acumenhokie Posted April 26, 2015 Share Posted April 26, 2015 Any pics of your setup? http://legacygt.com/forums/attachment.php?attachmentid=183943&d=1401390004 Link to comment Share on other sites More sharing options...
jackal8788 Posted April 26, 2015 Author Share Posted April 26, 2015 For those with an EWG, what wastegate and BCS are you running? VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
jackal8788 Posted April 27, 2015 Author Share Posted April 27, 2015 Thinking I would be ordering something like the following (thanks to jojorios for compiling this original list): OEM Replacement Parts: 2 GASKET-EXHAUST MANIFOLD 14038AA000 1 GASKET-EXHAUST TURBO OUTLET 44616AA150 Couple Of Extra: STUD-10X44X12 800910580 BOLT-10X35X26 800110620 SELF LOCKING NUT 902350001 FLANGE NUT 902370010 EWG Header (Exact Version TBD) (Qty TBD based on Header) - Tial MV-S 38mm wastegate Mazdaspeed3 BCS 771750 Am I missing anything or screwing anything up? VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
jojorios Posted April 27, 2015 Share Posted April 27, 2015 Thinking I would be ordering something like the following (thanks to jojorios for compiling this original list): OEM Replacement Parts: 2 GASKET-EXHAUST MANIFOLD 14038AA000 1 GASKET-EXHAUST TURBO OUTLET 44616AA150 Couple Of Extra: STUD-10X44X12 800910580 BOLT-10X35X26 800110620 SELF LOCKING NUT 902350001 FLANGE NUT 902370010 EWG Header (Exact Version TBD) (Qty TBD based on Header) - Tial MV-S 38mm wastegate Mazdaspeed3 BCS 771750 Am I missing anything or screwing anything up? Just in case your interested: http://legacygt.com/forums/showthread.php/ny-grimmspeed-mazdaspeed3-ebcs-239220.html I'm waiting 10k to do the header install but I also ended up getting buying the Grimmspeed Adjustable IWG Bracket (sku 010019). Not sure if its 100% needed, but just in case, I didn't want to weld anything. Link to comment Share on other sites More sharing options...
jackal8788 Posted April 27, 2015 Author Share Posted April 27, 2015 Just in case your interested: http://legacygt.com/forums/showthread.php/ny-grimmspeed-mazdaspeed3-ebcs-239220.html I'm waiting 10k to do the header install but I also ended up getting buying the Grimmspeed Adjustable IWG Bracket (sku 010019). Not sure if its 100% needed, but just in case, I didn't want to weld anything. Thanks! Is this BCS also plug n play with our stock wire harness? VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
SomeZero Posted April 27, 2015 Share Posted April 27, 2015 I will sell mine soon. Just need my new one done I should have a date shortly Sent from my SHIELD Tablet using Tapatalk Link to comment Share on other sites More sharing options...
jackal8788 Posted April 27, 2015 Author Share Posted April 27, 2015 I will sell mine soon. Just need my new one done I should have a date shortly Sent from my SHIELD Tablet using Tapatalk You mean you will be selling your header? Let me know if this is happening. Enabling must continue! VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
jojorios Posted April 27, 2015 Share Posted April 27, 2015 Thanks! Is this BCS also plug n play with our stock wire harness? Yeah, this is the one compatible with ours. Link to comment Share on other sites More sharing options...
s2baru Posted April 27, 2015 Share Posted April 27, 2015 I will sell mine soon. Just need my new one done I should have a date shortly Sent from my SHIELD Tablet using Tapatalk Sooo....I know this guy. <-----++ Link to comment Share on other sites More sharing options...
jackal8788 Posted April 27, 2015 Author Share Posted April 27, 2015 It begins - just ordered the EBCS from jojorios. I'm checking with a couple shops around here on the possibility of fabbing up something custom or modifying the stock headers. Also may move on SomeZero's header depending on what I come up with here. I keep thinking about the stock setup and the ETS option - wouldn't it be possible to have two tubes welded to the stocker just like ETS? I haven't looked at it in any detail so I might be missing something but the concept seems possible.... VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
BigBopper Posted April 27, 2015 Share Posted April 27, 2015 The OEM header is double wall piping, which may make modifications unreasonable. Link to comment Share on other sites More sharing options...
