jackal8788 Posted August 27, 2014 Share Posted August 27, 2014 ^^A fine birthday choice! Enjoy! VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
SpidermanMTL Posted August 27, 2014 Share Posted August 27, 2014 but it's like 900$ for AVO and 600$ for the RACERX MY BUILD TAKE 2 : http://legacygt.com/forums/showthread.php/spideys-12lgt-take-2-266018.html Link to comment Share on other sites More sharing options...
GTEASER Posted August 27, 2014 Author Share Posted August 27, 2014 ^^Yes, yes it is. The AVO can be had for about $800. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
SpidermanMTL Posted August 27, 2014 Share Posted August 27, 2014 so it's hard for me to justify buying the AVO over the racerx (plus thermal coating). MY BUILD TAKE 2 : http://legacygt.com/forums/showthread.php/spideys-12lgt-take-2-266018.html Link to comment Share on other sites More sharing options...
thatonesandman Posted August 27, 2014 Share Posted August 27, 2014 I'm with Spiderman on this one... Link to comment Share on other sites More sharing options...
btran1384 Posted August 27, 2014 Share Posted August 27, 2014 The avo Tb hose is cheaper than the Perrin... But I don't think it comes with t-bolt clamps. http://www.avoturboworld.com/avoshop/silicone-throttle-body-hose-p-33.html I've had the avo one on before the Perrin....I think Perrin fits better... And the tbolt is a must for me...although I can only get it to fit on the tb side I've got a used avo on for cheap if u want it lol Sent from my Nexus 5 using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted August 27, 2014 Author Share Posted August 27, 2014 ^^ Did you follow my instructions on the first page, I got both Tbolts to fit just fine without problem. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
thatonesandman Posted August 27, 2014 Share Posted August 27, 2014 I've had the avo one on before the Perrin....I think Perrin fits better... And the tbolt is a must for me...although I can only get it to fit on the tb side I've got a used avo on for cheap if u want it lol Sent from my Nexus 5 using Tapatalk Thanks, but I don't like using anything other than t-bolt for piping that has boost either. Especially on a stage 2 tune, and I've had that hose blow out on me. Although I didn't get the farting noise under boost lol. Even went out and made a $4 boost leak tester from home depot... I'll probably go with the Perrin. Link to comment Share on other sites More sharing options...
btran1384 Posted August 28, 2014 Share Posted August 28, 2014 ^^ Did you follow my instructions on the first page, I got both Tbolts to fit just fine without problem. Couldn't get the coupler to go over the rx tmic side with the tbolt on it...literally a half turn n the tbolt would have opened up.  Think I got a weird tmic Sent from my Nexus 5 using Tapatalk Link to comment Share on other sites More sharing options...
blklgt05 Posted August 28, 2014 Share Posted August 28, 2014 Couldn't get the coupler to go over the rx tmic side with the tbolt on it...literally a half turn n the tbolt would have opened up.  Think I got a weird tmic Sent from my Nexus 5 using Tapatalk You can do it, you just gotta really push it down because the coupler have so much friction. I got Perrin coupler to fit with both t-bolt clamps. mod journal Link to comment Share on other sites More sharing options...
btran1384 Posted August 28, 2014 Share Posted August 28, 2014 ^i gave up and slap the stock one on lol...holding find now Sent from my Nexus 5 using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted August 28, 2014 Author Share Posted August 28, 2014 Douse it with silicone spray seconds before you do it and it will slide right on. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jojorios Posted August 28, 2014 Share Posted August 28, 2014 Douse it with silicone spray seconds before you do it and it will slide right on. Followed your advice with this and it slid right on. Link to comment Share on other sites More sharing options...
eckseleven Posted September 2, 2014 Share Posted September 2, 2014 Tried to install this with the RacerX TMIC at the same time. It didn't go well. I got the coupler on fine with the stock IC so I know the positioning of it is ok, but when I try to put the RacerX on, the passenger side mounting bracket is way off. On the driver's side I'm able to use a bit of force to get the mounting holes to line up and a bolt to drop through, but on the other side I don't see how I'm going to do it without drilling a hole through the RacerX mount point. It is a good inch off. Gave up after a couple hours and put the stock IC back on with the Perrin coupler. Makes me wonder if there are variations in these Rx ICs since some people say they fit perfect. blklgt05, jojorios, and others that have the Rx, do you have any tips? Did you have to push the intercooler towards the front of the car and to the left to get the mounting holes to line up? Link to comment Share on other sites More sharing options...
