xt2005bonbon Posted September 24, 2012 Share Posted September 24, 2012 Just heard back from my machine shop....spun 2 rod bearings and ruined the crank. Oil cooler and oil pump also shot So, oil cooler and oil pump's fault then? I have not heard too much of failed oil pump. interesting.. What's your plan? Link to comment Share on other sites More sharing options...
dr_sharp Posted September 24, 2012 Share Posted September 24, 2012 oil pump failure... thats a new one. you should have seen an oil light when the pump stopped. lol Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 24, 2012 Share Posted September 24, 2012 you should have seen an oil light when the pump stopped. ^ warning light of death. So, oil cooler and oil pump's fault then? First time I hear of failed oil pump. interesting.. ^ fixed. Link to comment Share on other sites More sharing options...
leggyman17 Posted September 24, 2012 Author Share Posted September 24, 2012 Oil light never went on strangely. Plan is new internals just OEM i need the car back Link to comment Share on other sites More sharing options...
Caboose Posted September 24, 2012 Share Posted September 24, 2012 So what's something like that gonna cost to get fixed?? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 24, 2012 Share Posted September 24, 2012 How about a new EJ257 short block? Isn't it cheaper? I guess they've already begun the surgery anyways.. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 24, 2012 Share Posted September 24, 2012 Oil light never went on strangely. Plan is new internals just OEM i need the car back You can get a new oem EJ257 in a couple of day's for $1880 + tax and shipping. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Caboose Posted September 24, 2012 Share Posted September 24, 2012 You can get a new oem EJ257 in a couple of day's for $1880 + tax and shipping. If I didn't do it myself, what kind of labor cost to do the swap? Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted September 24, 2012 Share Posted September 24, 2012 All shops will be different call a couple in your area that you TRUST, or ask around the forum and people will make recomendations. but asking how much a rebuild will cost is way too broad.. You supplying parts?Does block need machining? do you want to forge internals? do you want a nitride crank? How much power you wanting to put down? what size turbo? just sayin.. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 24, 2012 Share Posted September 24, 2012 If I didn't do it myself, what kind of labor cost to do the swap? I spent about 5000 doing most labor myself. But I did more then a cheap quick rebuild. I plan to keep my wagon. That's with a new clutch, timing belt kit, oil pump, heads rebuilt and ported. The machine shop took the old heads off and give me back a long block with timing belt and oil pan on. http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Caboose Posted September 24, 2012 Share Posted September 24, 2012 I spent about 5000 doing most labor myself. But I did more then a cheap quick rebuild. I plan to keep my wagon. That's with a new clutch, timing belt kit, oil pump, heads rebuilt and ported. The machine shop took the old heads off and give me back a long block with timing belt and oil pan on. Based on your mods, and the "above and beyond OEM" stuff you did to your rebuild, how long you think it'll run before you have wash, rinse, and repeat? Link to comment Share on other sites More sharing options...
leggyman17 Posted September 24, 2012 Author Share Posted September 24, 2012 my build is approx 4000$, new OEM crank, bearings, machining the block, 11mm oil pump, Moroso oil pickup, Hot tanking the heads, new headgaskets, timingbelt, tensioners, etc. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 24, 2012 Share Posted September 24, 2012 Based on your mods, and the "above and beyond OEM" stuff you did to your rebuild, how long you think it'll run before you have wash, rinse, and repeat? Years as in 5 or more. my build is approx 4000$, new OEM crank, bearings, machining the block, 11mm oil pump, Moroso oil pickup, Hot tanking the heads, new headgaskets, timingbelt, tensioners, etc. That sounds about right. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Caboose Posted September 25, 2012 Share Posted September 25, 2012 my build is approx 4000$, new OEM crank, bearings, machining the block, 11mm oil pump, Moroso oil pickup, Hot tanking the heads, new headgaskets, timingbelt, tensioners, etc. That just for parts, or turn key? Link to comment Share on other sites More sharing options...
leggyman17 Posted September 25, 2012 Author Share Posted September 25, 2012 Turn key fully assembled. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 25, 2012 Share Posted September 25, 2012 I'd say it'll also be a perfect time to install an oil pressure gauge. Link to comment Share on other sites More sharing options...
leggyman17 Posted September 25, 2012 Author Share Posted September 25, 2012 I'd say it'll also be a perfect time to install an oil pressure gauge. Lol most definatly Link to comment Share on other sites More sharing options...
Danteneon Posted September 26, 2012 Share Posted September 26, 2012 I'm surprised by the pump failure as well. Have them show you the old pick-up tube. I'm still betting on it being cracked. Glad to hear it is coming together either way. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 26, 2012 Share Posted September 26, 2012 Have them show you the old pick-up tube. I'm still betting on it being cracked. me too. Link to comment Share on other sites More sharing options...
leggyman17 Posted October 1, 2012 Author Share Posted October 1, 2012 Update : new OEM crank and ACL race bearings going in. also a Moroso oil pickup and a Spec stage 1 clutch. Link to comment Share on other sites More sharing options...
dr_sharp Posted October 1, 2012 Share Posted October 1, 2012 personally, I would've just got an ej257 rather than splitting the block. but good luck, hope it works out for you. lol Link to comment Share on other sites More sharing options...
leggyman17 Posted October 2, 2012 Author Share Posted October 2, 2012 personally, I would've just got an ej257 rather than splitting the block. but good luck, hope it works out for you. i wanted too. But nobody in my area had one readily avaliable :/ Link to comment Share on other sites More sharing options...
Max Capacity Posted October 2, 2012 Share Posted October 2, 2012 Update : new OEM crank and ACL race bearings going in. also a Moroso oil pickup and a Spec stage 1 clutch. Spec stage 1 ? I would go at least a 2 or 2+ if you like to drag race. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
leggyman17 Posted October 2, 2012 Author Share Posted October 2, 2012 No more drag racing for me in my daily lmao Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted October 2, 2012 I Donated Share Posted October 2, 2012 Hijacking this thread for a moment: Max Capacity what clutch would you recommend for a DD + autocrosser? I never drag race it, but do some quick starts autocrossing sometimes. Link to comment Share on other sites More sharing options...