acumenhokie Posted April 27, 2015 Share Posted April 27, 2015 The OEM header is double wall piping, which may make modifications unreasonable. ^^^^^This Be sure you mention that to any shops you talk to about custom fabrication. It's not really possible to modify the stocker. Link to comment Share on other sites More sharing options...
jackal8788 Posted April 29, 2015 Author Share Posted April 29, 2015 Continuing down the path of part procurement, I've noticed that a lot of EWG setups with EBCS have a fluttery sound due to the cycling of the boost solenoid. One way to eliminate this is by using a manual boost controller. Is anyone else running EWG with an EBCS that does not experience the fluttering or is this inherent in that configuration? VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Rutchard Posted April 29, 2015 Share Posted April 29, 2015 Unfortunately that's just how it's going to be with the way the EBCS cycles. MBC all the way. Link to comment Share on other sites More sharing options...
jackal8788 Posted April 29, 2015 Author Share Posted April 29, 2015 That's what I was expecting to hear. So I will likely be selling the EBCS I just bought from jojorios and picking up an MBS instead. There are a crapload out there - any recommendation on something you've had good luck with or something to avoid? VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
jojorios Posted April 29, 2015 Share Posted April 29, 2015 I was also looking at the MBC, but the tuner was really not a big fan of them and suggested EBCS. Something about it being a pain with temperature changes. That's how I ended up getting the EBCS. When I was looking into this I also came across a hybrid setup that uses both and MBC and EBCS, which didn't look like it creates the flutter. Link to comment Share on other sites More sharing options...
jackal8788 Posted April 29, 2015 Author Share Posted April 29, 2015 I'll have to do more research on this as I really don't like the flutter sound at all. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
fahr_side Posted April 30, 2015 Share Posted April 30, 2015 Plumb the wastegate dump back into the exhaust system. Problem solved. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 1, 2015 Author Share Posted May 1, 2015 Talked to my tuner a little more and he recommended a hybrid setup with both MBC and EBCS. MBC will control peak boost while the EBCS allows for boost taper at upper RPM and boost cut in case of knock as shown: VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Rutchard Posted May 1, 2015 Share Posted May 1, 2015 Best of both worlds, looks good! Link to comment Share on other sites More sharing options...
jojorios Posted May 1, 2015 Share Posted May 1, 2015 Talked to my tuner a little more and he recommended a hybrid setup with both MBC and EBCS. MBC will control peak boost while the EBCS allows for boost taper at upper RPM and boost cut in case of knock as shown: Did your tuner mention anything about temperature change affecting the MBC in this setup? I really wish I had a local subie shop/tuner I could fully confide in. The subie shop I used is the only one I know of locally that has a good rep, but when I asked about the MBC and the hybrid setup, they pretty much told me they won't do it because the MBC can be a pain with the seasons. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 1, 2015 Author Share Posted May 1, 2015 Did your tuner mention anything about temperature change affecting the MBC in this setup? I really wish I had a local subie shop/tuner I could fully confide in. The subie shop I used is the only one I know of locally that has a good rep, but when I asked about the MBC and the hybrid setup, they pretty much told me they won't do it because the MBC can be a pain with the seasons. No, he didn't. In fact, he said this is the setup he recommends most highly for those who want/need precise boost control and that it is what he runs on his own Legacy. I guess I don't understand how temperature could have any effect on a manual boost controller. The controller is just staying closed until the spring cracking pressure is reached, then it opens up. Since the spring cracking pressure won't be influenced by temperature (within the range of temperatures it's going to see in real-world use) or atmospheric pressure, the boost setting shouldn't change either. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Rutchard Posted May 3, 2015 Share Posted May 3, 2015 I think it's less of the cold actually affecting the MBC itself, but more how turbos just seem to generate a lil more boost when they're fed extra cold & dense air. Link to comment Share on other sites More sharing options...
BBPeik Posted May 3, 2015 Share Posted May 3, 2015 I wouldn't think temp would have much affect either. Even though in cold weather the dense air creates more boost the mbc is pretty simple. Pressure makes it open and that is that. I would be interested to hear more about the shops theory on weather making that setup a pain. Hmmm My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 3, 2015 Author Share Posted May 3, 2015 Agree. More dense air = potentially greater pressure but the controller doesn't care whether the boost is due to air density or air volume being compressed. It just has a setpoint at which it will open. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
