Haight 05LGT Posted September 13, 2012 Share Posted September 13, 2012 +1^^ Link to comment Share on other sites More sharing options...
DocHolladay23 Posted September 13, 2012 Share Posted September 13, 2012 5W-40 T6 here as well. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
aggmcmuffin Posted September 13, 2012 Share Posted September 13, 2012 Thats unfortunate. I hate using two gallons. I can never fit it all in my engine. Not sure if serious. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2012 Share Posted September 13, 2012 That's a joke... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Brunex Posted September 13, 2012 Share Posted September 13, 2012 I was surprised to see that the Rotella T6 was used in the LGT... so that oil is suppose to be for diesel engines. Whats the advantage of using it? Link to comment Share on other sites More sharing options...
mwm5094 Posted September 13, 2012 Share Posted September 13, 2012 puralator pureone filter, rotella t6, fumoto... fixed! Link to comment Share on other sites More sharing options...
BoozeRS05 Posted September 13, 2012 Share Posted September 13, 2012 I was surprised to see that the Rotella T6 was used in the LGT... so that oil is suppose to be for diesel engines. Whats the advantage of using it? Turbo Subaru's tend to shear oils pretty badly, and starting with a 5w30 tends to leave you with a 20 weight after your oil interval. Using a more robust oil to start with is to your benefit. Check out 'bob is the oil guy' for the most comprehensive oil forum out there, plenty of Subaru owners represented there. fixed! I've been considering it, esp since last time I needed a crusher washer it was $2.50 for two at Pep Boys.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted September 13, 2012 Mega Users Share Posted September 13, 2012 i just put rotella in cuz everyone else does, seriously "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
dr_sharp Posted September 13, 2012 Share Posted September 13, 2012 I couldn't decide which oil to use so I stopped using it altogether. lol Link to comment Share on other sites More sharing options...
Nrw Posted September 13, 2012 Share Posted September 13, 2012 I prefer Crisco myself Link to comment Share on other sites More sharing options...
Wonder_Boy Posted September 13, 2012 Share Posted September 13, 2012 ^^ I started doing that, now I just put dough balls down my oil/crisco fill tube and golden brown biscuits come out the exhaust Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 13, 2012 Share Posted September 13, 2012 Quote: Originally Posted by HAMMER DOWN http://legacygt.com/forums/skynetim/buttons/viewpost.gif 0W-30 AMSOIL Signature Series Synthetic Motor Oil & Ea oil filters all year round. 15k OCI, still rock for over 200k ,original motor & VF-40 turbo at 18.5 psi. Mike Don't get him going... .... Buy two gallons and one qt of t6. After you drain the oil and put the plug back in, put the first gallon in. Then open the qt and bring the oil level up to full. Use that qt to top it off weekly as needed or so. Re-fill that qt from the other gallon you bought. Repeat the process as needed. I used to run the rotella 15w-40 in the summer and a 10w or 5w-30 in the winter. Now, HAMMERDOWN has me putting Amsoil in 3 cars. .... Yap it's all my fault Be careful what you ask...LOL .... Like I really twisted you arm on that one:rolleyes: Quote: Originally Posted by InnocentGuns http://legacygt.com/forums/skynetim/buttons/viewpost.gif how often do you check / add oil? and how much do you typically have to add? Check oil once a week. That about 600-700 miles. I add 2-4qts. over the 15k OCI. Depends on how hard I drive it. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Haight 05LGT Posted September 13, 2012 Share Posted September 13, 2012 Hammer down, do you have your banjo filter removed? Link to comment Share on other sites More sharing options...
Mill Posted September 13, 2012 Share Posted September 13, 2012 Ive changed my oil about 5 or 6 times since owning the car. The dealer did it when I bought it and never put a crush washer on. Since ive changed it Ive never used one. Lol... thinking about getting a fumoto valve cause I'm too lazy to buy washers. Ive never had any problems with it though. Aside from having to use a breaker bar to break the plug because apparently the dealer impacted it on. Link to comment Share on other sites More sharing options...
