s2baru Posted November 21, 2013 Share Posted November 21, 2013 This is a rather disheartening message to send to everyone but here it goes... About a week ago I just put in a new airfilter into the car and decided to go out fora drive afterwards making sure that the filament wouldn't disrupt anything since other were having the discussion at the current time. Drove around just normal nothing about 4k until I downshifted into 4th to speed up onto the interstate and my car fell flat on its face, christmas lights all over. So of course my immediate thought was maybe I needed to clean my MAF sensor. I pulled over immediately and checked the codes and it registered a misfire in cylinder3 along with PFFFE. Nervous I kept the car under 2.5k put my hazards on and turned around and headed for home. Got in my garage and started a process of elimination. MAF looked clean as a whistle, none of the hoses and or wires were disconnected or loose. Figuring it was a coil pack issue or perhaps a bad plug I didn't have the tools to flip things around and test so I went to a local subie enthusiasts home last night to check it all out and a new code popped up PFFFF....and here's the result Pulled the battery and air box and started to swap coil packs. All of which looked super clean. So so far so good.....Second, started with the rear drivers side sparkplug (cylinder4) pulled it out and looked a bit sutty. Meaning the car was running rich. Next up drivers front plug (cylinder 2) same result. Working over to the passenger side pulled the front first (cylinder1) also sutty but deffinately signs of oil residue. And now the tough part....rear passenger (cylinder3) the ground electrode looked as if it had been hit and two minor markings looking like aluminum, along with oil residue.......not pleasant to witness Went ahead and did a compression test and I had to walk out of the garage and collect my thoughts after this... cylinder 3 ......... 28-32 cylinder 1.......... 115-118 cylinder 4........... 110 cylinder 2........... 110 Looking inside the cylinder with a small angled mirrotr since we didn't have a scope you could see something inside 3. What exactly the material I'm not sure http://i991.photobucket.com/albums/af38/stu-nami/Screenshot_2013-11-20-19-27-52_zps9c34bfbf.png So here's the scenarios I guess 1- Hoping the heads are fine I'll be in need of a new shortblock 2- The passenger head may need rebuilt if damaged and assuming the drivers side is ok with there being no metal in the oil. Then shortblock and seals along with new head 3-IF there is metal in the oil I'm looking at replacing all the hard parts Link to comment Share on other sites More sharing options...
GTEASER Posted November 21, 2013 Share Posted November 21, 2013 Bummer!! Sorry to hear this s2. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
islandborn Posted November 21, 2013 Share Posted November 21, 2013 Aw crap.... well, keep us informed. Link to comment Share on other sites More sharing options...
ehsnils Posted November 21, 2013 Share Posted November 21, 2013 Looking at the spark plug it looks like it has been burning oil. This means a dead piston. Too early to tell if you have damage to your head or how bad it is for the rest of the engine. Link to comment Share on other sites More sharing options...
s2baru Posted November 21, 2013 Author Share Posted November 21, 2013 Rather unfortunate I know. I have a feeling this one moment of driving doesn't correlate to the overall problem. If anyone remembers I was trying to figure out why my car was burning oil and discovered it was a bad o-ring? That was earlier this summer so that was replaced.. Odds are this was more or less the issue. Onward and upward for what's to come I guess. Gotta find a positive out of this, being negative will only poison my love for this car. Link to comment Share on other sites More sharing options...
FJuan Posted November 21, 2013 Share Posted November 21, 2013 Here's a positive, you'll now get to be more intimate with your motor once you start rebuilding it. I was in the same shoes when I blew a ringland on one of my pistons, wasn't sure if I wanted to fix it or sell it at that point. I decided it's a lot cheaper to fix it than to buy a newer car. Good thing I rebuilt it, because you get that bonding feeling when putting it back together and starting it up for the first time. It's like love all over again. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
hmmrdwn Posted November 21, 2013 Share Posted November 21, 2013 Sue K & N. It's all their fault. That low restiction air filter caused a free flow piston slap. Just kidding of course. Wish you the best with your LGT. Looks like you have other things going on too. I'd check the seals on the turbo when rebuilding engine. Dang. Link to comment Share on other sites More sharing options...
lingling1337 Posted November 21, 2013 Share Posted November 21, 2013 First 5th gen engine to go? Link to comment Share on other sites More sharing options...
GTEASER Posted November 21, 2013 Share Posted November 21, 2013 ^^2nd. SurlyOldManMN had one let go last year around this time. IIRC hairline cracks around Piston #4 ringland and a loss of compression in that cylinder. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ebo03 Posted November 21, 2013 Share Posted November 21, 2013 3rd motor to go. First one on pump gas though. You are running pump right Stu? Link to comment Share on other sites More sharing options...
ehsnils Posted November 21, 2013 Share Posted November 21, 2013 But all engines that have gone are EJ:s, no FA/FB that has passed on yet? Link to comment Share on other sites More sharing options...
ebo03 Posted November 21, 2013 Share Posted November 21, 2013 But all engines that have gone are EJ:s, no FA/FB that has passed on yet? Correct. The USDM 5th gen is an EJ. And yeah FBs are not a stout motor by the way. The angled rods are very weak. Add forced induction to a BRZ and start the stop watch...it's only a matter of time before the motor goes. Link to comment Share on other sites More sharing options...
