ehsnils Posted November 18, 2014 Share Posted November 18, 2014 Put winter tires on yesterday, got to drive on them today. Steering wheel shakes going between 40-70, 70+ doesnt shake... Out of balanced rim? Tires: Blizzak ws70 Rims: steelies Did you mount the wheels yourself? And did you torque the nuts progressively according to the correct 5-point star pattern? Also any debris between rim and hub can cause vibration. Link to comment Share on other sites More sharing options...
s2baru Posted November 18, 2014 Author Share Posted November 18, 2014 Having a similar issue myself on my 91 after putting them on today. Oddly same mph range too, so going in for an alignment next week since I know it's off upfront. Link to comment Share on other sites More sharing options...
Hepy117 Posted November 18, 2014 Share Posted November 18, 2014 Did you mount the wheels yourself? And did you torque the nuts progressively according to the correct 5-point star pattern? Also any debris between rim and hub can cause vibration. I did mount the wheels. I cleaned the hub before putting them on and i used the 5 star torque pattern to 85# Link to comment Share on other sites More sharing options...
SBT Posted November 18, 2014 Share Posted November 18, 2014 Alignment will cause both noise (sound like a wheel bearing) and vibration at specific speeds. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Hepy117 Posted November 18, 2014 Share Posted November 18, 2014 Hmmm ok. I just got an alignment last summer. My stock GT wheels/tires dont shake at all, thats why i feel it is this combo and not the car. But im no expert Link to comment Share on other sites More sharing options...
SBT Posted November 18, 2014 Share Posted November 18, 2014 Your GT wheels, and tires in particular, may have adapted (read: worn-in) to the current alignment. But if they're all in great shape and don't vibrate, then it's likely the wheel/tire balance on your new setup. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Hepy117 Posted November 18, 2014 Share Posted November 18, 2014 The GT wheels have 30k miles on them, but i just rotated them also (x pattern) so i would think that would cause some vibration. Maybe not. I am goin to stop by firestone on my way home n have them throw them on the balancer and see Link to comment Share on other sites More sharing options...
SBT Posted November 18, 2014 Share Posted November 18, 2014 If these are directional tires - check the sidewall to be sure - The arrow points in the direction of travel. If you did "X" rotate them, then, unless you dismounted all 4 tires and remounted them, all 4 tires are now on backwards, which as you indicated, would cause some vibration. That would be the first thing to check. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Hepy117 Posted November 18, 2014 Share Posted November 18, 2014 The stock tires are non-directional (on stock GT rims). The snows are directional and are on with the arrows pointing correctly forward (rotational) Link to comment Share on other sites More sharing options...
GTEASER Posted November 18, 2014 Share Posted November 18, 2014 ^^pointing forward while at the top of the tire or the bottom? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Hepy117 Posted November 18, 2014 Share Posted November 18, 2014 Top Link to comment Share on other sites More sharing options...
s2baru Posted November 18, 2014 Author Share Posted November 18, 2014 http://m.fastcodesign.com/1671067/the-story-behind-the-famous-fedex-logo-and-why-it-works For those of you who ever get mindF'd by the fedex arrow pointing backwards while moving forward. I just ruined your life from now on. Link to comment Share on other sites More sharing options...
Zee199969 Posted November 18, 2014 Share Posted November 18, 2014 occasionally, I will fire up the Levorg thread and allow myself to dream My "Build" Link to comment Share on other sites More sharing options...
Hepy117 Posted November 19, 2014 Share Posted November 19, 2014 Oh i did some more testing this afternoon as i couldnt get into firestone bc it was packed. I pumped the tires up to 36# and went out on the highway. The sweet spot for vibrations is exactly at 60mph. That's where it's the worse. Hit 70, and there is no vibrations above normal tiny bit. It tracks straight. Link to comment Share on other sites More sharing options...
SBT Posted November 19, 2014 Share Posted November 19, 2014 The stock tires are non-directional (on stock GT rims). The snows are directional and are on with the arrows pointing correctly forward (rotational) So stock 2012 LGT Potenza RE050A are asymmetric tires, but did you put the Inside and Outside markings in their respective places when you swapped the tires? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Hepy117 Posted November 19, 2014 Share Posted November 19, 2014 I guess i didnt realize there was an inside/outside to the potenzas. Good to know for when they go back on in the spring Link to comment Share on other sites More sharing options...
Hepy117 Posted November 19, 2014 Share Posted November 19, 2014 Ok im an idiot... I just realized i never retorqued my lugs after takin it on a short drive. Check the fronts, sure enough, both sides were a little loose. Tightened them up, took it for a drive, smooth as silk. So another question for yall. Currently im using the stock lugs for my steelies. They appear to be conical like the stock lugs. Should i be using a different set of lugs? Link to comment Share on other sites More sharing options...
GTEASER Posted November 19, 2014 Share Posted November 19, 2014 Ok im an idiot... I just realized i never retorqued my lugs after takin it on a short drive. Check the fronts, sure enough, both sides were a little loose. Tightened them up, took it for a drive, smooth as silk. Nothing beats a method of process that promotes consistency to remove as many potential errors as possible. In other words, take your time, stop to think, don't get distracted, and do it the exact same way every time and you will never forget a step. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted November 19, 2014 Share Posted November 19, 2014 Doing a circle pattern +1 or 2 after the star pattern doesn't hurt, either. Good way to make sure you didn't miss any. Taught to me by the man who has had a wheel fall off of not one, but two separate vehicles Link to comment Share on other sites More sharing options...
Hepy117 Posted November 20, 2014 Share Posted November 20, 2014 I usually do check the torque when i reinstall. Im not sure why i didnt. My guess is because it was snowing i didnt think about it. I am goin to run it to work and back tomorrow and recheck one more time. Then i'll do checks once a week to make sure Link to comment Share on other sites More sharing options...
ripstik Posted November 20, 2014 Share Posted November 20, 2014 I usually do check the torque when i reinstall. Im not sure why i didnt. My guess is because it was snowing i didnt think about it. I am goin to run it to work and back tomorrow and recheck one more time. Then i'll do checks once a week to make sure i keep a torque wrench in my car for the 2 times a year i change my wheels... you think that overkill? hahaha Link to comment Share on other sites More sharing options...
ehsnils Posted November 20, 2014 Share Posted November 20, 2014 i keep a torque wrench in my car for the 2 times a year i change my wheels... you think that overkill? hahaha Torque wrench - that's overkill. An ordinary breaker bar is enough. Link to comment Share on other sites More sharing options...
ripstik Posted November 20, 2014 Share Posted November 20, 2014 Torque wrench - that's overkill. An ordinary breaker bar is enough. HAHA yea i know but its actually to only wrench i own that has the larger square drive. plus i like knowing things are spec tight and its nice not having to use a separate breaker bar. Overkill FTW Link to comment Share on other sites More sharing options...
jj808 Posted November 20, 2014 Share Posted November 20, 2014 And thats how you misuse a torque wrench... You put the nuts on with a normal wrench till they are tight THEN use the torque wrench. Link to comment Share on other sites More sharing options...
ripstik Posted November 20, 2014 Share Posted November 20, 2014 Umm i put the nuts on with my fingers. how is tightening bolts with a torque wrench misuse? is it not meant to withstand the torques which it's designed to measure? if you over tighten are you then supposed to back it off with your regular wrench then check it again and again and again until you happen upon the correct torque level? I've had this torque wrench literally since i was 10 and it hasn't fallen out of spec once so i think I'm using it just fine Link to comment Share on other sites More sharing options...
