How to BLACK OUT the headlight
  • Replies 432
  • Created
  • Last Reply
  • 1 month later...
  • 5 weeks later...
I really want to do this mod, but like many of the others.. Putting my headlights in the oven scares me just a tad.. And when I see three or four different times and temps. it doesnt help. It is one of the best looking mods you can do though, especially to a darker LGTs!
  • 3 months later...
I've been experimenting with some different colors. I'll share what all I've tried so far. By the way, this is on the '08-'09 headlights.
Starting out
http://i1064.photobucket.com/albums/u365/projectrang/20131101_180553.jpg
Using Duplicolor Metalcast. This is the ground coat.
http://i1064.photobucket.com/albums/u365/projectrang/20131101_195215.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_195243.jpg
Then, I used the smoke color metalcast on top of the basecoat.
http://i1064.photobucket.com/albums/u365/projectrang/20131101_203841.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_203855.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_203924.jpg
Reflector removed, but diffusor still in place
http://i1064.photobucket.com/albums/u365/projectrang/20131101_204948.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_205002.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_205010.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_205022.jpg
I just taped off just a section of the reflector for the turn signal, since I didn't want to keep the entire side clear.
http://i1064.photobucket.com/albums/u365/projectrang/20131101_205034.jpg
Comparison
http://i1064.photobucket.com/albums/u365/projectrang/20131101_205614.jpg
http://i1064.photobucket.com/albums/u365/projectrang/20131101_205630.jpg
Headlights turned on
http://i1064.photobucket.com/albums/u365/projectrang/20131102_154057.jpg
http://i1064.photobucket.com/albums/u365/projectrang/2013-11-02154359.png
Compared to..
http://i1064.photobucket.com/albums/u365/projectrang/20131102_154105.jpg
http://i1064.photobucket.com/albums/u365/projectrang/2013-11-02154309.png
Then, I decided to try a bit of semi-gloss black to see if I would like that
http://i1064.photobucket.com/albums/u365/projectrang/20131102_165505.jpg
I recently tried some VHT Niteshades over top of a coat of the metalcast ground coat, but it just looks black. I tried it on the chrome too, but it comes out looking black also if you get enough on there to be an even coat.
I think, in the end, I'll stick with my original plan: metalcast ground coat, then metalcast smoke over top of that.
  • 2 weeks later...
  • 2 months later...
Finally, I've managed to black out my headlights. Knowing how easy yet tedious this project is, I took my time and may have "derped" around in the process. I ran into issues with masking off the special reflective part by the turn signal. I'm not a huge fan of chrome anyways so when the "chrome" started chipping off, I just said f*** it and painted it all black. We currently are dealing with the bumper not fully fitting into place. There's an annoying gap between the passenger side headlight and the bumper. Other then that I'm very happy with how it all turned out. I've learned to stay positive during and after every car project. Things happen :) Anyways thanks to everyone's step by step guidance and advice it definitely made all the difference in the end and my headlights look AWESOME!
I searched for "delicate" tape at home depot and lows and could not seem to find any. This is the set up I ended up using.
http://i934.photobucket.com/albums/ad189/madikaya/IMG_3470_zps48ce5a49.jpg
Before
http://i934.photobucket.com/albums/ad189/madikaya/9fddc5c8-8251-4190-bd28-93159c97b090_zps57186769.jpg
After
http://i934.photobucket.com/albums/ad189/madikaya/IMG_3499_zps3f8f383c.jpg
Before
After
Looks awesome! let me know if you need any help with the bumper or anything I'm in the PDX area too... Make sure all your plastics on the bottom of the car are sitting properly when you slide the bumper cover on, that was always my issue.
Before
After
Nice... I think? Any chance you can get an after pic from exactly the angle as the Before pic for a direct comparison? The close up is a little hard to get a gauge on the difference. Cheers!
  • 2 weeks later...
  • 2 months later...
In a cursory scroll-through, I don't know if anyone's done the blackout with Nightshades.
Just wanted to share what I did -- The pictures are pretty self-explanatory. I'm currently looking for a set of 06-07s to do (I want that black chrome look) the same way, so, my set is up for trade if anyone's interested.
Wanna replace those pesky torx screws in the headlights? See the Fastenal package for the part number. Can be had at your local shop for less than $3.
The "Samsung" LED 3157As are from Amazon. Look 'em up under that name. Haven't gotten a chance to run them yet, but from what I can tell, they should be pretty bright. Will definitely overcome any reflectivity obstacles, if any, from smoking out the corners.
Other than not matching the factory "black", I'm pretty pleased with how these turned out.
Did you reuse the glue to put it back together?
Sent from my SM-G900V using Tapatalk
I wouldn't. The best thing to do is use Butyl Windscreen Sealant which comes in a roll, roll it into a thin noodle, and drape it along the crevice that the lens goes into on the housing.
Sent from a box in my pocket.
Thank you. Going to look for that locally today.
  • 1 month later...
  • 4 months later...
so can you get pulled over for not having the orange reflector pieces in your headlights? does anyone know exactly what the law is? and has anyone blacked out their headlights then replaced the yellow reflectors back into the headlights?
If you're worried about it, you probably shouldn't do it.
  • 3 weeks later...
Lol no you won't get pulled over dude. Haha, that's too funny
Not sure on the flector but I know it's illegal in some states to not have orange bulbs for blinkers. Maybe that's what hes referring to. Here in MD your not suppose to switch them to clear although I done it on the past 4 vehicles ive owned and it's never been an issue.
By the way im assuming as long as you don't open the lights multiple times you can reuse the glue that originally attaches the lens? Also I know its a straight forward diy but how much more will a heat gun help? Just curious because I have access to a master heat gun at work and could borrow for the weekend.
Alex D.
JDM Prestige Motors
alex@jdmprestigemotors.com
  • 2 months later...
It's been done before, isn't as pleasing in person as it is in your head. Also expensive to have properly matched to SWP.
What's the goal for the car? If you are going to create a unified theme and show it semi-professionally, then, by all means, get down with your bad self. That said, if it's just your DD and you're looking for ways to "personalize" it, I suggest stickers. It's less work for the same result.