GTEASER Posted November 21, 2013 Share Posted November 21, 2013 We are talking about the EJ255 here. The motor in 2010-2012 Legacy GT models. They employ DVCS and low front mount turbo. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
minuccims Posted November 21, 2013 Share Posted November 21, 2013 This is not a thread I wanted to read. Was hopeful the fault would follow the coil pack; my experience several months back. Cars are funny. Family members are attached to my LGT named FP (flyin pig). Take a few days to be pissed, a few to be unsure of what to do, and many many more to bring the car back to life and reinserted into the family with a smile. Link to comment Share on other sites More sharing options...
s2baru Posted November 21, 2013 Author Share Posted November 21, 2013 I'm gonna do my best to everyone... Islandborn-im hoping for the best, won't know full details until inside. Which may be a few weeks or a Mont to figure out how to attack this. Ehsnils-Yes it had been using/buring oil. .5qt each change so I expected it to be normal. No signs when starting it up in the exhaust. Meaning no smell or fumes when idiling or letting it sit. F1- I'm hoping so. Stage2 block with forged internals is what I'm leaning toward. Try to make this thing a monster now. Hmmrdwn- With how corrupt the corporate world is becoming a lawsuit would cost more than the build lol Ebo03- Running a 91oct map and normally fill with 92. Looking forward to what Youre coming up with aoni can somewhat follow suit when it comes to the items you choose for internals. Keep me updated. Minnicums- I dont want to read all this either, let alone living with it. I'll be all smiles once the process is complete and shes rolling at interstate speeds again. . Always had a legacy so I wouldnt know what else to do. Not really worth tossing to the side. I owe 12grand still so no point in selling it when I can go even more unique then how it sits now. Link to comment Share on other sites More sharing options...
GTEASER Posted November 21, 2013 Share Posted November 21, 2013 Keep up the good attitude s2!!! You've got a great community here to lean on and we thank you for your contributions thus far. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
wrxwhit Posted November 22, 2013 Share Posted November 22, 2013 Damn, no good bro My slipping clutch is giving me heart palpitations, but you are on a waaaay different level. So sorry for this mechanical failure. Well, on a positive note, we all be waiting for your build thread! Link to comment Share on other sites More sharing options...
shribob Posted November 22, 2013 Share Posted November 22, 2013 Sorry to hear this! Hopefully all will be fixed and she'll be better than ever! Link to comment Share on other sites More sharing options...
s2baru Posted November 22, 2013 Author Share Posted November 22, 2013 Keep up the good attitude s2!!! You've got a great community here to lean on and we thank you for your contributions thus far. Will do try to help when and where I can,for scenarios and options available then community here has come full circle and given me tons of info in return. To clear my head a bit I'm going fishing tomorrow hopefully I'll have better luck pulling in some stealhead. Not going to make any rash decisions. One thing I think we should do... ebo03 and acumenhokie along with anyone else, including me now. Should start one solid thread of engine rebuilding items being used. Link to comment Share on other sites More sharing options...
levihamernik Posted November 22, 2013 Share Posted November 22, 2013 Fishing fixing everything!! Sorry to hear about this though, man, really is a shame. Hopefully something good will come of it! Link to comment Share on other sites More sharing options...
MilkCRATE Posted November 22, 2013 Share Posted November 22, 2013 Truelly sucks s2.... hope you figure things out and get her back up and running for next summer! Link to comment Share on other sites More sharing options...
blklgt05 Posted November 22, 2013 Share Posted November 22, 2013 Oh no... what was the cause? Did you use a new K&N air filter? keep us updated mod journal Link to comment Share on other sites More sharing options...
ebo03 Posted November 22, 2013 Share Posted November 22, 2013 Ebo03- Running a 91oct map and normally fill with 92. Looking forward to what Youre coming up with aoni can somewhat follow suit when it comes to the items you choose for internals. Keep me updated. I have no plans of building my motor. At least at this moment in time, I have no plans. When it decides to go bye bye I will build it. As much time as I've put into this car, I will not be selling it for quite a while. If Subaru comes out with a turbo Legacy in a few years then I would consider moving on but we shall see. But when the motor does go I already know what I'm going with. Nothing wrong with thinking ahead right? Link to comment Share on other sites More sharing options...
acumenhokie Posted November 22, 2013 Share Posted November 22, 2013 I have no plans of building my motor. At least at this moment in time, I have no plans. When it decides to go bye bye I will build it. This part of his comment holds true for me as well. On the other hand probably won't buy another Legacy GT in a few years and have no clue what parts I would go with for a rebuild. I've been eying one of those Maserati built Alfa Romeo 4Cs they keep talking about bringing over. (they need to put a real manual and get the price into the 50k range though) Link to comment Share on other sites More sharing options...
s2baru Posted November 22, 2013 Author Share Posted November 22, 2013 Well I'll get some research together for parts. Otherwise looks like I'll order a Maxwell Power built engine or MA Performance. Gotta pull the engine and heads first. That'll be awhile Link to comment Share on other sites More sharing options...
