boostedgrocerygetter Posted July 25, 2011 Share Posted July 25, 2011 http://www.amsoil.com/mygarage/vehiclelookup.aspx Link to comment Share on other sites More sharing options...
Max Capacity Posted July 25, 2011 Share Posted July 25, 2011 Yea, so what's your question ? I'm using Amsoil 5w-40 in my 09 Spec B. HAMMER DOWN uses 0w-30 I think. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted July 25, 2011 Author Share Posted July 25, 2011 sorry no question just happened to find this link and figured that it would help others who may have questions about. fluid capacity or fluid weights/types. Link to comment Share on other sites More sharing options...
AZP Installs Posted July 25, 2011 Share Posted July 25, 2011 And if anyone needs Amsoil... We are a master dealer you can order directly through the link below -mike -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
SSpeed Posted July 25, 2011 Share Posted July 25, 2011 That is a very cool site... Link to comment Share on other sites More sharing options...
Max Capacity Posted July 26, 2011 Share Posted July 26, 2011 Good guy's there, AZPinstalls. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted July 26, 2011 Author Share Posted July 26, 2011 That is a very cool site... yea i know i had a little trouble trying to find which fluids and how much my car needed. so figured it could help others as well and help cut down on some questions. if a mod could sticky this im sure it would get used. nice too because you can look up any car you may have. not just your legy. Link to comment Share on other sites More sharing options...
JoeFromPA Posted July 26, 2011 Share Posted July 26, 2011 I recommend a 5 or 10w40 for the engine, their 75w110 severe gear for the trans and rear diff, and a bottle of cheap brake fluid from pep boys for the brakes (unless you track em) Link to comment Share on other sites More sharing options...
BENCOB Posted July 26, 2011 Share Posted July 26, 2011 http://www.amsoil.com/mygarage/vehiclelookup.aspx Thanks for sharing your find...... Link to comment Share on other sites More sharing options...
Instanced Posted August 18, 2011 Share Posted August 18, 2011 So I'm trying to source out all the stuff needed for my 60k service. Got spark plugs already (NGK LFR7AIX), but now I'm looking for fluids. Have my oil and filter already... looking for tranny fluid and front/rear diff fluids... From the website there it says to use a 75W-90 for all temps (we've seen -27F to 110F up here) for all three... I am second guessing myself about this... can someone confirm that to be correct? and what brand should I go with? I have a spec b with the 6spd also what about coolant? stealership purchase for that? am I missing anything? Link to comment Share on other sites More sharing options...
AZP Installs Posted August 18, 2011 Share Posted August 18, 2011 We have had really good success with the Amsoil 75w90 Diffy fluid for the Spec B in both the trans and rear diffy. Subaru Extra S fluid is also something we use, although we use it more in the 5MTs over the 6MTs. As for coolant Subaru Long Life Coolant is probably your best bet. Don't forget to get ATE Superblue brake fuild to flush your brake lines as well. -mike PS: If you want amsoil feel free to order from our site http://AZPInstalls.com Link to comment Share on other sites More sharing options...
outahere Posted August 21, 2011 Share Posted August 21, 2011 ........also what about coolant? ...... Subaru OE, or the "Asian Coolants" from Zerex or Beck-Arnley. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 22, 2011 Share Posted August 22, 2011 Yeah the Subaru Long Life Coolant is what we use in our customer cars. -mike Link to comment Share on other sites More sharing options...
kateviliams Posted September 1, 2011 Share Posted September 1, 2011 thanks for sharing the link of amsoil.com. Link to comment Share on other sites More sharing options...
