AKLGT Posted September 18, 2008 Share Posted September 18, 2008 This was posted by Subiegal today: September 18, 2008 Dealer Announcement – Subaru Recall WVF-16 Turbo Charger Oil Supply Pipe Subaru of America, Inc. has initiated a voluntary Safety Recall to inspect, modify and possibly replace the turbo charger oil supply pipe on approximately 16,715 2007 & 2008 Legacy 2.5GT / Outback 2.5XT, 2008 Impreza WRX (except STI) and a very small number of early production 2009 Forester 2.5XT models. Campaign code WVF-16 has been assigned to this Safety Recall. Affected vehicles may have been manufactured with a turbo charger oil supply pipe that was deformed due to misalignment during the assembly process. If the pipe is deformed, vibration experienced during normal driving could result in a crack developing over time, causing an engine oil leak. There is a safety risk associated with this condition. If leaking oil contacts components operating at high temperatures, an engine compartment fire could result. This recall will involve inspection of the turbo charger oil supply pipe for proper alignment. If the pipe is found to be properly aligned, it will be necessary to install a support bracket as a precautionary measure to increase rigidity of the pipe. If the pipe is found to be deformed, a new replacement pipe and support bracket must be installed. A Recall Campaign bulletin will be released during the week of October 6th. The bulletin will provide additional information concerning inspection and repair procedures. General information concerning this Safety Recall: • Recall Campaign Bulletin - the bulletin is expected to be released during the week of October 6th. • Repair parts - Information concerning the availability of repair parts will be released in the near future. • Owner notification - owner notification letters are expected to be mailed during the week of October 20th. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
Habitual Line Stepper Posted September 18, 2008 Share Posted September 18, 2008 Damnit! I wonder if they'll still do this under warranty if i'm modded? "I for one do not doubt you, dude. Your car is fast and an internet legend." -Gire Link to comment Share on other sites More sharing options...
AKLGT Posted September 18, 2008 Author Share Posted September 18, 2008 it's a recall, so won't matter. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
jim1969 Posted September 18, 2008 Share Posted September 18, 2008 wonder what was different on the 05+06? Link to comment Share on other sites More sharing options...
urs1ne Posted September 18, 2008 Share Posted September 18, 2008 I already had to get mine replaced, I knew this should have been a recall, they took way too long in addressing this issue. ^ n00bs below this line Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 18, 2008 Share Posted September 18, 2008 Its About TIME!~!!!!!!! On my third oil feed line! Link to comment Share on other sites More sharing options...
VTGT Posted September 18, 2008 Share Posted September 18, 2008 wonder what was different on the 05+06? +1 Link to comment Share on other sites More sharing options...
h22afast Posted September 18, 2008 Share Posted September 18, 2008 Does this apply to the '07 Spec B. it does not specify but I would assume so as the engine is that same? Link to comment Share on other sites More sharing options...
urs1ne Posted September 18, 2008 Share Posted September 18, 2008 Does this apply to the '07 Spec B. it does not specify but I would assume so as the engine is that same? Ya it should ^ n00bs below this line Link to comment Share on other sites More sharing options...
FishingFiend Posted September 18, 2008 Share Posted September 18, 2008 Besides good luck for those who get dealer monkeys replacing the stock line. It requires pulling of intake manifold and even unbolting main water pipe. Lots of things to screw up. Unclemat is dead on, it's a lot of work. My car still does not feel right after the repair... I hope the rest of you have better luck. Link to comment Share on other sites More sharing options...
Guest Posted September 18, 2008 Share Posted September 18, 2008 Unclemat is dead on, it's a lot of work. My car still does not feel right after the repair... I hope the rest of you have better luck. Yes, I my dealer experiences are consistently bad to horrid. For example, they forgot to actually... secure the clamp on the turbo inlet tube For that reason go aftermarket. I based my install on what this guy wrote: http://www.iwsti.com/forums/engine-power-performance/101927-turbo-oil-feed-avcs-line-replacement.html However I used somewhat different set of parts that fits cleaner and easier plus is actually compatible with 07 plumbing (although I have 05) - the 90 deg. line as per the guy's walkthru does not fit on 07+ cars I read. I'll post my detailed info shortly. Link to comment Share on other sites More sharing options...