jojorios Posted September 2, 2014 Share Posted September 2, 2014 Tried to install this with the RacerX TMIC at the same time. It didn't go well. I got the coupler on fine with the stock IC so I know the positioning of it is ok, but when I try to put the RacerX on, the passenger side mounting bracket is way off. On the driver's side I'm able to use a bit of force to get the mounting holes to line up and a bolt to drop through, but on the other side I don't see how I'm going to do it without drilling a hole through the RacerX mount point. It is a good inch off. Gave up after a couple hours and put the stock IC back on with the Perrin coupler. Makes me wonder if there are variations in these Rx ICs since some people say they fit perfect. blklgt05, jojorios, and others that have the Rx, do you have any tips? Did you have to push the intercooler towards the front of the car and to the left to get the mounting holes to line up? I had loosened the bolt that holds on the passenger side bracket to give it some moving room. I am not sure if this actually helped in anyway. Once I was able to thread the TMIC I was able to get under the TMIC and re tightened it. But like I said, I'm not sure if that really helped any. Link to comment Share on other sites More sharing options...
eckseleven Posted September 2, 2014 Share Posted September 2, 2014 Ok, I'll try loosening that one next time. I did loosen the drivers side bracket and that did help some but wasn't quite enough. Link to comment Share on other sites More sharing options...
jojorios Posted September 2, 2014 Share Posted September 2, 2014 Ok, I'll try loosening that one next time. I did loosen the drivers side bracket and that did help some but wasn't quite enough. I didn't realize the drive side bracket could of been loosened. Might of saved me a couple of minutes of frustration. Link to comment Share on other sites More sharing options...
frenchy Posted September 4, 2014 Share Posted September 4, 2014 Got mine this morning.http://tapatalk.imageshack.com/v2/14/09/04/4dfbfe4190f8c808a7a3e7ef6ca3901c.jpg  Sent from my iPad using Tapatalk I dont speak English to good but I French alot. Link to comment Share on other sites More sharing options...
Zee199969 Posted March 24, 2015 Share Posted March 24, 2015 Got my Perrin coupler in yesterday. Quick questions to those that have bought it, did you notice the inside of the coupler being somewhat rough with random bumps? It almost feels like those bumps could break loose, would this be an issue? I'll post pics of it later when I get home if needed. My "Build" Link to comment Share on other sites More sharing options...
mcg_ Posted March 24, 2015 Share Posted March 24, 2015 Got my Perrin coupler in yesterday. Quick questions to those that have bought it, did you notice the inside of the coupler being somewhat rough with random bumps? It almost feels like those bumps could break loose, would this be an issue? I'll post pics of it later when I get home if needed. Yes, mine had random bumps. I'm not worrying about it. Link to comment Share on other sites More sharing options...
islandborn Posted March 24, 2015 Share Posted March 24, 2015 Got my Perrin coupler in yesterday. Quick questions to those that have bought it, did you notice the inside of the coupler being somewhat rough with random bumps? It almost feels like those bumps could break loose, would this be an issue? I'll post pics of it later when I get home if needed. STDs.. intake warts... Link to comment Share on other sites More sharing options...
Zee199969 Posted March 24, 2015 Share Posted March 24, 2015 STDs.. intake warts... so this is another reason why I should use the silicone spray? My "Build" Link to comment Share on other sites More sharing options...
matts_pats Posted March 24, 2015 Share Posted March 24, 2015 lamb skin... anyway. i was a little disappointed when i flashed stage one a week ago, didnt feel right. Ruchard thought this might be the prob.. removed the coupler; in was shredded, just removed it and attached OEM hose. peak boost went from 12 to 16.5... now im smiling. Link to comment Share on other sites More sharing options...
Perscitus Posted March 24, 2015 Share Posted March 24, 2015 ... removed the coupler; in was shredded, just removed it and attached OEM hose. peak boost went from 12 to 16.5... now im smiling.Was the Perrin silicone coupler shredded or the stock rubber coupler? If it was the Perrin, how long did you have in on there and what was your target boost until now? (assuming it couldn't have been too high if pre-Stage I). Link to comment Share on other sites More sharing options...
GTEASER Posted March 24, 2015 Author Share Posted March 24, 2015 There is a little confusion here about the term "coupler". Perrin calls it's TB hose, which is a single piece of silicone, a "coupler". When talking about the stock throttle body hose, it is a total of 3 pieces, the rubber hose with a coupler on each end. Pretty sure Matt doesn't have the Perrin yet, which is why he posted in here, because if he had one then he wouldn't have the crappy stock one giving him problems when he flashed to Stage1. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
