WaspGT Posted October 20, 2013 Share Posted October 20, 2013 I originally planned on just upgrading my fuel system to support a 20G, but after further consideration and advice... i'm taking the plunge. Might as well do a minor build so that i can actually take advantage of the turbo upgrade... without damaging my motor. This is my first flat four build. I've decided to use R&L Engines of of 108 in Dover. I've heard some pretty good things about their work. We're disassembling the motor and bringing them the heads and block. I got a set of Wiseco 99.5 drop ins, Eagle forged rods and Clevite bearings all around. I didn't buy a new crank so i'm having this one polished. Also thinking of having the heads ported and polished. I've decided to stick with another set of OEM valves as i don't really see the benefit of going bigger (thoughts on this?). Parts list: Wiseco Forged Pistons Eagle Forged Rods ARP Head Stud Kit Clevite Bearings (depending on valve clearance) FMS TMIC Kit Kinugawa TD06 20G DW 740CC Injectors DW65C 265lph Fuel Pump Gates Timing Belt Kit (complete) Subaru OEM HF Oil Pump. Subaru OEM Master Engine Gasket Kit TSK3 Sleeve kit Optima Yellow Top Battery (stock just went) K&N Typhoon Intake Forge BPV New OEM Oil Pan (w/ SickSpeed magnetic anodized plug) Machine Shop: KJE Engine Design Link to comment Share on other sites More sharing options...
WaspGT Posted October 20, 2013 Author Share Posted October 20, 2013 Tearing it down. Link to comment Share on other sites More sharing options...
WaspGT Posted October 20, 2013 Author Share Posted October 20, 2013 Disassembly. Link to comment Share on other sites More sharing options...
WaspGT Posted October 20, 2013 Author Share Posted October 20, 2013 ... Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2013 Share Posted October 20, 2013 Remember to get the half moons for the valve covers, the gasket doesn't come with them, as well as the copper crush washers. Also grease the starter shaft and tranny snout where the TOB rides. I'm no expert, but are 740's a little small for a20g ? Good Luck. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Brian3676 Posted October 20, 2013 Share Posted October 20, 2013 What made you choose clevite bearings ? Tuning? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2013 Share Posted October 20, 2013 FWIW, Clevite is what I used when I use back in 1976 when I rebuilt my V8. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted October 20, 2013 I Donated Too Share Posted October 20, 2013 inb4kaboom Link to comment Share on other sites More sharing options...
WaspGT Posted October 20, 2013 Author Share Posted October 20, 2013 Remember to get the half moons for the valve covers, the gasket doesn't come with them, as well as the copper crush washers. Also grease the starter shaft and tranny snout where the TOB rides. I'm no expert, but are 740's a little small for a20g ? Good Luck. 740cc injectors are what BrenTuning recommended for this application. You think I should have gone bigger? Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 What made you choose clevite bearings ? Tuning? My first choice would have never been Clevite bearings. They only come n one size. 9 times out of 10 the high mileage flat fours are going to have different valve clearances than stock; so different clearances due to polishing the crank. The fact of the matter is that the bearings came with the Eagle Rods as sort of a package deal. Ah well, such is life. I'll most likely have to purchase different bearings after the machine shop measures the VC. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2013 Share Posted October 21, 2013 740cc injectors are what BrenTuning recommended for this application. You think I should have gone bigger? As I said, I'm no expert, if Bren said to use them you should be fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted October 21, 2013 Share Posted October 21, 2013 for the cost of the head port & polish, you could get sti heads? Why the typhoon intake? oem intake is more than good enough what about exhaust (downpipe, cat back, etc)? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Brian3676 Posted October 21, 2013 Share Posted October 21, 2013 My first choice would have never been Clevite bearings. They only come n one size. 9 times out of 10 the high mileage flat fours are going to have different valve clearances than stock; so different clearances due to polishing the crank. The fact of the matter is that the bearings came with the Eagle Rods as sort of a package deal. Ah well, such is life. I'll most likely have to purchase different bearings after the machine shop measures the VC. What does valve clearance have to do with main and rod bearing clearance? Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 for the cost of the head port & polish, you could get sti heads? Why the typhoon intake? oem intake is more than good enough what about exhaust (downpipe, cat back, etc)? I already have DP, UP, CP+polished factory manifolds, and CBE. I bought the Typhoon a while back but took it off until i got a bigger turbo that would actually utilize it; i assumed that the power created from the build would surpass the limits of the factory intake. You can't buy STI heads for cheaper than what i'm paying to have mine rebuild and resurfaced. Link to comment Share on other sites More sharing options...
boxkita Posted October 21, 2013 Share Posted October 21, 2013 hmm...I'm at 335wtq on stock intake. Even at the original 369wtq, the intake was not a limiting factor. If you already have it, why not? if you choose to dyno, it would be interesting to compare between OEM and aftermarket intake. Hint, hint Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 inb4kaboom I'm having my motor built professionally and warrantied by R&L Engines. Leo is actually exceptionally good at what he does. I guess i'm not sure just what you meant, Shawn? Unless of course you were confused by the pictures? Link to comment Share on other sites More sharing options...
FJuan Posted October 21, 2013 Share Posted October 21, 2013 In for the results. Good luck with the build! My wife's balls are delicious. Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 Thanks man! Link to comment Share on other sites More sharing options...
FJuan Posted October 21, 2013 Share Posted October 21, 2013 Rebuilt my motor 6 months ago, fun project just very time consuming. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 What does valve clearance have to do with main and rod bearing clearance? I have no idea why i linked these two together??? Had a million things going on. I've been trying to budget this build... and as with most projects, the unexpected expenses appear. Link to comment Share on other sites More sharing options...
boxkita Posted October 21, 2013 Share Posted October 21, 2013 we all luv a good build. Even more, we luv a good drama. Hoping you have a dramaless build, however, if you don't, don't be stingy on details. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 hmm...I'm at 335wtq on stock intake. Even at the original 369wtq, the intake was not a limiting factor. If you already have it, why not? if you choose to dyno, it would be interesting to compare between OEM and aftermarket intake. Hint, hint Aside from the funny noises it makes... i wish i had never purchased the K&N. There are several others i would rather have, with CF bits, and complete shields that actually seal off the filter... or the stock snorkel and box;) Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 You know i won't BoxKitty! It's been a long time since i've had anything worth posting about... with that said... this should be fun. Considering i have no idea what i'm doing... thank God for friends! Link to comment Share on other sites More sharing options...
boxkita Posted October 21, 2013 Share Posted October 21, 2013 Dang! I was honestly hoping for a repeat of the cheap coilover thread followed by the obligatory ritualistic banning. With regards the KN if the luv is so little, I'm sure you can find a stock intake to put back in. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
WaspGT Posted October 21, 2013 Author Share Posted October 21, 2013 I never got rid of my stock intake... it's perched on a shelf beside the motorless LGT. I'm in for fun, but i hope no one gets banned. banning tends to end fun ever so ubruptley. Link to comment Share on other sites More sharing options...
