mustangendsley Posted September 12, 2017 Share Posted September 12, 2017 I have the AVO TMIC and just put the Perrin TB hose on. Can someone take a pic from the side to see how you clock it right? I know you have to read the Perrin on the TB hose but is it straight or just up or just down reading the Perrin on the Hose. Mine just seems just off. Link to comment Share on other sites More sharing options...
GTEASER Posted September 12, 2017 Author Share Posted September 12, 2017 I have the AVO TMIC and just put the Perrin TB hose on. Can someone take a pic from the side to see how you clock it right? I know you have to read the Perrin on the TB hose but is it straight or just up or just down reading the Perrin on the Hose. Mine just seems just off.I believe I explained it thoroughly at the beginning of this thread. It's kinda trial and error and the end of the hose should fit flush all the way around the TMIC. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
mustangendsley Posted September 12, 2017 Share Posted September 12, 2017 well i read you post and it does fit just like that and i still have a leak somewhere in the throttle body hose. That is why i would like a pic of where it says perrin on the hose to see if i have it clocked right. Link to comment Share on other sites More sharing options...
GTEASER Posted September 12, 2017 Author Share Posted September 12, 2017 As you can see from this photo linked below (the last one in my posts at the beginning of this thread), its not really possible to get a photo of the text on the side of the coupler while its install. If the coupler is seated up against TMIC all the way around, then it's clocked correctly. Are your clamps tight? Do you have another boost leak somewhere? At least with my hose, if you were to put your chin on the fender just in front in the strut tower, and see thru all the mess of hoses while looking at the TB hose, you'd be able to read the Perrin logo perfectly level directly in front of you. This perhaps is not a great metric for determining the clocking of the hose because it's possible that the logo is in a slightly different place on every hose. [ATTACH]186364[/ATTACH] GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
mustangendsley Posted September 13, 2017 Share Posted September 13, 2017 I will check that out. On the GFB did you use a gasket or bolt it right up to the TMIC? Link to comment Share on other sites More sharing options...
GTEASER Posted September 13, 2017 Author Share Posted September 13, 2017 I will check that out. On the GFB did you use a gasket or bolt it right up to the TMIC?Use the gasket. Just to clarify, this thread is for a 5th Gen, not 4th gen GT. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ivan.ej255 Posted November 24, 2018 Share Posted November 24, 2018 Hi everyone. On the Perrin website, the available TMIC Coupler has this part number for 08-2017 WRX: PSP-ITR-321BL Is it still the same just with different clamp? Just making sure it will fit my 5th gen LGT before buying. Also, will it fit Grimmspeed TMIC? Maybe someone here has the same setup. Thanks. Link to comment Share on other sites More sharing options...
cww516 Posted November 24, 2018 Share Posted November 24, 2018 The GrimmSpeed TMIC comes with its own silicone coupler, since the TMIC outlet isn't in the same location as on the stock part. Link to comment Share on other sites More sharing options...
ivan.ej255 Posted November 25, 2018 Share Posted November 25, 2018 The GrimmSpeed TMIC comes with its own silicone coupler, since the TMIC outlet isn't in the same location as on the stock part. Ok, but for now I still have stock TMIC. I'm just eyeing the Grimmspeed TMIC as a future upgrade but for now, will the Perrin coupler with the new part number fit? Link to comment Share on other sites More sharing options...
DrD123 Posted November 25, 2018 Share Posted November 25, 2018 I think the "new" part number has been in use for quite some time - I have the PSP-ITR-321BK installed on my car - if you are looking for the blue one, the part number you mentioned above is correct (BL=blue, BK=black, and RD=red) Link to comment Share on other sites More sharing options...
dgoodhue Posted November 26, 2018 Share Posted November 26, 2018 I have a new black Perrin coupler forsale (PSP-ITR-321BK) I bought it for my GT, only to find out the prior had already installed one. Link to comment Share on other sites More sharing options...
