eekay Posted November 8, 2012 Share Posted November 8, 2012 Interesting. I like it. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 8, 2012 Author Share Posted November 8, 2012 Damn. My motor I'm building needs a different block Sent from my SCH-I800 using Tapatalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted November 8, 2012 Share Posted November 8, 2012 Damn. My motor I'm building needs a different block Sent from my SCH-I800 using Tapatalk 2 Why? Run oversize bearings -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 8, 2012 Author Share Posted November 8, 2012 they would have to be over size each way. over and over, the block is bad BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted November 8, 2012 Share Posted November 8, 2012 Like the mains are oversize? Have it line honed, they can make it perfect to the clearances you specify. I paid $175 to have my 22T hind honed, measured and blueprinted. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 11, 2012 Author Share Posted November 11, 2012 but you cant add metal to get the clearence to were it needs to be. i have 09 ej257 case halves in the mail with only 300 miles. i swear if someone managed to **** up a near new engine ill be Most pissed BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted November 11, 2012 Share Posted November 11, 2012 When they line hone a Subaru block they take a few thousands off of the inside mating surfaces of the block then do the line hone on the mains. This will fix the issue of having clearances that are too large like you do. Looks like you solved the issue with a new case though. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 11, 2012 Author Share Posted November 11, 2012 When they line hone a Subaru block they take a few thousands off of the inside mating surfaces of the block then do the line hone on the mains. This will fix the issue of having clearances that are too large like you do. Looks like you solved the issue with a new case though. its like someone honed it but didnt shave the case halves. i cant fix it because its over by 2.-4 thou from the stock upper limit. i would have to shave alot off the case halves. BNR18g on 93oct Link to comment Share on other sites More sharing options...
Stang70Fastback Posted November 12, 2012 Share Posted November 12, 2012 Bahaha, Swagon_Wagon, I am honored to be featured in your signature Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 12, 2012 Author Share Posted November 12, 2012 today i checked my balance to make sure i was not under, good news. i may have the exhaust done sooner then i thought. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 13, 2012 Author Share Posted November 13, 2012 anyone know where i can buy a good set of spark plug wires. like better deals? pretty sure mine have at least 20k on them. Edit: I just got the msd coil in the mail. Pics:D http://img.tapatalk.com/d/12/11/14/yjyvapaz.jpg BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 20, 2012 Author Share Posted November 20, 2012 My mains look like this! Each one. A little loose for mains? What do you think The thrust bearing has a wee bit tighter but that's not a problem. I think its on purpose. http://img.tapatalk.com/d/12/11/20/guqedy2u.jpg I also got this sexy pic http://img.tapatalk.com/d/12/11/20/esy7yvub.jpg Sent from my SCH-I800 using Tapatalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 20, 2012 Share Posted November 20, 2012 MSD coil & 257 block ftw. Link to comment Share on other sites More sharing options...
Dufek125 Posted November 20, 2012 Share Posted November 20, 2012 oreilly auto parts has got idw(import direct wires) for like ~$40, there basically oem wires thrown in a different box. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 20, 2012 Author Share Posted November 20, 2012 Anyone know if better wires would benifit me enough to care? Sent from my SCH-I800 using Tapatalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
NickTej22 Posted November 20, 2012 Share Posted November 20, 2012 Anyone know if better wires would benifit me enough to care? Sent from my SCH-I800 using Tapatalk 2 You won't notice any difference lol. I think the ngk wires that you can get from advance or AutoZone are 1mm thicker than stock. Sent from my SGH-T679 using Tapatalk 2 Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 21, 2012 Author Share Posted November 21, 2012 is stock 6mm? BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 21, 2012 Author Share Posted November 21, 2012 o and a little secret of whats to come. powder BNR18g on 93oct Link to comment Share on other sites More sharing options...
Dufek125 Posted November 21, 2012 Share Posted November 21, 2012 stock is 7mm i believe. green powdercoat?? Link to comment Share on other sites More sharing options...
NickTej22 Posted November 21, 2012 Share Posted November 21, 2012 Stock is 7. Ngk I believe are 8 Sent from my SGH-T679 using Tapatalk 2 Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 21, 2012 Author Share Posted November 21, 2012 got a bunch of small fitment question im gonna toss out. do the water crossover pipes interchange from say a 97 lgt to a wrx case halves? what about water pumps, i got a like new one with the other early 2000 ej251 case. and im not to concerned about timing covers but i should be able to use the stock 97 covers right? 96 heads, 09 shortblock? BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted November 22, 2012 Share Posted November 22, 2012 Cross over pipe should match the intake manifold, but they all interchange on the block. Water pumps dont matter besides the outlet angle -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 23, 2012 Author Share Posted November 23, 2012 i dont believe i have updated on the appearence of my car in my build thread yet.. enjoy http://img.tapatalk.com/d/12/11/24/ajeze2uj.jpghttp://img.tapatalk.com/d/12/11/24/yna4apy6.jpghttp://img.tapatalk.com/d/12/11/24/u7aha9e9.jpghttp://img.tapatalk.com/d/12/11/24/sysy7e7u.jpghttp://img.tapatalk.com/d/12/11/24/zapanyru.jpghttp://img.tapatalk.com/d/12/11/24/uqemaje2.jpg BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 26, 2012 Author Share Posted November 26, 2012 http://img.tapatalk.com/d/12/11/26/tysyvyva.jpg Sent from my SCH-I800 using Tapatalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 12, 2013 Author Share Posted January 12, 2013 would anyone care for an update? BNR18g on 93oct Link to comment Share on other sites More sharing options...
