maleki777 Posted July 23, 2012 Share Posted July 23, 2012 95 Legacy EJ22E 5 speed with cruise. What's goin on, with clutch pedal all the way UP no pressure on it, car running not in gear, I can the squiking from the fork which is not a concern, however I also here a sound like metal rubbing. I push the clutch in and it goes away. I'm sure it's the flywheel amd clutch plate rubbing barly.,my quetion is do you agree? And if so can I fix this simply by just adjusting it? Also what is the squiking, it gies away when I push the clutch or push against it under the hood by hand? THANK YOU. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 23, 2012 I Donated Share Posted July 23, 2012 Sounds like you need to buy a flywheel and clutch kit. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
mnbd Posted July 25, 2012 Share Posted July 25, 2012 There should be a metal clip behind the clutch fork, and if that falls off or breaks will cause a squeaking noise and prevent you from fully disengaging the clutch. Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 25, 2012 Share Posted July 25, 2012 Throwout bearing Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 26, 2012 I Donated Share Posted July 26, 2012 Throwout bearing I'm pretty sure I covered that in my reply. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 I'm pretty sure I covered that in my reply. Pretty sure you said flywheel and clutch kit... Not throwout bearing and also that's not that problem the problem is the throwout bearing and the flywheel is prolly fine Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 27, 2012 I Donated Share Posted July 27, 2012 The throwout bearing comes with the clutch kit. You can buy a clutch kit for less than 200 bucks. Its standard (and good practice) to replace everything while you're in there to avoid doing it twice. Usually when a throw out bearing starts making noise is close to the end of the clutch disks life. Its also standard practice (and good practice) to either machine or replace a flywheel with a new clutch. Before you try and give advise, be sure you're giving PROPER advise. Otherwise you wind up looking like an ass hat. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 The throwout bearing comes with the clutch kit. You can buy a clutch kit for less than 200 bucks. Its standard (and good practice) to replace everything while you're in there to avoid doing it twice. Usually when a throw out bearing starts making noise is close to the end of the clutch disks life. Its also standard practice (and good practice) to either machine or replace a flywheel with a new clutch. Before you try and give advise, be sure you're giving PROPER advise. Otherwise you wind up looking like an ass hat. Dead honest opinion the only one looking like an ass Here is you... Someone asked what was making noise on his car and I told him what was making the noise that was it I didn't advise him to only replace that or do that repair or anything. I do agree while your in there do it all but he didn't ask that I just answered what the noise was. And yes I agree that while your in mite as well change it all and also flywheel may need machining or changing but it doesn't only take an hour to pull a trans and an hour and a half to put it back in or less so 3 hours of work total with changing the clutch so if the user did his own work and didn't want to change the flywheel he could but I do agree with you and you can re read over my posts I never said he should just change the throwout bearing so I don't know why you are trying to start an argument over me simply informing the poster that the noise be was hearing was coming from the throwout bearing Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 27, 2012 I Donated Share Posted July 27, 2012 He asked about how to fix it. The truth is you can't know for 100% sure until you take it apart. I advised him on the "proper" fix. You gave a half ass answer. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
bigjweb Posted July 27, 2012 Share Posted July 27, 2012 Half ass answer then got defensive when called on it Link to comment Share on other sites More sharing options...
NWSPECB Posted July 27, 2012 Share Posted July 27, 2012 Dead honest opinion the only one looking like an ass Here is you... Someone asked what was making noise on his car and I told him what was making the noise that was it I didn't advise him to only replace that or do that repair or anything. I do agree while your in there do it all but he didn't ask that I just answered what the noise was. And yes I agree that while your in mite as well change it all and also flywheel may need machining or changing but it doesn't only take an hour to pull a trans and an hour and a half to put it back in or less so 3 hours of work total with changing the clutch so if the user did his own work and didn't want to change the flywheel he could but I do agree with you and you can re read over my posts I never said he should just change the throwout bearing so I don't know why you are trying to start an argument over me simply informing the poster that the noise be was hearing was coming from the throwout bearing tl;dr Link to comment Share on other sites More sharing options...
