DocHolladay23 Posted May 30, 2012 Share Posted May 30, 2012 An increase in functionality usually leads to an increase in monies, which is then decreased in order to increase coolness. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 30, 2012 I Donated Share Posted May 30, 2012 "Stay broke, stay happy" Link to comment Share on other sites More sharing options...
Saigon78 Posted May 30, 2012 Share Posted May 30, 2012 Actually, it's not a dumb question. By definition, tint reduces light transmissibility. So if you tint your tails, the primary objective effect is to reduce light output from them, even if your stated goal is just to make the car look cooler. It's not a primary objective it's a side effect. Come on don't throw logic out the window because you're in a losing battle. It's a dumb question because it's rhetorical. Taillight tint can also protect your tails from being scratched, scuffed, etc. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 30, 2012 I Donated Share Posted May 30, 2012 It's not a primary objective it's a side effect. Come on don't throw logic out the window because you're in a losing battle. Apparently you are unfamiliar with the concept of objective vs. subjective, so here's a link describing the difference: http://www.differencebetween.net/language/difference-between-objective-and-subjective/ Don't talk to me about logic until you can grasp a simple distinction like that. Also, if you think all rhetorical questions are dumb, would you like to buy some oceanfront property in Arizona? Link to comment Share on other sites More sharing options...
Saigon78 Posted May 30, 2012 Share Posted May 30, 2012 Apparently you are unfamiliar with the concept of objective vs. subjective, so here's a link describing the difference: http://www.differencebetween.net/language/difference-between-objective-and-subjective/ Don't talk to me about logic until you can grasp a simple distinction like that. Also, if you think all rhetorical questions are dumb, would you like to buy some oceanfront property in Arizona? *facepalm* Did you read that link before you posted it? That link is using the word Objective as an Adjective we are using it as a Noun. Not at all relevant to this discussion. Read, the Objective is the person's Intended Goal. I guess you are going to need the definition for Intended now... I'll give you a hint this time it is being used as an Adjective. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 30, 2012 I Donated Share Posted May 30, 2012 *facepalm* Did you read that link before you posted it? That link is using the word Objective as an Adjective we are using it as a Noun. Not at all relevant to this discussion. Read, the Objective is the person's Intended Goal. I guess you are going to need the definition for Intended now... I'll give you a hint this time it is being used as an Adjective. Okay, genius, do you need me to diagram my original sentence? Actually, it's not a dumb question. By definition, tint reduces light transmissibility. So if you tint your tails, the primary objective effect is to reduce light output from them, even if your stated goal is just to make the car look cooler. "So if you tint your tails" is a dependent clause. I'm not going to diagram it. "the" is an article. "primary" and "objective" are ADJECTIVES. Yes, ADJECTIVES. "effect" is the noun/subject. ("objective" is not.) "is" is the verb. "to reduce" is an infinitive modifying the verb. "light output" is the direct object. "from them" is a prepositional phrase. "even if your stated goal is just to make the car look cooler" is another dependent clause that I'm not going to diagram either. I can't believe I just had to do that. Link to comment Share on other sites More sharing options...
pillboy Posted May 30, 2012 Share Posted May 30, 2012 God I hated diagramming sentences...I'm not coming back in this thread...brings back too many childhood anxieties. It is still ugly. Link to comment Share on other sites More sharing options...
Saigon78 Posted May 31, 2012 Share Posted May 31, 2012 Okay, genius, do you need me to diagram my original sentence? "So if you tint your tails" is a dependent clause. I'm not going to diagram it. "the" is an article. "primary" and "objective" are ADJECTIVES. Yes, ADJECTIVES. "effect" is the noun/subject. ("objective" is not.) "is" is the verb. "to reduce" is an infinitive modifying the verb. "light output" is the direct object. "from them" is a prepositional phrase. "even if your stated goal is just to make the car look cooler" is another dependent clause that I'm not going to diagram either. I can't believe I just had to do that. You're wrong so you're going full retard? I love arguing on the internet. Congrats to the winners. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 31, 2012 I Donated Share Posted May 31, 2012 You're wrong so you're going full retard? Hey, you're the one who fails at reading comprehension. Link to comment Share on other sites More sharing options...
Saigon78 Posted May 31, 2012 Share Posted May 31, 2012 Hey, you're the one who fails at reading comprehension. You're in a fail argument, with a fail point of view and you are now making up your own definitions. http://en.wikipedia.org/wiki/Primary_objective Link to comment Share on other sites More sharing options...
Ellesedil Posted May 31, 2012 Share Posted May 31, 2012 So, who else thinks this thread has run its course? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 31, 2012 I Donated Share Posted May 31, 2012 You're in a fail argument, with a fail point of view and you are now making up your own definitions. http://en.wikipedia.org/wiki/Primary_objective Apparently you are unaware that in the English language, many words can be used in multiple ways. So, who else thinks this thread has run its course? This guy. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted May 31, 2012 I Donated Too Share Posted May 31, 2012 This guy. yet you keep posting Link to comment Share on other sites More sharing options...
Saigon78 Posted May 31, 2012 Share Posted May 31, 2012 Apparently you are unaware that in the English language, many words can be used in multiple ways. I want you to go back and re-read this thread. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 1, 2012 I Donated Share Posted June 1, 2012 yet you keep posting I want you to go back and re-read this thread. Why? You're the one having reading-comprehension issues here. You don't grasp the English language well enough to understand what I wrote. Not my fault. Link to comment Share on other sites More sharing options...
bmx045 Posted June 1, 2012 Share Posted June 1, 2012 lick my ass Link to comment Share on other sites More sharing options...
faded-a-fool Posted June 1, 2012 Share Posted June 1, 2012 Mods, please close this thread. It is now way off topic Link to comment Share on other sites More sharing options...
TcDavis Posted June 1, 2012 Share Posted June 1, 2012 Mods, please close this thread. It is now way off topic I 2nd that notion! ReDQlous Link to comment Share on other sites More sharing options...
blklgt05 Posted June 1, 2012 Share Posted June 1, 2012 Mods, please close this thread. It is now way off topicI 2nd that notion! ReDQlous 3rd!! mod journal Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 2, 2012 Share Posted June 2, 2012 Semantics aside, it's still a stupid idea to tint your taillights. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
superscooby Posted June 3, 2012 Author Share Posted June 3, 2012 Yup, all you guys keep over thinking the semantics, the legality and the other retarded details of the matter while we will keep making our cars cool and thus keep getting laid by hot chicks. Have fun with your internet friends and your schematics. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 3, 2012 I Donated Share Posted June 3, 2012 Hot chicks dig tinted taillights... Link to comment Share on other sites More sharing options...
KUSoob Posted June 3, 2012 Share Posted June 3, 2012 http://cdn.memegenerator.net/instances/400x/21411179.jpg Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted June 3, 2012 I Donated Too Share Posted June 3, 2012 Yup, all you guys keep over thinking the semantics, the legality and the other retarded details of the matter while we will keep making our cars cool and thus keep getting laid by hot chicks. Have fun with your internet friends and your schematics. Jesus. Any iota of leverage/credibility you had in the debate just went flying out the tinted window. Link to comment Share on other sites More sharing options...
superscooby Posted June 3, 2012 Author Share Posted June 3, 2012 Just sayin Link to comment Share on other sites More sharing options...
