Jim L Posted January 26, 2006 Share Posted January 26, 2006 ^ lucky, I did it on a cold day, maybe it helped dry quicker? Oh well. Link to comment Share on other sites More sharing options...
Brady Posted January 26, 2006 Share Posted January 26, 2006 really? i used 3M's blue painters tape and it didn't take any chrome off +1 ... same here. I wonder why the difference? Would have really sucked to lose chrome or whatever on the reflector area. Link to comment Share on other sites More sharing options...
subastyle Posted January 26, 2006 Share Posted January 26, 2006 i wouldnt use the best tape again low stick is better and dont pull off in clumps one small piece at a time Link to comment Share on other sites More sharing options...
Brady Posted January 26, 2006 Share Posted January 26, 2006 here's another question, did you make sure you had good solid adhesion everywhere? like a smooth application? Or was it "bubbly" on the chrome? Link to comment Share on other sites More sharing options...
rallispec Posted January 30, 2006 Share Posted January 30, 2006 blue painters tape here as well -- although, i used a cleaning solvent to wipe everything off when i was done, and that peeled the chrome right off. Link to comment Share on other sites More sharing options...
gibsonsg Posted February 15, 2006 Share Posted February 15, 2006 Team23jordan, WHat kind of grill is that and where did you get it? i'm also a little confused on what exactly you're supposed to paint on the light. you don't pain the clear part right, you paint he inside of the headlight. just need clarification on what to tape. thanks Link to comment Share on other sites More sharing options...
team23jordan Posted March 10, 2006 Author Share Posted March 10, 2006 RBS grill check vendor classified section you paint everything except chrome parts Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
Nasty Posted March 22, 2006 Share Posted March 22, 2006 Rallispec, what makes your headlights iridescent? Did you put a protective film over them? Link to comment Share on other sites More sharing options...
Brady Posted March 23, 2006 Share Posted March 23, 2006 Rallispec, what makes your headlights iridescent? Did you put a protective film over them? That's just the way they look when they're blacked out and clean! Link to comment Share on other sites More sharing options...
derffred Posted March 24, 2006 Share Posted March 24, 2006 i'm debating... ahhhh decisions kill me! Link to comment Share on other sites More sharing options...
Brady Posted March 24, 2006 Share Posted March 24, 2006 Debating?! If you like the look you see here, it's an evening at home with a couple beers (but not too many!) and it's dirt cheap! Practically free! Link to comment Share on other sites More sharing options...
Brady Posted June 10, 2006 Share Posted June 10, 2006 I'm going to bump this and add some things since I've received a few PMs recently asking about my experience with this mod. First off, the paint I used was "ACE" brand Flat Black from ACE hardware. I used the oven to heat up the headlights. I don't remember the exact temperature if it was 180 or 220 that I used. I remember that I baked them for about 10 minutes each and used oven mitts to pry them open. 220 degrees should be fine. I wouldn't expect the head lights to be damaged if you drove through death valley when it's 180 out there, so Figure a few more degrees will be ok too. To reseal the lights, all I did was press them together as well as I could, then threw them back in the oven baked them for another 10 minutes then pressed them together the rest of the way and reinstalled the hardware (torx screws). Make sure all your clips are firmly in place. When I painted, I sanded one of the lights and didn't sand the other. I've experienced no difference in quality or durability of either and would advise skipping the sanding step because it just causes more work. I used blue 3M masking tape to mask off the chrome parts I wanted to keep chrome and was VERY careful and slow when peeling it off. Some people have had their chrome peel. I was lucky, which is why I suggest being slow and patient when you do this. My other advise about the masking tape is to be sure you have a GOOD exacto knife to trim the masking tape on the part of the reflector for the turn signal. A very good exacto will make this part of the job MUCH easier. Also, the clear piece that the amber reflector mounts to seems loose in the headlight housing once the reflector is out. I used a little silicone to hold the clip of the clear piece from the rear of the housing. I should have taken a picture of this part, but I never thought of it at the time. You would likely figure it out when you are looking at it. My final piece of advice is to make sure you have a good chunk of time available and go real slow. Slow and patient work pays off with great quality. And if you have any other questions, feel free to PM me. If you need help with a step, I'll PM my phone number and walk you through it. Link to comment Share on other sites More sharing options...
derffred Posted June 10, 2006 Share Posted June 10, 2006 Debating?! If you like the look you see here, it's an evening at home with a couple beers (but not too many!) and it's dirt cheap! Practically free! too bad you don't live in North Jersey, i'd give you a couple of bucks to do it for me hahah:lol: Link to comment Share on other sites More sharing options...
Brady Posted June 10, 2006 Share Posted June 10, 2006 Mail me your headlights! Link to comment Share on other sites More sharing options...
sysfailur Posted December 31, 2006 Share Posted December 31, 2006 lol ya know, I am contemplating doing this as well, but say the chrome chips off what do you do? That's the only thing I'm reading about in this thread that makes me not want to do it. The disassembly looks fairly straightforward. Link to comment Share on other sites More sharing options...
derffred Posted December 31, 2006 Share Posted December 31, 2006 anyone in the north new jersey area wanna tackle this with me? preferably someone who's done it before... Link to comment Share on other sites More sharing options...
mlrtime Posted December 31, 2006 Share Posted December 31, 2006 ^ +1 Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted January 29, 2007 Share Posted January 29, 2007 just did this saturday over in RI... Went well...didn't black them out, but I have twice now on my car. (Did it originally and then a second time after an accident) http://www.legacygt.com/forums/showthread.php?t=51477&page=5 Link to comment Share on other sites More sharing options...
whobaru Posted February 16, 2007 Share Posted February 16, 2007 Team 23- Sounds great, looks great! Neway u can send a close up of a finished headlight along with a little better instructions (when ur more awake)? That would b awesome! Link to comment Share on other sites More sharing options...
Hanger Posted February 16, 2007 Share Posted February 16, 2007 Definitely one of my favorite free mod of all time http://i33.photobucket.com/albums/d70/Hangerr/My%20Legacy/000_0392.jpg http://i33.photobucket.com/albums/d70/Hangerr/My%20Legacy/000_0398.jpg ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
bakasama Posted February 20, 2007 Share Posted February 20, 2007 subscribe Gonna jump on this as soon as the weather stabilizes (no garage ) -Jim (AKA 09F911029D74E35BD84156C5635688C0) Link to comment Share on other sites More sharing options...
own3d Posted February 27, 2007 Share Posted February 27, 2007 Did anyone ever try to paint the headlight to color match the body color? Ferrari like ... http://ferrari-source.us/pic/race_ferrari_noback.jpg Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted February 27, 2007 Share Posted February 27, 2007 ive seen a bunch of wrx guys do this... Dont know about a legacy though. Should look pretty good. Link to comment Share on other sites More sharing options...
lvethesnow Posted February 27, 2007 Share Posted February 27, 2007 i was going to black out my head lights then i relized that there already black guess thats because i have black lgt. felt stupid for a couple min but i got over it. they look good thou History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted February 27, 2007 Share Posted February 27, 2007 i was going to black out my head lights then i relized that there already black guess thats because i have black lgt. felt stupid for a couple min but i got over it. they look good thou its cuz u got an 05. They came with a black surround inside the headlight. My 06 on the other hand had all chrome, so I decided to black them out entirely. Link to comment Share on other sites More sharing options...
