Max Capacity Posted June 11, 2012 Share Posted June 11, 2012 FWIW, I found that if you replace the studs on the up pipe with good bolts from the dealer, the turbo is much easier to install with the oil return line on it. Use anti-seize compound on the nuts and bolts. Check this thread around post 138, you can see where I used bolts. http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106p5.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted June 11, 2012 Share Posted June 11, 2012 My leak is at the bottom of the valve cover or at the half moon, not the turbo oil feed or return lines. Very small leak, not showing up at all on the dipstick reading yet, just a little residue on the bottom of the valve cover. Coincidentally, I read the bulk of your build thread a couple days ago. Good stuff. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2012 Share Posted June 11, 2012 Thanks, So, I guess your pulling the valve cover soon ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted June 11, 2012 Share Posted June 11, 2012 As much as I don't want to, yes. I'm getting some other work done soon. Might have my shop throw it in with the rest of the list that I don't want to do myself though. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
BoozeRS05 Posted June 11, 2012 Share Posted June 11, 2012 Max, you have a part number for the passenger side valve cover gasket? Pretty easy repair? Remove manifold, and coilpacks, remove valve cover and old gasket, then reinstall? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2012 Share Posted June 11, 2012 I don't have the p/n but make sure the gasket comes with the half moons. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StoplightAssassin Posted June 11, 2012 Share Posted June 11, 2012 Max, you have a part number for the passenger side valve cover gasket? Pretty easy repair? Remove manifold, and coilpacks, remove valve cover and old gasket, then reinstall? It's easy, but you've really over simplified it. Make sure you check out the vacation pics before you start. It is really easy to scratch your cams if you aren't careful. I don't have the p/n but make sure the gasket comes with the half moons. It doesn't. Flatirons Tuning sells a complete kit. http://www.flatironstuning.com/p-2033-subaru-valve-cover-gasket-re-seal-kit.aspx Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2012 Share Posted June 11, 2012 Never seen that site. wow that's a impressive price on the oil cooler. How much is one side gasket set from the dealer. Seems most of us have only the passenger side that leaks. Why is that ? who's the slacker at the factory putting on that side valve cover? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nrw Posted June 11, 2012 Share Posted June 11, 2012 Never seen that site. wow that's a impressive price on the oil cooler. How much is one side gasket set from the dealer. Seems most of us have only the passenger side that leaks. Why is that ? who's the slacker at the factory putting on that side valve cover? I think it's more of a issue of being cooked by the up pipe for x amount of years. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2012 Share Posted June 11, 2012 Hummm, I hadn't thought about it that way. Glad I wrapped mine before I put it back in. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted June 11, 2012 Share Posted June 11, 2012 It seems, through my searching, to happen around people removing the bulky factory UP, scratching the half moon or the somehow dinging the valve cover. I just recently replaced my factory UP, was a little forceful I will admit getting the OEM UP out... EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
brokentv Posted June 17, 2012 Share Posted June 17, 2012 looks like my passenger side is leaking too. Do I need to drain the oil out of the car before I change the gasket? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 17, 2012 Author Share Posted June 17, 2012 I didn't . Link to comment Share on other sites More sharing options...
BoozeRS05 Posted June 17, 2012 Share Posted June 17, 2012 Most everything settles in the pan, you might be ready for a little leakage. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
dr_sharp Posted July 3, 2012 Share Posted July 3, 2012 Whats the best way to confirm this diagnosis without taking everything apart? Got a decent amount of smoke from under the hood today coming from the area under the turbo. Alot of oil dripping onto the up-pipe making the smoke. I was 1.5 qts low It sucks being a sissy in an apt complex with no tools... I scheduled the dealer to look at it on Thursday. lol Link to comment Share on other sites More sharing options...
BoozeRS05 Posted July 3, 2012 Share Posted July 3, 2012 Pull off the under tray, and inspect along the bottom of the valve cover just above the exhaust manifold near the UP. You'll see the oil if it's there. The work isn't hard from what I've gathered, but even with a garage and tools I might farm it out. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
nyogi116 Posted July 23, 2012 Share Posted July 23, 2012 Passenger side = Left side? Link to comment Share on other sites More sharing options...
BoozeRS05 Posted July 23, 2012 Share Posted July 23, 2012 If you're looking at the car from the front, yes. It's the side of the car that the passenger sits on... EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2012 Share Posted July 23, 2012 Passenger side = Left side? I guess some people don't realize you always talk as if your in the drivers seat. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dr_sharp Posted July 23, 2012 Share Posted July 23, 2012 I thought 'passenger side' was pretty self explanatory lol lol Link to comment Share on other sites More sharing options...
BoozeRS05 Posted July 23, 2012 Share Posted July 23, 2012 You would think so. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
brokentv Posted July 24, 2012 Share Posted July 24, 2012 I just changed my passenger side valve cover gasket and and I haven't noticed any leaking so far. The job was pretty straight forward just take your time if you haven't done it before. Link to comment Share on other sites More sharing options...
ehsnils Posted July 24, 2012 Share Posted July 24, 2012 I thought 'passenger side' was pretty self explanatory lol Not if you have a RHD car (which is the norm in Japan and the UK/Ireland). Link to comment Share on other sites More sharing options...
Max Capacity Posted July 24, 2012 Share Posted July 24, 2012 Not if you have a RHD car (which is the norm in Japan and the UK/Ireland). Yea, but the rest of know those people always drive on the wrong side anyways... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dr_sharp Posted July 24, 2012 Share Posted July 24, 2012 Not if you have a RHD car (which is the norm in Japan and the UK/Ireland). I'd suspect that any intelligent person could determine that the majority of people that post on this forum are in the US and hence saying passenger side is not ambiguous. But hey, maybe I'm wrong about intelligent people on this forum lol Link to comment Share on other sites More sharing options...