LuckyBob Posted September 18, 2008 Share Posted September 18, 2008 Your best bet is to replace the line with flexible stainless lines. $100 for piece of mind is worth it. I'll post a how-to soon.[...] Link to comment Share on other sites More sharing options...
tdoggydog Posted September 19, 2008 Share Posted September 19, 2008 Perhaps this is reason enough to get a NA? Link to comment Share on other sites More sharing options...
Gator GT Posted September 19, 2008 Share Posted September 19, 2008 For that reason go aftermarket. I based my install on what this guy wrote: http://www.iwsti.com/forums/engine-power-performance/101927-turbo-oil-feed-avcs-line-replacement.html However I used somewhat different set of parts that fits cleaner and easier plus is actually compatible with 07 plumbing (although I have 05) - the 90 deg. line as per the guy's walkthru does not fit on 07+ cars I read. I'll post my detailed info shortly. I'm actually consulting w/ a local hydraulic shop for these pieces...I'm curious about your 07 plumbing solution. "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
FireB Posted September 19, 2008 Share Posted September 19, 2008 Hope to hear from Subaru. Finally a safety issue sorta resolved. Link to comment Share on other sites More sharing options...
Guest Posted September 19, 2008 Share Posted September 19, 2008 I'm actually consulting w/ a local hydraulic shop for these pieces...I'm curious about your 07 plumbing solution. 07 compatible solution is to use straight -4AN hose between the Tee and the AVCS, and use -4AN 12mm banjo, not the metric to -4AN adapter - just like stock, which has banjo and banjo bolt there. Link to comment Share on other sites More sharing options...
Hokiebird Posted September 19, 2008 Share Posted September 19, 2008 Is this all 2007 - 2008 LGTs or a certain vin range? Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 20, 2008 Share Posted September 20, 2008 Okay I'd like to see they support bracket they plan to install. Link to comment Share on other sites More sharing options...
j255c Posted September 20, 2008 Share Posted September 20, 2008 just buy a braided line they are 50 bucks from blouch turbo. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
VTGT Posted September 21, 2008 Share Posted September 21, 2008 wonder what was different on the 05+06? Anybody? Link to comment Share on other sites More sharing options...
Guest Posted September 21, 2008 Share Posted September 21, 2008 Anybody? Not sure, but I don't think there is any difference. It was just manufacturing and/or assembly issue on 07+ cars. Link to comment Share on other sites More sharing options...
DrCloud Posted September 21, 2008 Share Posted September 21, 2008 This could explain my LGT.B experience when it was brand new, last April. It took two tries, but on the second one (which involved waiting for a new part) they seem to have done it right. And, in conversations with the tech guy at the time, I discovered that he was dismayed that (1) this looked like a problem with a new design because my case wasn't the first one he'd seen (apparently, though, SOA has decided it was an assembly glitch); and (2) it was a huge PITA to fix because of how deep into the engine compartment they had to burrow to get at the line. I sure hope it's limited to a range of VINs so that we won't need our OBXT fixed. HPH Link to comment Share on other sites More sharing options...
20lgt06 Posted September 21, 2008 Share Posted September 21, 2008 it is all years or select models because i didnt get a notification yet Link to comment Share on other sites More sharing options...
ama0787 Posted September 22, 2008 Share Posted September 22, 2008 I hope 06 are included I have a leak on the top of the cartridge where the supply line attaches and also on the intercooler inlet I think it may spray under high loads...I checked the BOV recirculate pipe which was clean so I assume no excessive blow by is going on Does the leak I described above sound like the problem with the recall they are issuing Link to comment Share on other sites More sharing options...
nemo Posted September 22, 2008 Share Posted September 22, 2008 Is this all 2007 - 2008 LGTs or a certain vin range? +1 -- there a VIN range? If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
