stuck686 Posted December 18, 2012 Share Posted December 18, 2012 Its like a little strip that slides onto the fender from the inside. any one know where i could order this? or maybe just glue it or something? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2012 Share Posted December 18, 2012 rubber cement works great, that's what's holding one of mine on for 3 years now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stuck686 Posted December 18, 2012 Author Share Posted December 18, 2012 ah good idea. would it be hard to find a new one since the corner is all bent on mine? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2012 Share Posted December 18, 2012 Any body shop, might be able to get you one. Any auto parts store may carry them, you'll have to ask. Fredbeans, a vendor here would have them. You may use a heat gun to soften it and reform it. Follow the directs on the rubber cement, it works great. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1stick3pedals Posted December 18, 2012 Share Posted December 18, 2012 I ordered mine on subaru parts warehouse or something, didn't cost too much. Link to comment Share on other sites More sharing options...
12sechatch Posted December 18, 2012 Share Posted December 18, 2012 subarugenuineparts.com at the top, go to the OEM catalog, then search for your part. Link to comment Share on other sites More sharing options...
ryanlucas13 Posted December 18, 2012 Share Posted December 18, 2012 I took both of mine off several years ago..water was getting trapped in there and I was afraid it was going to rust. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 19, 2012 I Donated Share Posted December 19, 2012 Yeah, mine are off. Link to comment Share on other sites More sharing options...
.Catalyst. Posted December 19, 2012 Share Posted December 19, 2012 When washing my car one day realized one was gone - promptly removed the remaining one since it seemed worthless anyhow. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
rallispec Posted December 19, 2012 Share Posted December 19, 2012 Removed mine long ago, also worried it would be a rust trap Link to comment Share on other sites More sharing options...
stuck686 Posted December 19, 2012 Author Share Posted December 19, 2012 what does it do?? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 19, 2012 I Donated Share Posted December 19, 2012 what does it do?? Captures moisture and salt so that the quarter panel rusts? Link to comment Share on other sites More sharing options...
SCHM1AN Posted December 19, 2012 Share Posted December 19, 2012 It's supposed to guard the fender from slicing open your tires if you bottom out, but if you do that enough you'll wear through the rubber lining and expose some sharp metal pieces inside. I promptly ripped them off when I found that out. If you're worried about the fender slicing your tires, it's time to roll the fenders. Link to comment Share on other sites More sharing options...
TenzoGT Posted December 20, 2012 Share Posted December 20, 2012 Take them both off. Link to comment Share on other sites More sharing options...
