Arm-Chair Diagnostics HELP! **video**
Help, my car quit and now has some serious noise issues. Here's the story...I was driving to my sons school because they were having a kindergarten kids lunch day (where parents can bring and eat with their kids) and noticed it seemed low on power. I use intelligent drive 98% of the time because in my small town there is no reason to go faster than 40 mph.
I came to a stop sign and it stuttered a little and almost stalled. As I let out the clutch to go again it bogged down heavily and just stalled. I tried starting again and it would barely crank. I pushed it to the side of the road and tried cranking it again, no luck. My battery was 10 years old and I was certain this was the issue. I installed a new battery and tried cranking it again...still would barely crank. I took the battery back and had them check it on their tester, it was low on charge so they gave me a fresh one. I re-installed the battery and was able to get it started. The battery seemed like it was really trying hard to turn the car over, but it eventually started. Once it started it made a really loud clacking noise. I drove it about a block and it quit again. (I probably shouldn't have even driven it:confused:) From that point on I could not get it started again, so I had it towed to my house. I was able to get it started again and took some video of what it sounds like. Any ideas that could get me going in the right direction are greatly appreciated. Oh yeah, it doesn't eat oil and the oil level is still full. The turbo was replaced by a Subaru dealership shortly before I got the car, around 66K. The car now has ~75k
Take that useless POS plastic cover off the engine and throw that POS away.
Now that you can see things. Check the tensioners on the drive belts.
Check the crank shaft pulley, make sure it is not loose.
Engine Build - Click Here
:lol: MaxCap, this isn't the first time, but it seems like the sight of the word "engine cover" infuriates you. LOL. I see it that you think this is the most useless piece of equipment Subaru can put on a car. Now, you've got me scared to mention that I passed on a IPR intercooler because I wanted to retain the looks of my engine bay with the engine cover...and didn't want to go through the hassle of modifying it...because I totally Love the engine cover....So I wont tell you.:rolleyes:
To me It's much more important to be able to see any potential problems before they start.
I feel it's more of a marketing thing. If they can't see a possible problem, they will wait until it gets really bad and then bring the car into the dealership to fix. The longer the problem exist, the more money we can make on repairs.
if it was just for the tmic a much smaller piece would have worked.
wow - bad noises. it almost sounds like the flywheel bolts have loosened, although i don't think that would be a common thing. maybe if the above things don't pan out you could take a peek?
BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT
  • Moderators
The engine cover should not be tossed as it guides air into the TMIC. Come on, Byron--you know that.
It's not just for the TMIC, and yes it could be modified, but it literally takes 10 seconds to remove to "check for issues"
Not currently in stock :(
Well, I took off the belts and exercised the main pully with a breaker bar, there was nothing obvious and everything moves smoothly. I turned the key again and the chickens are still there...I wonder if Colonel Sanders would be interested.
At this point it looks like the Subi will be out of commission for a while, I don't have the time or the experience for this in depth of a problem.
Can anyone recommend a good mechanic in the Antelope Valley/Bakersfield, CA area? I have heard the dealerships around here are subpar and willing to take you for everything including the lint in your pockets.
Rod bearing shot/spun:mad:
I think you're right...
After educating myself I am guessing it all started when the turbo went bad. I could be way off base, but from what I've been reading it there is any oil starvation it causes the bearings to overheat and expand which loosens the tolerance. Overtime the looser tolerance cuases it to beat itself up. The previous owner of the car had to have the turbo replaced because the banjo bolt filters clogged and it starved. Ever since I bought the car there was a slight knock at cruising RPM. I never heard other than cruising 65-70 on the freeway, I couldn't duplicate it any other way. I just assumed it was a resonance that occurred at that specific speed/rpm combination. My only guess is that when the turbo starved it also caused an overheat condition at the bearing and over time just got worse...
You have severe rod knock plus some other bad noises. Price out a used longblock, it'll be cheaper in the long run.
Thanks for the advice, I've been looking online but haven't had much luck. Do you have any recommendations on where else to look?
Did you ever see that PhoenixLegacy guy that was selling long blocks for super cheap?
I think he ended up getting vendor status.
I'll go look.
Yeah looks like it, worth a look...
http://legacygt.com/forums/showthread.php/sti-2-5l-turb0-engine-sale-197839.html?p=4384636#post4384636
I beleive he does alot of sti(dual avcs) motors so those don't drop in IIRC.
Self proclaimed PNW Craiglist find of the day Champion, April 2014.
  • 2 weeks later...
I haven't yet pulled my motor to see what is going on, but am ready to get things moving. Can you tell me why I should be looking for a long block vs a short block.
There are so many companies that sell shortblocks, but almost none that sell longblocks.
Thanks.
My employers firewall wont let me watch youtube but by the sounds of things I'd agree you prob have internal issues. Drain the oil and ispect it for glitter (may want to cut open the oil filter too).... you may have vampire chickens from the movie twilight.... either that or you've pooched your bearings or worse.
Short block should be fine as long as the pistons havent hit the valves or any debris hit hte head. With a short block you'll have to swap the heads and stuff.
I'll go look.
Thanks for telling me about this, I talked to Joe a couple days ago and gave him a deposit. He said it will be a couple weeks until it's done...
So did you actually get the car checked, or are you making expensive decisions based on what some guys on the internet said?
I guess it depends on what you mean by getting the car "checked." If you're asking if I pulled the motor and opened it up, the answer is no. I did however have a friend (who works as a mechanic for Ford...NOT Subaru) come and look at it. He is also confident it is something internal that would "more than likely" require a rebuild. So, I guess my answer is that I not only listened to some guys on the internet, but also a non-Subaru mechanic! :eek:
If it's not the motor...well I guess I'll have a spare to build on! :cool:
It's only money right? If you say it fast enough it doesn't sound like much at all :lol:
