FJuan Posted November 1, 2015 Share Posted November 1, 2015 Are you gonna be running corn the whole time? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 1, 2015 Author Share Posted November 1, 2015 Probably not, 91 mostly. The nearest Corn station(basically my only station) is the opposite way of my daily drive, but its only 3 miles away from home. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 1, 2015 Author Share Posted November 1, 2015 Removed my injector dynamics side feed to top feed conversion fuel rails. Remove my side feed to top feed conversion ID1000cc injectors. Removed my factory TGVs. Installed my zero lift TGV deletes. Installed my Fuel Injector Clinic OEM style top feed fuel rails. Installed my OEM style top feed ID 1000cc injectors. Installed my flex fuel module. http://images.tapatalk-cdn.com/15/11/01/c769fb260a43bc3309c6044f5fc40df6.jpg http://images.tapatalk-cdn.com/15/11/01/c7609acf18a38f521a49e97beb78831c.jpg Got it all back together. http://images.tapatalk-cdn.com/15/11/01/8a81e2c0b417f38046d41f0393325cf3.jpg Base tune still needs changes. http://images.tapatalk-cdn.com/15/11/01/fd4f7297122003ffcf8b673e053b7a34.jpg For sale thread coming. http://images.tapatalk-cdn.com/15/11/01/4c08daa78307c2d2ef4aa1d2744a36d2.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
rhino6303 Posted November 1, 2015 Share Posted November 1, 2015 Removed my injector dynamics side feed to top feed conversion fuel rails. Remove my side feed to top feed conversion ID1000cc injectors. Removed my factory TGVs. Installed my zero lift TGV deletes. Installed my Fuel Injector Clinic OEM style top feed fuel rails. Installed my OEM style top feed ID 1000cc injectors. Installed my flex fuel module. Were you able to install by just rocking the manifold or did you just remove the intake manifold? Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 1, 2015 Author Share Posted November 1, 2015 I did leave the manifold attached to the car, but I pretty much had so much removed I could have just pulled it out anyway. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Rhitter Posted November 5, 2015 Share Posted November 5, 2015 How much power do you expect to be making on corn and any reason you stuck with the OEM TMIC? My OBXT build Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 5, 2015 Author Share Posted November 5, 2015 Honestly, i don't know. Only goal I had was 300wtq or higher. If I can make 300whp, that'd be pretty awesome too though. It's my daily, I just wanted something "peppy" that I can jump in front of most cars from a stop light or freeway meter. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 5, 2015 Author Share Posted November 5, 2015 How much power do you expect to be making on corn and any reason you stuck with the OEM TMIC? To be able to pas smog and it should work just fine with my vf40. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 16, 2015 Author Share Posted November 16, 2015 Well, got the idle dialed in on my 91 base tune. Maybe tomorrow I'll be able to get a little cruising Tuning done. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted January 2, 2016 Author Share Posted January 2, 2016 Hoping to get an email next week about making an appointment to get the tune dialed. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted February 16, 2016 Author Share Posted February 16, 2016 Well got tuned a week ago. rand two+ tanks of corn through it. getting rough starts for a bit and then idles fine(warm or cold) already emailed logs to Bill. Had some Knock on a 3rd gear pull the other day where i was able to feel the car surging from it. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 1, 2016 Author Share Posted April 1, 2016 Got some tires today. Kumho ECSTA PA31 225/45R17 Getting them put on in the morning. Saw this at the front door when I got home. http://uploads.tapatalk-cdn.com/20160401/16ab5d0dd70dad3f7dbad56db959ea21.jpg Shoved then in the back seat. http://uploads.tapatalk-cdn.com/20160401/c806779f75b6cb2ce0d2f646c4cda25b.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Rhitter Posted April 1, 2016 Share Posted April 1, 2016 Well got tuned a week ago. rand two+ tanks of corn through it. getting rough starts for a bit and then idles fine(warm or cold) already emailed logs to Bill. Had some Knock on a 3rd gear pull the other day where i was able to feel the car surging from it. How is the tune going? Getting it all worked out? My OBXT build Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 1, 2016 Author Share Posted April 1, 2016 I go back down on the 18th with the new MAF to get retuned. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 5, 2016 Author Share Posted April 5, 2016 Got this a few days ago. http://uploads.tapatalk-cdn.com/20160405/61d82a11f171b91766e6786f4628da49.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 9, 2016 Author Share Posted April 9, 2016 Oh, and the company 23 3 port electronic boost controller (flutter fixer) should show up on the 13th. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 13, 2016 Author Share Posted April 13, 2016 Finally got my fuel pump rewire in the car and working.(had it since Christmas) Went for a test drive of course...only the 2nd time I've driven it with the GS intake. Hoping boost controller shows tomorrow. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 14, 2016 Author Share Posted April 14, 2016 Company 23 (anti-flutter) electronic boost controller showed up today! http://uploads.tapatalk-cdn.com/20160414/27fa6fab5d9faf61bc7f28da57030d0e.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
gkinslow Posted April 14, 2016 Share Posted April 14, 2016 sub'd for corn updates. Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 14, 2016 Author Share Posted April 14, 2016 I really wish I had a proper video camera... "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted April 14, 2016 Share Posted April 14, 2016 You seem to have enough money for parts, why not invest in a better camera? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 14, 2016 Author Share Posted April 14, 2016 You seem to have enough money for parts, why not invest in a better camera? Because parts > camera right now. Camera won't get me to work. Also, I don't have a camera, only cell phone...so technically I need a new phone. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted April 14, 2016 Share Posted April 14, 2016 Get it together ButTBeaR. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted April 18, 2016 Author Share Posted April 18, 2016 http://uploads.tapatalk-cdn.com/20160418/7360ac92b9456fe166211d1855c7519c.jpg Got the pig all washed up for her date today for a tune with Bill from delicious and some dyno Time with Mike and infamous. On my way there now. Only 70 more miles down I-15. I'm installing my company 23 ASBCS in Mike and Bills parking lot right now lolhttp://uploads.tapatalk-cdn.com/20160418/7a9fbd872df260b43c7e3655cc9144a8.jpg Update, getting dyno tuned! http://uploads.tapatalk-cdn.com/20160418/133bb11eeb0ab12c572e528d1a87257f.jpg New MAF in, new boost controller in, should be all set. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted April 18, 2016 Share Posted April 18, 2016 Are you rocking the man bun? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
