ibr_adam09 Posted October 17, 2011 Share Posted October 17, 2011 Not really sure where this leak is coming from, but I notice it while doing my front sway bars. The pass side is has oil along the edges of the valve cover near the back of the bank ( towards the firewall side) and dripping onto my uppipe and down onto the sway bar. Before I replace anything, are there any other seals that could be there ? http://i344.photobucket.com/albums/p330/ibr_adam09/2005%20Legacy%20GT%20%20ABP/SAM_1193.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/2005%20Legacy%20GT%20%20ABP/SAM_1194.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/2005%20Legacy%20GT%20%20ABP/SAM_1196.jpg Link to comment Share on other sites More sharing options...
captainobvious Posted November 7, 2011 Share Posted November 7, 2011 I just noticed that as well. Hope its not to much of an indepth repair job. Link to comment Share on other sites More sharing options...
ehsnils Posted November 7, 2011 Share Posted November 7, 2011 The seal in the spark plug well is known for being a potential leak. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 7, 2011 Share Posted November 7, 2011 The valve cover gaskets do go and aren't insanely hard to do. Its just a tight fit and is annoying. As people have said you should do the spark plug seals as well since they come out when you pull the valve cover. Otherwise there isnt much else to leak from there. -Jake http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg Call directly for your best Whiteline Price! | We also carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
captainobvious Posted November 8, 2011 Share Posted November 8, 2011 I got the gaskets for the valve covers and the 4 other smaller ones. I should go to the dealer and get the spark plug ones too seeing the guy im bringing it to wil have it all apart. Link to comment Share on other sites More sharing options...
lowwill Posted November 8, 2011 Share Posted November 8, 2011 Does it look like this? Been annoying me for weeks. Thought it was coolant than power steering. No leaks from turbo. Just seems to burn on the exhaust. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 8, 2011 Author Share Posted November 8, 2011 Sorry I had to rehost he pics. I got the pass. gaskets with the spark plug ones as well. Just need to find time to do it. Maybe I'll do a DIY if there isn't one, though it should be self explanatory. Link to comment Share on other sites More sharing options...
captainobvious Posted November 9, 2011 Share Posted November 9, 2011 Well i brought the car to my mechanic friend this morning to get the valve cover gaskets done, and i go there today after lunch only to find out one of the bolts snapped and had to be drilled out and retapped. Thank god it was one that was easy to get to. They have only done the passenger side and the drivers side still has to get done. Crossing my fingers this goes according to plan or im takin my work truck home with me. Link to comment Share on other sites More sharing options...
SCOBARU Posted November 10, 2011 Share Posted November 10, 2011 i had the same problem after my uppipe install, i did the gasket pita btw took me a while to get done. the leak was still there afterwards. i just took brake clean washed down the entire engine and then put some black high heat silicone on the bottom of the valve cover and so far no leaks been about 3 months now. hopefully everything works out for you. Link to comment Share on other sites More sharing options...
captainobvious Posted November 10, 2011 Share Posted November 10, 2011 It was smokin like crazy last night after the guy changed everything, but after driving awhile it went away, probably residue that had dripped onto the pipes. Checked the oil level this morning so far no leaks and spots on the driveway. Gonna double check again after i get to work as well. Link to comment Share on other sites More sharing options...
lowwill Posted November 10, 2011 Share Posted November 10, 2011 I seen were my issue was. It was so hot above the exhaust on the right side a piece of the gasket was oozing out of place. Literally. Cut away the excess and put some high temp silicon on and no more leak. Its ghetto but then so am I Link to comment Share on other sites More sharing options...
ehsnils Posted November 10, 2011 Share Posted November 10, 2011 It was smokin like crazy last night after the guy changed everything, but after driving awhile it went away, probably residue that had dripped onto the pipes. Checked the oil level this morning so far no leaks and spots on the driveway. Gonna double check again after i get to work as well. An engine wash to get rid of all the old oil and then you can see if the fix was good after a while. Link to comment Share on other sites More sharing options...
