Matt Walter Posted September 14, 2014 Author Share Posted September 14, 2014 here was my day: chummy: no pictures of the new trans installed. not really that interesting looking anyway. the car drives great now took about 9 hours start to finish. Link to comment Share on other sites More sharing options...
erickrocks1126 Posted September 14, 2014 Share Posted September 14, 2014 Glad it's running again! Link to comment Share on other sites More sharing options...
Matt Walter Posted September 15, 2014 Author Share Posted September 15, 2014 i found a picture online of what i'm talking about. the rear cam "plate" (for lack of a better term) on the passenger's side of the engine is leaking. What is this called, and what will i ask for at the parts store to replace whatever is leaking under it? i believe i can get to this and reseal this from the top, but noticed it when i had the trans out this past weekend. any information is appreciated http://i1014.photobucket.com/albums/af262/Rugby_boy101/PassengerSideRearo-ring.jpg Link to comment Share on other sites More sharing options...
scontivt Posted September 15, 2014 Share Posted September 15, 2014 I believe that is a spot for a distributor. I'm not 100% certain, but I believe it is just hi-temp silicone there, but I have never taken that piece off before. Link to comment Share on other sites More sharing options...
johnegg Posted September 16, 2014 Share Posted September 16, 2014 the rear cam "plate" (for lack of a better term) on the passenger's side of the engine is leaking. What is this called, and what will i ask for at the parts store to replace whatever is leaking under it? the is generally referred to as a cam cap. and it needs a cam cap o-ring to cure the leak. it is the same oring used on the driver side head in the front. only that ''cam cap'' has the shaft coming thru it with the sprocket. the cam cap covers the hole where the cam shaft is inserted into the head. look for the part display and number at Subaru parts catalog Link to comment Share on other sites More sharing options...
Matt Walter Posted September 16, 2014 Author Share Posted September 16, 2014 sweet! looks like it's part number 806946030 for future reference. i'll see about picking one up at some point. should i lay down any RTV with it? so far, i believe my rear engine separator plate is leak free when i put the new trans in, i used the shifter linkage that came with the trans, which was also missing the bushings. i did a new steel bushing/washer combo as the old setup rattled like crazy. it's sloppier than my first attempt though. i think i will break down and buy the correct shifter bushings. the car drives fantastically other than that. glad to have my gas saver back. driving my 2000 silverado the 110 miles daily was taking a serious toll on my wallet. Link to comment Share on other sites More sharing options...
Matt Walter Posted September 23, 2014 Author Share Posted September 23, 2014 what's everyone's thoughts on flat black for an exterior? mild drop and tinted windows. oh, i picked up a new rear taillight panel for the hatch as mine is cracked in multiple places, as well as a GT rear spoiler, which i'm actually pretty pumped about. Link to comment Share on other sites More sharing options...
Matt Walter Posted September 24, 2014 Author Share Posted September 24, 2014 spoiler and rear taillight panel installed. turned out alright. needs moar low Link to comment Share on other sites More sharing options...
twisty Posted September 24, 2014 Share Posted September 24, 2014 did you take pics and/or save the measurements? i am going to put mine on soon as well, but i havent taken the time to get the fine details for it yet. Link to comment Share on other sites More sharing options...
Matt Walter Posted September 24, 2014 Author Share Posted September 24, 2014 no, i just put some painters tape on the hatch, put the spoiler where i wanted it and made impressions in the tape, then drilled. the factory holes are slotted for alignment, so i made mine slotted with a dremel tool. having a welder and basic fabrication skills makes doing things like drilling holes in the car not a scary thing for me. Worst case scenario, i just weld them back up, lol. Link to comment Share on other sites More sharing options...
twisty Posted September 24, 2014 Share Posted September 24, 2014 lol true, im not terribly afraid of doing it, just like to get as much info as i can before cutting stuff up. i did find the original install instructions at one point, has measurements and a template. Link to comment Share on other sites More sharing options...
Matt Walter Posted September 24, 2014 Author Share Posted September 24, 2014 that would have been nice. i drilled, then got the dremel out and started elongating the holes till i could bolt it down and open the hatch without interference. The hatch had to be adjusted a little too to clear. at one point i got the spoiler stuck between the hatch and the roof of the car and it split the paint, but the car is going to get repainted at some point so it doesn't bother me much. it's completely unnoticable unless you're right ontop of it. Link to comment Share on other sites More sharing options...
Matt Walter Posted April 7, 2015 Author Share Posted April 7, 2015 after 20,000 miles of daily commuting since July of last year, the engine caught fire on my way to work last friday. As far as i can tell, the timing belt idler pulley seized, causing the belt to smoke and eventually break. the heat caught the oil gunk on the timing cover from a long term oil leak on fire. passenger's side of the timing case is pretty charred. the timing belt cover is melted. not sure what my long term solution is going to be....it may be to part the car and buy another, lol. with my gm background, i'm very tempted to throw this spare 5.3 and t56 in the car, but i lose my front wheel assist. no decisions have been made. thus far i have pumped the fuel out of it and taken a 5 minute gander at the fire damage. otherwise, it's sitting on my trailer waiting for garage space. sigh.... Link to comment Share on other sites More sharing options...
Zues Marine Posted April 8, 2015 Share Posted April 8, 2015 you are the second, second gen this week i have heard of going up in flames, thats too bad Link to comment Share on other sites More sharing options...