InnocentGuns Posted September 13, 2012 Author Share Posted September 13, 2012 I use what it says on the cap, 5w30. Castrol Syntec w/Edge if you like what the cap says, you should read your owners manual. 5-30 is a fail safe for colder temps. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 13, 2012 Share Posted September 13, 2012 Hammer down, do you have your banjo filter removed? Yes, from other threads I posted in. I finally got around to pulling both of the Banjo filter bolts. The turbo one was about 50% plugged. And the driver side ACVS unit was 25% plugged. Pic. of turbo Banjo filter. Over 73k on my GT http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0812072233.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0812072235.jpg I stated this earlier. http://legacygt.com/forums/showpost....7&postcount=44 But change my mind. Do to my oil\filter change history. I put new filter bolts in to see if the clogging took place more in the first 30k Mobil1\Fram or the last 43k, using Amsoil oil\filer. Originally Posted by HAMMER DOWN http://legacygt.com/forums/skynetim/buttons/viewpost.gif This would be me:p:). 2 microns filtration, 15k OCI, Cobbs stage 1 93 tune, 16.2 psi. of max boost & 169k+miles on the original motor & turbo. Took the original ones out at 73k. Another 4k I will have 100k on this set of banjo filter bolts. Then I will inspect & if all is fine. I will leave them out. If I have crap in them. I but new ones in & change them out every 100k. Mike Update, back is Sept.2011, at 174k, I recheck my banjo filter bolts. After 100k on just Amsoil 0w-30 SSO & Ea oil filters. Both banjo filter bolts was clean. So I remove both filters from the banjo bolts & reinstalled with new washers. There was no shaft play on my original VF-40 turbo. Oil history from day1: New. SOA filter & oil 4000 miles 1st. oil & filter change till 30k, Mobil1, 5w-30 every 6000 miles \ Fram oil filter every 3000 miles. Amsoil 0w-30 SSO and Amsoil Ea oil filter, Ea15k13 oil filter at 30k-73k . At 73K, my filtration I use.http://legacygt.com/forums/showthrea...ons-81741.html My oil system now is 7qt. I add 2-4qts over the 15k OCI. Oil consummation hasn't change sense car was new. Most off the shelf oil filter, filter down between 20 & 40 microns. Amsoil full-flow oil filter is 15 microns & Amsoil By-Pass oil filter is 2 microns. This filtration system add 2qts. of oil to you motor. Which help keep the oil cooler. My GT mileage; over 200k My G\F's 05 WRX use same oil & OCI, but uses 1 single spin-on, Ea15k13 oil filter. The WRX as over 150k. I add 2-4qts over the 15k OCI. Oil consummation hasn't change sense car was new. My 07 Pontiac Solstice GXP, 2.0L DI turbo charge motor, Same oil & OCI, but No Ea filter is available. I use a WIX filter. Change oil filter only every 5k. GXP as over 84k. No oil consummation over it's 15k OCI. In short, check you oil level often & top as needed. Use oil & filter that will protect for the OCI your running. OA's is the only way you know that yoru oil & filter is up for the challenge. After that IMO no OA's are needed. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Flipapotimus Posted September 14, 2012 Share Posted September 14, 2012 5W-40 only in my car. All year long. As far as filters, I stick with the OE filter. The pressure relief is much lower that a standard "off the shelf" aftermarket filter. I have disected almost every filter available and the Mobil 1 for the subaru has a rediculous tiny filter element. Look at the inlet holes on a Subaru vs any aftermarket filter. Measure the size of the holes and the quanity. I strongly feel a Subaru filter will/does flow better. I think I have a thread with pictures of the filters side by side, taken apart. So it seems like I need to start using a different filter also. I think next oil change I will take it to my me mechanic again and have him check the banjo bolts and in my meantime I will look for one of these fumoto valves. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 14, 2012 Share Posted September 14, 2012 +1 for the Fumoto's 3 out of 4 of my cars have them. The 4th one only get's it's oil changed once a year, 86 F-150, less then 2000 miles a year. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
joeblow Posted September 15, 2012 Share Posted September 15, 2012 I ran a fumoto on my LGT and then swapped it over to my WRX. Its pretty low and I don't have to jack the car up to do an oil change since its tool-less now. I ran T6 with Subie blue filters on my LGT, but now I run Amsoil 5w40 euro blend and Purloator P1 filters in my WRX. I didn't use a noticeable amount over my last 3500 mile OCI, and I'm awaiting blackstone results about extending my OCI to 5k-7500 miles. Basically I'm paying more for oil to not have to change it as often. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Roche Posted October 8, 2012 Share Posted October 8, 2012 I've never used any oil. I have Mobil 1 full synthetic with Mobil 1 filter in it now, but after reading this I think I'll get Rotella T6 next. Still unsure about a filter. They want me to change my oil every 5k What's this banjo filter I'm hearing about? Link to comment Share on other sites More sharing options...
joeblow Posted October 8, 2012 Share Posted October 8, 2012 Do a quick search and there should be a thread about the whole thing and how to remove it if it hasn't been removed already. In the 05 and maybe 06 LGTs, there was a filter in the banjo bolt on the block under the turbo inlet that connects the turbo oil feed line. There were a lot of issues with that getting clogged with crap and starving the turbo of oil. No oil to the turbo means no more turbo. It was bad enough that Subaru eliminated the filter in subsequent years. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Roche Posted October 8, 2012 Share Posted October 8, 2012 Do a quick search and there should be a thread about the whole thing and how to remove it if it hasn't been removed already. In the 05 and maybe 06 LGTs, there was a filter in the banjo bolt on the block under the turbo inlet that connects the turbo oil feed line. There were a lot of issues with that getting clogged with crap and starving the turbo of oil. No oil to the turbo means no more turbo. It was bad enough that Subaru eliminated the filter in subsequent years. My turbo was just replaced, could it still be an issue? Link to comment Share on other sites More sharing options...
mwm5094 Posted October 9, 2012 Share Posted October 9, 2012 If the clogged filter was the reason your turbo went and they didn't do anything about it besides replacing the turbo.... Yes it would still be an issue. Link to comment Share on other sites More sharing options...
Roche Posted October 9, 2012 Share Posted October 9, 2012 I think I'll just remove the screen altogether. Link to comment Share on other sites More sharing options...
lgt_nube Posted October 9, 2012 Share Posted October 9, 2012 Mobil 10W-30 conventional oil. Moderate (sometimes hot) climate. 140K miles and never had to add any between twice-per-7500 mile changes. A few photos of the LGT My current ride Link to comment Share on other sites More sharing options...