captainobvious Posted November 10, 2011 Share Posted November 10, 2011 What would u use to.wash it? What needs to be covered so not to get wet. Sent from my DROIDX using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted November 11, 2011 Share Posted November 11, 2011 Engine-degreaser on the dirty spots, then rinse off with a hose. No pressure washer and no water or degreaser on the alternator and throttle sensor and be careful with the spark plug wells. Also don't spray any hot parts like the turbo. If the engine is warm it will evaporate. Link to comment Share on other sites More sharing options...
c-lo Posted December 20, 2011 Share Posted December 20, 2011 appears I've got a small leak on the passenger side valve cover gasket. how is this replaced? does the engine have to come out?? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Max Capacity Posted December 20, 2011 Share Posted December 20, 2011 No the engine doesn't have to be removed. Unless you have the tools and area, pay the man to do this job. You don't need to go to a stealership just a good mechanic. Any body have a idea of the labor cost for this job ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nrw Posted December 20, 2011 Share Posted December 20, 2011 appears I've got a small leak on the passenger side valve cover gasket. how is this replaced? does the engine have to come out?? Remove intake. Remove coilpacks. Remove the 8 bolts holding the cover on. Remove the cover. Clean mating surfaces. Apply rtv in the proper locations. Add new gasket. Then put it back together. Link to comment Share on other sites More sharing options...
jhawk222 Posted January 9, 2012 Share Posted January 9, 2012 This might be my next mission..will have to commandeer my cousin's heated garage!! Noticed slight smoking. While under the car changing the axle I saw oil on the cross member that appeared to be coming from the valve cover area. Link to comment Share on other sites More sharing options...
subie_dude05 Posted January 13, 2012 Share Posted January 13, 2012 Good info. Which file in the "vacation pics" shows the valve cover removal and installation? i see a diagram in the Engine>Engine Mechanical> General Description and shows RTV on the bottom corner. Also, best place to buy the seals? I have heard that the felpro don't fit well. I will give Fred Beans a call... or victor reinz? http://www.autozone.com/autozone/parts/2005-Subaru-Legacy-AWD/Valve-Cover-Gasket/_/N-jngwmZ8iics?filterByKeyWord=valve+cover&fromString=search Link to comment Share on other sites More sharing options...
ibr_adam09 Posted January 13, 2012 Author Share Posted January 13, 2012 Nrw has it right on the nail. That's what I did. Leak has been cured. Been a month or two now. leak free ! Link to comment Share on other sites More sharing options...
Nrw Posted January 13, 2012 Share Posted January 13, 2012 Good info. Which file in the "vacation pics" shows the valve cover removal and installation? i see a diagram in the Engine>Engine Mechanical> General Description and shows RTV on the bottom corner. Also, best place to buy the seals? I have heard that the felpro don't fit well. I will give Fred Beans a call... or victor reinz? http://www.autozone.com/autozone/parts/2005-Subaru-Legacy-AWD/Valve-Cover-Gasket/_/N-jngwmZ8iics?filterByKeyWord=valve+cover&fromString=search I used felpro on mine and it seemed to fit fine :shrug: Link to comment Share on other sites More sharing options...
subie_dude05 Posted January 13, 2012 Share Posted January 13, 2012 I used felpro on mine and it seemed to fit fine :shrug: maybe it was an older issue and it was fixed. i had seen that comment in the older posts in some of the valve cover threads. Thanks! Link to comment Share on other sites More sharing options...
jhawk222 Posted January 13, 2012 Share Posted January 13, 2012 Located my leak,,,oil return under the turbo. Probably loosened when I installed the uppipe. Gotta get it done this weekend. Sick and tired of the smoke coming from the engine bay from time to time. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2012 Share Posted January 13, 2012 Located my leak,,,oil return under the turbo. Probably loosened when I installed the uppipe. Gotta get it done this weekend. Sick and tired of the smoke coming from the engine bay from time to time. If it's the orginal, it may be time to replace it. Mine was pretty hard when I replaced it back in Aug for the vf52. One member had his crack but he had 180,000 miles on his back in 2010. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted June 10, 2012 Share Posted June 10, 2012 Found this leak on my LGT last week.. good info here, thanks. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
