shrike1201 Posted January 27, 2013 Share Posted January 27, 2013 I ordered a replacement OEM turbo inlet and received part number 14460AA220 but I've seen that part number 14459AA340 also listed as the turbo inlet. The part I received has the same amount of spigots/fittings but are off by a little bit. One of the fittings, you can see in the second picture, is almost completely different and I can't imagine how to put the hose one it. Also, the replacement turbo side seems about 1/4 inch smaller in diameter but that could just be the original being stretched. Did I receive the wrong part or was part 14459AA340 superseded? I snapped a few pictures, hopefully you guys can help me. The older looking one with a hose still attached is the one I am replacing. Link to comment Share on other sites More sharing options...
2.5GT_dude Posted January 28, 2013 Share Posted January 28, 2013 05-07 have different BPV return spigot placement than 08-09 do to relocation of solenoids. You would have to order for the inlet for your year specifically. Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 28, 2013 Share Posted January 28, 2013 05-07 have different BPV return spigot placement than 08-09 do to relocation of solenoids. You would have to order for the inlet for your year specifically. ^ This. And it's a royal pain to learn this the hard way. Would be easier to change a spark plug through the muffler tip. Link to comment Share on other sites More sharing options...
shrike1201 Posted January 28, 2013 Author Share Posted January 28, 2013 Thanks for the reply guys. So then I suppose they sent me an inlet for 08-09. On the OEM inlet, the spigot closest to the turbo has a right angle and a place to clip a wire coupling whereas the replacement is a straight and has nowhere to place the coupling. Just got off the phone with Fred Beans Parts and they verified through my VIN that the correct turbo inlet part number is 14459AA340 and is for 03-05 models while 14460AA220 is for 05-07. Link to comment Share on other sites More sharing options...
LGT254 Posted January 28, 2013 Share Posted January 28, 2013 I'm looking for this same part. So does that mean that there are two different parts for LGTs made in 2005? Link to comment Share on other sites More sharing options...
shrike1201 Posted January 29, 2013 Author Share Posted January 29, 2013 I'm looking for this same part. So does that mean that there are two different parts for LGTs made in 2005? That's what they told me, best to verify the correct part with your VIN when purchasing. Link to comment Share on other sites More sharing options...
Underdog Posted January 29, 2013 Share Posted January 29, 2013 I can look up the correct P/N by your VIN, and quote it for you. The Crimson Dynamo Link to comment Share on other sites More sharing options...
LGT254 Posted January 29, 2013 Share Posted January 29, 2013 Already ordered it. Thanks though! Link to comment Share on other sites More sharing options...
Energyblue98 Posted March 16, 2014 Share Posted March 16, 2014 I have an 08 which would mean i need 14460AA220 that you ordered... do you have it still laying around? my coupler that connects to the turbo broke off like all the other one's ive seen. Looks to be around $90 from subaru, do you happen to know if they have them in stock at the dealership? I need to get my car back on the road asap.. and would you know if the perrin would fit the 08-09's? anyone know if perrin made two types to fit both the 05-07 and the 08-09? Link to comment Share on other sites More sharing options...
shrike1201 Posted March 17, 2014 Author Share Posted March 17, 2014 I have an 08 which would mean i need 14460AA220 that you ordered... do you have it still laying around? my coupler that connects to the turbo broke off like all the other one's ive seen. Looks to be around $90 from subaru, do you happen to know if they have them in stock at the dealership? I need to get my car back on the road asap.. and would you know if the perrin would fit the 08-09's? anyone know if perrin made two types to fit both the 05-07 and the 08-09? I ordered it from FredBeansParts and sent it back to them for an exchange. I have no idea about the Perrin inlets. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 2, 2014 Share Posted April 2, 2014 SO glad I found this thread need an inlet ASAP FBP can be it here by Friday. I recently bought my LGT and all records are on hand from previous owner but a tear in the inlet hose is something you wont know about until you look. 14460AA220 is what I ordered it is for the 07-09 LGT as a bit of insurance I am going to use wider clamps (t-bolts) over the narrow worm gear clamps. looks like the stock inlet rots over time due to constant heat cycles. My LGT is @ 87K no idea how long its been ripped but the tear isn't large enough room for my index finger to fit through. Link to comment Share on other sites More sharing options...
chato Posted April 3, 2014 Share Posted April 3, 2014 let me know if you figure out a trick for getting those t-clamps on the turbo side. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 3, 2014 Share Posted April 3, 2014 Im going to put the clamp on with the IC off and clock the bolt so i can reach it with my 12" extension from the area where the IC would normally sit. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 3, 2014 Share Posted April 3, 2014 let me know if you figure out a trick for getting those t-clamps on the turbo side. If you can see the original clamp in the pic ill clock the bolt head so im looking right at it Link to comment Share on other sites More sharing options...
chato Posted April 3, 2014 Share Posted April 3, 2014 yeah, I have a uninstalled t-clamp because my perrin likes to slip off periodically. just haven't gotten up the gusto to pull the inlet off again to put it on. partly because I wasn't sure I could get it to fit, and partly because it was such a pain to get the inlet on the turbo the first time. Link to comment Share on other sites More sharing options...
Sk8erOrd Posted April 8, 2015 Share Posted April 8, 2015 Thoughts on these for a 2006? http://www.oakos.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=355&Product_Code=TR-HS1003BL&Category_Code=6244 http://www.oakos.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=355&Product_Code=AVO-S1B07G41BBLUJ&Category_Code=6244 2015 Mustang Ecoboost Premium w/ PP (6MT) 2006 LGT Ltd 5MT OBP Cobb Short Throw Shifter | GS Catless Up Pipe Gone Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2015 Share Posted April 8, 2015 Stay stock and stay happy. That's what I did. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Sk8erOrd Posted April 8, 2015 Share Posted April 8, 2015 Stay stock and stay happy. That's what I did. Ok. I'm starting my shopping list for my turbo swap, and replacing this is on my list. I'm not going huge, either the 16G or JmP custom40. I'll replace stock with aftermarket if the aftermarket is better, or the same for less $$, but not if it's going to cause issues. 2015 Mustang Ecoboost Premium w/ PP (6MT) 2006 LGT Ltd 5MT OBP Cobb Short Throw Shifter | GS Catless Up Pipe Gone Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 8, 2015 Share Posted April 8, 2015 I replaced my stocker with the Godspeed silicone inlet. I've had zero issues with it so far and you can't beat the price with a stick. [ame=http://www.amazon.com/gp/product/B005EYRQ0O/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1]Amazon.com: Godspeed Blue color Turbo Intake Inlet Silicone: Automotive[/ame] Link to comment Share on other sites More sharing options...
seanlah Posted April 8, 2015 Share Posted April 8, 2015 Ok. I'm starting my shopping list for my turbo swap, and replacing this is on my list. I'm not going huge, either the 16G or JmP custom40. I'll replace stock with aftermarket if the aftermarket is better, or the same for less $$, but not if it's going to cause issues. I actually have an extra Perrin turbo inlet for an 05 lgt right now, and have no use for it. Almost new, 3000 miles on it. Here's a link to the part: http://perrinperformance.com/i-13323995-turbo-inlet-hose-for-2008-14-wrx-2005-09-lgt.html I'll sell it $100 shipped I can attach pictures if you're interested. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2015 Share Posted April 8, 2015 I think I paid around 80 for my oem. count the number of bungs on the OEM and others. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