NWSPECB Posted July 27, 2012 Share Posted July 27, 2012 The throwout bearing comes with the clutch kit. You can buy a clutch kit for less than 200 bucks. Its standard (and good practice) to replace everything while you're in there to avoid doing it twice. Usually when a throw out bearing starts making noise is close to the end of the clutch disks life. Its also standard practice (and good practice) to either machine or replace a flywheel with a new clutch. Before you try and give advise, be sure you're giving PROPER advise. Otherwise you wind up looking like an ass hat. also tl;dr But being that brok posted it I will say that I agree with everything in this post because it is correct. Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 He asked about how to fix it. The truth is you can't know for 100% sure until you take it apart. I advised him on the "proper" fix. You gave a half ass answer. Okay sorry I gave a half ass correct answer my bad your the master of all subarus and know so much more than me why did I bother Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 27, 2012 I Donated Share Posted July 27, 2012 Half ass answer then got defensive when called on it tl;dr also tl;dr But being that brok posted it I will say that I agree with everything in this post because it is correct. Okay sorry I gave a half ass correct answer my bad your the master of all subarus and know so much more than me why did I bother :lol::lol::lol: -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 People were saying that the noise was the clutch rubbing the flywheel and that clearly isn't right and doesn't make sense and I know you posted clutch kit and flywheel I agree that's what he should do and obviously he'll listen to someone with way more posts than me before he listens to me. I just wanted to clarify that the noise was the throwout bearing not the clutch rubbing on the flywheel Link to comment Share on other sites More sharing options...
NWSPECB Posted July 27, 2012 Share Posted July 27, 2012 Okay sorry I gave a half ass correct answer my bad your the master of all subarus and know so much more than me why did I bother If only turbodog could have figured this out as early as you have... Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 :lol::lol::lol: Hahaha someone thought I was serious... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 27, 2012 I Donated Share Posted July 27, 2012 Like I said before, you don't know what it is until you get into it. I've seen noisy clutches where the rivets on the disk are rubbing on either the flywheel or pressure plate. So yes, he very well may be correct. Hahaha someone thought I was serious... No I'm laughing at the entire string of conversation -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 Like I said before, you don't know what it is until you get into it. I've seen noisy clutches where the rivets on the disk are rubbing on either the flywheel or pressure plate. So yes, he very well may be correct. Yes agreed except that if it only does the noise when the pedal is not being pressed then it can't be a clutch especially if it still does it in neutral with the pedal not pressed it only can be the throwout bearing No I'm laughing at the entire string of conversation Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 Oh that one came out weird I think I typed in the quote my bad Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 27, 2012 I Donated Share Posted July 27, 2012 I like your mystical powers of internet diagnostics. Please teach me oh wise one. http://www.cruzine.com/wp-content/uploads/2010/10/032-china.jpg -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
NWSPECB Posted July 27, 2012 Share Posted July 27, 2012 Class is about to start. Everybody take their seats please. Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 I like your mystical powers of internet diagnostics. Please teach me oh wise one. Why thank you great sir who think a clutches rivets can make noise while engaged in neutral... Thats totally possible especially since at that point the clutch is spinning the exact same speed as the flywheel you know everything sir and aren't cocky at all a totally humble dude sorry I posted in the sane thread as you Link to comment Share on other sites More sharing options...
NWSPECB Posted July 27, 2012 Share Posted July 27, 2012 99legacyturbo - I got everybody to sit down and shut up. Please proceed with your teachings. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 27, 2012 I Donated Share Posted July 27, 2012 Why thank you great sir who think a clutches rivets can make noise while engaged in neutral... Thats totally possible especially since at that point the clutch is spinning the exact same speed as the flywheel you know everything sir and aren't cocky at all a totally humble dude sorry I posted in the sane thread as you Ever hear of a slipping clutch? http://chzmemebase.files.wordpress.com/2012/07/internet-memes-sarah-jessica-parker-is-a-great-mechanic.jpg -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
