Dbl_D718 Posted August 2, 2013 Share Posted August 2, 2013 Crap, ok hold on. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
SpecBinNB Posted August 2, 2013 Share Posted August 2, 2013 torrent is up and running.Thanks for this. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 2, 2013 Share Posted August 2, 2013 New torrent file link sent for those that couldn't access the first. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
Meltdown07 Posted August 2, 2013 Share Posted August 2, 2013 New torrent file link sent for those that couldn't access the first. I'm connected to the second torrent and will seed indefinitely when complete. Thanks again for putting this together. Go Cardinals! Link to comment Share on other sites More sharing options...
theflystyle Posted August 2, 2013 Share Posted August 2, 2013 I'm connected to the second torrent and will seed indefinitely when complete. Thanks again for putting this together. ditto Link to comment Share on other sites More sharing options...
.NetSubie Posted August 2, 2013 Share Posted August 2, 2013 I'm connected to the second torrent and will seed indefinitely when complete. Thanks again for putting this together. Same here Link to comment Share on other sites More sharing options...
mass-hole Posted August 2, 2013 Share Posted August 2, 2013 I'm connected to the second torrent and will seed indefinitely when complete. Thanks again for putting this together. as will i Link to comment Share on other sites More sharing options...
awwrxwgn Posted August 2, 2013 Share Posted August 2, 2013 Can I get a link Dbl Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 2, 2013 Share Posted August 2, 2013 New torrent file link sent for those that couldn't access the first. if you still have problems hosing the torrent file let me know i'll host it on my webspace for free. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
xVern Posted August 2, 2013 Share Posted August 2, 2013 Will download and seed when i get home! Link to comment Share on other sites More sharing options...
xVern Posted August 2, 2013 Share Posted August 2, 2013 Downloading at my full speed, and seeding! Link to comment Share on other sites More sharing options...
Meltdown07 Posted August 2, 2013 Share Posted August 2, 2013 Work up this morning and the torrent had completed and I'd already uploaded the discs 2x over! Burned EAST and it loaded up in the car no problem. Thanks again, Dbl_D718 for getting this organized and delivered for all of us! I'll be sure to keep seeding on my end Go Cardinals! Link to comment Share on other sites More sharing options...
brawline Posted August 2, 2013 Share Posted August 2, 2013 got it and it works great. Thanks again Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 2, 2013 Share Posted August 2, 2013 Glad this worked for everyone! I don't have any DLers currently, so hopefully that means most people have finished up successfully. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
SubieChik Posted August 2, 2013 Share Posted August 2, 2013 I still don't know what I'm doing.....nor can I do it from an iPad I'm guessing... Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 3, 2013 Share Posted August 3, 2013 I'm not sure it'd work from an iPad or not. Have you ever used a torrent client before? I prefer uTorrent myself. So, download the torrent file from the link I sent, then open it with the torrent client. Your download should then start automatically. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
mass-hole Posted August 3, 2013 Share Posted August 3, 2013 I'm not sure it'd work from an iPad or not. Have you ever used a torrent client before? I prefer uTorrent myself. So, download the torrent file from the link I sent, then open it with the torrent client. Your download should then start automatically. There may be an app to download the torrent for the Ipad(there is for android), but you still need to be able to burn it with a DVD burner and dual layer disc. A dual layer DVD is a a special kind that holds up to ~8.6 GB instead of the usual ~4.5 GB. You should be able to pick them up at your local best buy, you just need to make sure you get the dual layer ones, otherwise the pictures wont fit. Easiest Way - Download this and install on your PC: http://www.utorrent.com/, then download the torrent file he sent out and open it using the utorrent software. Then use a program called imgburn to burn the pictures to the dual layer disk you purchased. Link to comment Share on other sites More sharing options...
.NetSubie Posted August 3, 2013 Share Posted August 3, 2013 Downloaded half and it worked perfectly. getting other half of them now. Thanks Dbl_D718! Link to comment Share on other sites More sharing options...
cosdriver9521 Posted August 4, 2013 Share Posted August 4, 2013 Got it downloaded just fine but found out that my DVD burner isn't a double layer. D'Oh! Gotta get that tomorrow and then I'll be good to go. Thanks! Link to comment Share on other sites More sharing options...
Meltdown07 Posted August 4, 2013 Share Posted August 4, 2013 Easiest Way - Download this and install on your PC: http://www.utorrent.com/, then download the torrent file he sent out and open it using the utorrent software. Then use a program called imgburn to burn the pictures to the dual layer disk you purchased. Also worth mentioning. The built in ISO burner in Windows 7 and 8 works to burn this. Just right click the ISO file and click burn, put in your DL DVD and enjoy. Go Cardinals! Link to comment Share on other sites More sharing options...
theflystyle Posted August 4, 2013 Share Posted August 4, 2013 Worked like a charm... thanks Dbl_D718 Link to comment Share on other sites More sharing options...
xVern Posted August 5, 2013 Share Posted August 5, 2013 Downloaded and burned in the last hour before a road trip. Good thing it worked without issue. Link to comment Share on other sites More sharing options...
xVern Posted August 8, 2013 Share Posted August 8, 2013 Now that all the starters have gotten it, or i assume so since no one has leached from me for a few days, will we release this to the public? Link to comment Share on other sites More sharing options...
Meltdown07 Posted August 8, 2013 Share Posted August 8, 2013 Now that all the starters have gotten it, or i assume so since no one has leached from me for a few days, will we release this to the public? They can use version 6 that is out there as far as I am concerned. People were given plenty of time to get into this for a very small price. People too cheap to do that dont deserve to get in on this. Just my opinion. Go Cardinals! Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 8, 2013 Share Posted August 8, 2013 Now that all the starters have gotten it, or i assume so since no one has leached from me for a few days, will we release this to the public? Why would we do that? We paid for it (kinda), they can too. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
