comment Share on other sites More sharing options...
LatentWagen Posted October 20, 2014 Share Posted October 20, 2014 Should've realized that's what you meant. Obviously, dentists can't make axles. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
gordata Posted October 20, 2014 Share Posted October 20, 2014 Doogie29th - Why couldn't DSS make the axle? Sent from my A0001 using Tapatalk Link to comment Share on other sites More sharing options...
Doogie29th Posted October 20, 2014 Author Share Posted October 20, 2014 I don't know why. I worked with them for several months. I sent them an axle and the answer was no. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 16, 2014 Share Posted November 16, 2014 They are making axle for a Spec B, I'm trying to find the thread about them now. I was reading about them a few days back. It was from Mary at AWD Tuning. Her Spec B runs low 11's http://legacygt.com/forums/showthread.php/driveshaft-shop-axles-legacys-232880.html?t=232880&highlight=grimlin 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gordata Posted November 16, 2014 Share Posted November 16, 2014 They are making axle for a Spec B, I'm trying to find the thread about them now. I was reading about them a few days back. It was from Mary at AWD Tuning. Her Spec B runs low 11's http://legacygt.com/forums/showthread.php/driveshaft-shop-axles-legacys-232880.html?t=232880&highlight=grimlin $1800 option. These are pro level axles, more then enough axle for any legacy on this board. They need to make stage 3.9 or 5.9 which should not be more then $1000. I am not ready to drop 2gs on axles at this moment but it's good that a option like this exist, working in the right direction to make more parts for the legacy. Sent from my Nexus 7 using Tapatalk Link to comment Share on other sites More sharing options...
Strizzy Posted November 17, 2014 Share Posted November 17, 2014 Her axles require new rear hubs. The axles that I have been working on for the last few months are almost complete and will use your existing hubs. They will be a drop in replacement and will be a much better price than the ones through DSS. My bad luck build Link to comment Share on other sites More sharing options...
gordata Posted November 17, 2014 Share Posted November 17, 2014 Her axles require new rear hubs. The axles that I have been working on for the last few months are almost complete and will use your existing hubs. They will be a drop in replacement and will be a much better price than the ones through DSS. Nice! Sent from my Nexus 7 using Tapatalk Link to comment Share on other sites More sharing options...
