JBear Posted September 13, 2016 Author Share Posted September 13, 2016 Look up Fumoto oil drain valve, I have 3 of them. They work great. https://www.google.com/search?q=fumoto+valve&rls=com.microsoft%3Aen-us%3AIE-ContextMenu&oe=&safe=active&oq=fumoto&gs_l=heirloom-serp.1.0.0l10.3666.10016.0.13916.92.19.0.0.0.6.375.2278.0j6j4j1.11.0....0...1ac.1.34.heirloom-serp..88.4.873.6VusQYwl6uU So, finally broke down and bought one of these, per your link. Tried to put it in during the oil change tonight, couldn't. There's a piece of framework right fricking there and it hits it when you try to screw it in. Putting the drain plug back in... again Link to comment Share on other sites More sharing options...
solidxsnake Posted September 13, 2016 Share Posted September 13, 2016 So, finally broke down and bought one of these, per your link. Tried to put it in during the oil change tonight, couldn't. There's a piece of framework right fricking there and it hits it when you try to screw it in. Putting the drain plug back in... again I just installed mine last oil change... Not much room to get a 17mm spanner on it (or was it 3/4? I don't remember), but enough to get the job done... what part of the car were you hitting? Link to comment Share on other sites More sharing options...
Volta55 Posted September 14, 2016 Share Posted September 14, 2016 in on this thread my commute is shelton to west haven, 17 miles will be doing my first oil change on my wagon using Rotella T6 5w40 ( recommendations on filter? ) and tempted to try out this Fumoto valve.. seems very handy. will be studying the sh*t out of the oil that comes out im very new with subaru, i knew my volvo whiteblocks very well but im back in school learning the different ways of these shortblocks Link to comment Share on other sites More sharing options...
coldsoda Posted September 14, 2016 Share Posted September 14, 2016 ^ stick to OEM filters, or the Mazda filters - see this thread for more info: http://legacygt.com/forums/showthread.php/rotella-t6-5w30i-255899p2.html "Studying the sh*t out of the oil"... as in, sending it to blackstone for analysis? Link to comment Share on other sites More sharing options...
Volta55 Posted September 14, 2016 Share Posted September 14, 2016 ^ stick to OEM filters, or the Mazda filters - see this thread for more info: http://legacygt.com/forums/showthread.php/rotella-t6-5w30i-255899p2.html "Studying the sh*t out of the oil"... as in, sending it to blackstone for analysis? maybe not as extreme as sending it to blackstone, but mainly opening up the filter and seeing what crud the filter caught this is the correct stuff? https://www.amazon.com/Shell-Rotella-550019921-Synthetic-Diesel/dp/B005CHT4W6#customerReviews fwiw i bought the car 6 days ago, and i have no idea when and what the oil change was Link to comment Share on other sites More sharing options...
coldsoda Posted September 14, 2016 Share Posted September 14, 2016 ^ yes. You'll find it a few dollars cheaper at the local wally mart, FYI. Also, theres a rebate going on for the rotella, $5 back per 1gal jug http://rotella.shell.com/coupons-rebates-and-sweepstakes/save-5-per-gallon.html good call to do it now not knowing the previous change. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 14, 2016 Share Posted September 14, 2016 Check Tractor Supply or local Farm Supply they may have it for a good price too. Hint, Tractor Supply is a nice Man's, Christmas Tree Shop...as my GF call's it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JBear Posted September 14, 2016 Author Share Posted September 14, 2016 So. Max. Is there a trick to getting this Fumoto valve screwed in, or do I just have to budget enough time at the next oil change to remove the two cross members that bolt together right in the way? Link to comment Share on other sites More sharing options...
solidxsnake Posted September 15, 2016 Share Posted September 15, 2016 So. Max. Is there a trick to getting this Fumoto valve screwed in, or do I just have to budget enough time at the next oil change to remove the two cross members that bolt together right in the way? I didn't even remove my undercarriage plastic tray... just got enough of a grip with an open ended wrench to screw it in with sufficient torque. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 15, 2016 Share Posted September 15, 2016 I had no trouble putting two on the 4th Gen cars or the 2016 Outback. Didn't take any longer then putting the drain plug back in. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
arg36 Posted September 16, 2016 Share Posted September 16, 2016 I had no trouble putting two on the 4th Gen cars or the 2016 Outback. Didn't take any longer then putting the drain plug back in. Did you use a Subaru crush washer or the included Fumoto gasket? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2016 Share Posted September 16, 2016 Fumoto gasket 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jsmythe Posted September 19, 2016 Share Posted September 19, 2016 Another vote on Fumoto - get the one without the neck, it screws right in. On the filter - I think that most non-dealer shop will way overtighten the filter and as a result destroy the o-ring on the oil cooler. This was what happened on mine - I replaced the o-ring (the only thing you might want to torque correctly is the nut holding the whole thing in place). Now everything is dry and I have a shiny Fumoto and a dry oil filter down there. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 19, 2016 Share Posted September 19, 2016 Fumoto came out with a new product, the SX I think it is, banjo bolt design. https://www.fumotooildrainvalve.com/fumoto-r-sx-series-engine-oil-drain-valve.html?utm_source=Product+Updates+%26+Promotions&utm_campaign=f36bceeb26-SX+video+email&utm_medium=email&utm_term=0_53992b9c0e-f36bceeb26-296471289&mc_cid=f36bceeb26&mc_eid=dd7c29540f 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JBear Posted September 19, 2016 Author Share Posted September 19, 2016 Well that figures. I finally get around to trying to install the one that I bought months ago that won't work, and in the meantime they've come out with one that will. Awesome. Link to comment Share on other sites More sharing options...
solidxsnake Posted September 20, 2016 Share Posted September 20, 2016 https://www.amazon.com/gp/product/B003VCEV0Y/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 That's the one that I bought... went on just fine. Link to comment Share on other sites More sharing options...
Legaroo Posted September 20, 2016 Share Posted September 20, 2016 ^^ I just got this one as well, going on tomorrow! Link to comment Share on other sites More sharing options...
Volta55 Posted September 20, 2016 Share Posted September 20, 2016 I am a tiny bit hesitant buying a fumoto valve because of ground clearance issues. I go off-road ( more like trail driving for a bit for mountain biking to get to the trail head ) how much more do they stick down than stock oil drain plug? Link to comment Share on other sites More sharing options...
jsmythe Posted September 20, 2016 Share Posted September 20, 2016 There is an amazon review that talks about having to raise the engine. I think if you get the version with a neck, it may hit the cross brace. I agonized over having to do that only to discover that you didn't have to with the plain version. I've put Fumotos on 4 cars now, never had any problems, although I do not go off road. The cars go through lots of snow without any problems. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 20, 2016 Share Posted September 20, 2016 I am a tiny bit hesitant buying a fumoto valve because of ground clearance issues. I go off-road ( more like trail driving for a bit for mountain biking to get to the trail head ) how much more do they stick down than stock oil drain plug? Here's pictures, I think of the one I did on the new outback. http://legacygt.com/forums/showthread.php/first-oil-change-253396.html Even on my 4th Gens the valve is above the under tray. If you have a skid plate, that would ad more protection. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
